Introduction: How and What to Salvage From Clothes Dryer (tumble Dryer)
This is my very first instructable!
How and what to salvage from a clothes dryer (tumble dryer).
Hopefully this will be of some use to someone.
Enjoy!
(Please excuse any spelling and grammar mistakes, English is not my first language and also not my home language)
Step 1: Safety
My dad had an old saying: "Using the RIGHT tool/s for the job, not only makes it easier and faster but also SAFER".
Make sure that you disconnect all the power to the clothes dryer (tumble dryer).
Almost all clothes dryers (tumble dryers) have a big starting capacitor.
Discharge this capacitor and any other capacitors before you start cutting, hacking, ect.
Use eye protection!
Get a comfortable seating position that will allow easy access to all sides of the clothes dryer (tumble dryer).
Step 2: Tools
REQUIRED......
1) 3 X different sizes Phillips screwdrivers;
2) 3 X different sizes flat screwdrivers;
3) side cutter;
4) strong plyers;
5) holders to sort wires, screws, parts, etc;
6) safety glasses.
OPTIONAL......
1) Power drill;
2) Power jigsaw.
Step 3: Opening Up.....
Before you do anything.....make sure you buy your wife (or yourself) a new clothes dryer (tumble dryer), before you strip the current one!
Personally I started stripping at the back, bit I guess you could start in the front or back.....
Take photos or write down any and all information (if any) that is located on the back cover, like model number, Watts, Volts, etc. You never know when you might need it....maybe when you want to use the motor for something else.....
Take out all the screws (some might be hidden) from the back cover.
Put them in a container of some sort.
Step 4: Remove the Door
On my model I simply pulled out the plastic cover located on the front of the door (the one you take out to remove debris, dust, etc). I also removed the "filter thing" lacated behind it.
Photo 4 and 5 shows this.
Take out any debris, dirt, etc. you might find and also any seals, rubbers and so on as well.
Photo 9 and 10 shows the screws you need to take out in order to remove the door.
Step 5: Door Switch
The next thing you should remove is the safety switch located in the door.
This is the switch that shuts the dryer off when you open the door to throw in the socks your wife so lovingly washed for you but you ignored the request by her to put it in the dryer with the rest of the washing........
Photo 1 shows the hinge on the left and the switch opposite that on the right.
Photo 2 shows the screws you must remove.
Remove the plate that holds the switch, BUT DO NOT CUT ANY WIRES YET!!!!
You need to note the wires and the connections before you start cutting.
This is only of you would like to use the switches and motor together again....
Step 6: Front "control" Panel
First remove the dial (timer thingy) by pulling it out.
Remove the screws.
You will notice that the front panel does not want to come off.
Do not force it.
You need to take out screws from the back in order to remove the front panel.
see next step.....
Step 7: Removing Screws to Loosen Front Panel.
Photo 1 is from the back of the dryer.
Note the marked screws in photo 2.
I actually had 3 screws, but only 2 is showing in the photo.
Remove the screws and head on back to the front of the dryer.
Gently pull on the front panel (from the top, downwards) to get the panel about halfway out.
Remove any screws (if any) holding buttons, dials or wires to the panel.
Photo 4 and 5 shows the power light and buttons.
The front panel should be completely free and you van remove it.
Again....if you want to use the wires and buttons all together after the strip, note the colors, locations and connections before cutting.
Step 8: Removing Wires From the Back
Photo 1 shows the broad view of photos 2, 3, 4, 5 and 6. Note that I drew a circle in photo 1 to show where the wires are located that I will be removing in photo 2, 3, 4, 5 and 6.
To make things easier, cut all the cable ties (not the wires, if you want to use the entire harness) that is holding the wires to the metal structure of the dryer. This will help when you need to move wires out of the way without cutting tje wires in smaller and useless lengths.
I find ot better to salvage and organise longer lengths of wire than short pieces. But thats just me.....
Start with the plate where the power cable goes into the dryer. this is also the location of the Earth wires (on my model. Note the indicated sticked on the plate)
First undo the screws that holds the small plate to the metal structure of the dryer.
Then remove the Earth wires. You will find lots of them connected to the same connection.
Now remove the main power cable from the plate.
You will now have a nice long wiring harness without any cutoff pieces.
