House Shaped Bed (twin)
2,230
37
Introduction: House Shaped Bed (twin)
House shaped twin bed for kids
Mattress size 90x200cm
Made from 21mm plywood (6mm and 18mm plywood for drawers)
Step 1: Material List
  • 6 sheets of 21mm plywood
  • 2 sheets of 6mm plywood
  • some leftovers of 18mm plywood
  • drawer slides
  • dowels
  • screws
  • glue
  • paint
Dimensions can be found at attached sketchup file (was sketched for 18mm plywood, but actually was made of 21mm plywood)
Step 2: Cutting
Cut plywood sheets to size using circular saw
Holes for drawers were cut using jigsaw, then cuts smoothed on router
Step 3: Connections
Almost all parts are connected using dowels and glue to avoid visible screws
Used also screws where they are not visible
Step 4: Frame
Boards for frame are made gluing 4 pieces of plywood together
Everything connected together on dowels/ glue and screws
Step 5: Safety Guards
Approximate cuts for holes were cut using jigsaw, then finished with router/ template
Step 6: Drawers
Drawers made of 18mm plywood (bottom from 6mm plywood)
Fronts are made from 21mm plywood, handles are routed
Step 7: Assembling
Final assembly - parts are glued/ screwed together
I tied it do it so, that there is no any visible screw, but it is still possible to break bed apart if needed
Then painting - I guess hardest part :)
Step 8: Finished
Done!
Furniture Contest 2017
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    • For the Home Contest
