Introduction: Homemade for a Grinder From a Piece of Pipe and Two Bolts
Simple, but at the same time functional homemade product for a grinder. With this device, you can strip a huge number of metal pipes in a short period of time.
Step 1: As a Basis, I Took a Piece of Pipe at 108 Mm.
Step 2: Do the Markup.
Step 3: Cut Off on a Marked Line. This Kind of Blank Is Obtained at This Stage.
Step 4: Now We Take a Profile Pipe 20 * 20 and Cut Off 150 Mm.
Step 5: From a Piece of Metal Strip We Measure Twice 150 Mm Each.
Step 6: Cut and Get the Workpiece.
Step 7: We Make Holes in the Plates, Then the Marking for the Slot.
Step 8: That's How It Turned Out.
Step 9: We Turn on the Welding Machine and Weld a Section of the Profile Pipe to the Main Part.
Step 10: On Each Side of the Pipe We Weld the Plates, It Can Be Painted for Aesthetics.
Step 11: Clamp Our Homemade Product in a Vice, Fix the Grinder With Bolts. As You Understand, the Height Is Adjustable for Different Pipe Diameters.
Step 12: We Connect
We connect the grinder through the speed control. Watch a short video. Anyone who has cleaned the pipe at least once will definitely appreciate the usefulness and effectiveness of this homemade product.
Step 13: Done
Of course, if you need to clean a meter of the pipe, then you can do it in a vice, but if the volume is large, then this homemade product is very useful.
Step 14: Video Version
If you liked this project, then be sure to subscribe to my YouTube channel and check out some of my other Instructables.
