How to Make a Dark Sensor
Introduction: How to Make a Dark Sensor
About: I was 13 when I made this account so please don't make fun of my username
Hey guys ,
In this project I am going to show you how to make a dark sensor using a single transistor and some few resistors in just 3 simple steps .
here is my video this is my old dark sensor
Step 1: Things You Need
Parts:-
1) 1x BC547 transistor
2) 1x 220 k resistor
3) 1x 330 ohms resistor
4) 1- small perf board
5) 1x led (any colour )
6) wires
7) 9v battery
8) battery clip
9)ldr(light dependent resistor )
Tools:-
1) soldering rod and wire
2) wire stripper
Step 2: Getting Started
solder the transistor on the perf board and solder one wire of the ldr to the emitter and other to the base  , solder the negative wire of the led to the base of the transistor with a 330 ohms resistor and also solder 220k resistor with the one side of the 330 ohms resistor
Step 3: Finishing Touches
I have also used a SPDT switch it is optional I have used to pin headers as the connectors for the power .
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Big and Small Contest
    • For the Home Contest
    28 Comments
    PrathamK5
    PrathamK5
    5 years ago
    For how much time will it glow in total?
    savdd
    savdd
    8 years ago on Introduction
    hey is there a way to make it so that when i hover my hand over it, it will stay on then when i hover over it again, it will turn off. thx
    Pranavthegreat
    Pranavthegreat
    I don't think so you can with just a transitor , you might need a microcontroller and PIR sensor
    Ingenerare
    Ingenerare
    Reply 7 years ago
    A microcontroler with in combination with aLDR will do the job also
    dharmik pater
    dharmik pater
    7 years ago
    When I supply current to the terminal the led starts glowing when there is light in the room and it still glowing after I put my hand on ldr hey please help me please!!!!!!!!!!
    AnindyaG1
    AnindyaG1
    7 years ago
    Nice project.. But led is blinking fast. How can i slow it.?
    its not working the way you said
    its glowing without closing with hand any alternative for this.
    if i use 200k resistor inthe place of 220 k resistor
    and i use 300 ohms resistor in the place of 330 ohms resistor'
    thanks
    thanks
    thanks
    thanks
    Very nice project
    but i want to use a buzzer in the place of led what should i do
    Thxx in advance
    Pranavthegreat
    Pranavthegreat
    just instead of the led replace the buzzer nothing else
    Very nice project
    Thxx in advance
    aaamir2
    aaamir2
    i have a problem.
    i have followed the steps
    but instead of Dark its working as a Light Detector any idea why Thanks
    Pranavthegreat
    Pranavthegreat
    just change reverse the transistor because using this circuit you can make both light as well as dark sensor
    lukeD
    lukeD
    9 years ago on Introduction
    hello, nice ible!
    is there a way to control how much light there is needed to light up the led? i think it would be possible with other resistors, wich one would that be?
    I want it to light up when it is only half dark.
    Pranavthegreat
    Pranavthegreat
    Replace any other resistor instead of 100 k or use a 100k pot so that u can change sensivity of the sensor
    muhammad-zka
    muhammad-zka
    am i able to use it on 12v dc for a smd LED ??? IF SO TEll me about the things needed.
    Pranavthegreat
    Pranavthegreat
    I think so u cant as the the transistor will nt be able to bear that much current