Move the harness (bunch of wires) out of the way while you remove the rest of the wires (Earth wire connected to the element back plate and also the element wires) Both these can be seen in photo 9. Photo 10 is of all the wires removed. I placed the wires on top of the drum towards the front. see photo 10.....
Step 9: Remove the Drum
Photo 1 is more or less what you should be seeing at the moment.
The drum is connected to the heating element that is connected to the heating element back plate.....unscrew the screws as shown in Photo 1 to get to Photo 2.... I circled the screws. Again I could not fit all the screws into that photo.
When all the screws are out, the drum might rotate a bit to the left or to the right. Don't panic! Its not a ghost and not the motor that got power magically.....you actually loosened the drum completely en the movement is due to the tension and or lack thereof between the moter, the belt and the drum.
Photo 3 and 4 shows the belt. Remove it by sliding it towards the front of the dryer (the same location you moved the wires to).
Then pull out the drum from the dryer.
You should be seeing more or less a result as shown in photo 5.
Step 10: The MOTOR!!!!
Remember the part about the CAPACITOR.....?
My capacitor was located on the bottom of the motor with 4 pi s and 2 wires connected to only 2 of the pins.
Don't panic it can be discharged by following the following steps:
1) Take a long screwdriver (must have a rubber or other unconductive handle);
2) Make sure that no part of your body is touching any part of the dryer;
3) While maintaining the above mentioned in point 1 and 2.....simply touch with the screwdriver on both connectors of the capacitor at the same time. In other words....create a short!
You might hear a zap and might even see sparks.
Repeat the above mentioned steps untill no more zap or sparks are heard or seen.
90% of the time, nothing will happen and no charge will be in the capacitor. But never take a chance! You never know when it's your turn to be in the 10%.
Now we can proceed.
Photo 1 shows the motor in the left corner and the wires and belt to the front of the dryer.
If you missed any of the cable ties (like me) cut them and remove the wires and belt.
Photo 3 shows the wires and, buttons, dial, etc removed but still connected to the motor.
This is where you will have to make a choice.....
1) take the motor out with everything connected and keep it like that;
or.....
2) Take photos and notes of the connections and cut the motor wires.....
I went with option 2 because I used the wires, buttons, switches and other stuff in other projects.
Photo 7 shows the motor with the wires cut.
My motor could not be taken out from the inside.
Photos 8 and 9 shows the screws on the bottom of the dryer that you need to remove in order to remove the motor. When removing the last screw, hold the motor with one hand to prevent it from falling and damaging when the last screw is removed.
Photo 10 is of the motor completely removed.
In photo 11 I placed my Zippo (red) in front of the motor to give you an idea of the size of the motor.
Step 11: Removing the Heater Element From the Drum
The front of the drum os where the clothes go in....
The back of the drum is where the element is located.
In the centre of the back of the drum, you will see a white cap with 4 screws and a nut in the centre.
Remove the screws.
The nut was a size 13.
Remove that also.
This all is shown in Photo 1.
After the screws and nut is removed, the heater element plate should slide/fall off from the drum.
Photo 2 shows the nut, plastic cap, washer end bearing.
Photo 3 shows the heater element and I marked the 2 heat sensors with white circles.
Photo 4 and 5 are closeup shots of the sensors.
Remove the sensors.
Step 12: Removing Metal Cone From Drum
On the back of the drum (after you removed the heater element) there is a white almost cone shaped metal/aluminum cover.
This cover is attached to the drum with (yes, you guessed it....pop rivets),
so.....time for the drill...hehehehehe.
I used the number 4 drill bit (metal drill bit).
If your drill has a speed control, set it to low speed. If not....don't be "trigger happy". Go slow and steady.
Drill all the rivets out. Take care with the last rivet....make sure that you have a grip on the cone with one hand, if not, the drill might bite into the cone whe you drill oit the last rivit and the cone might spin and hit you with a sharp edge!
Slow and steady....
Step 13: Salvaged Items.....
Photo 1 shows the wires that you salvaged as well as the dial, buttons, connectors, etc.
Photo 2 shows (I could not get everything into the photo) the wires and also the other parts you salvaged and that you can use in your other projects!
Remember.....you can use a jigsaw to cut the dryer frame into manageable sizes......it is good "sheet metal".
The drum (I will put the instructable for that on tomorrow), I have turned into a mini incinerator, using only a drill and jigsaw.
The motor (I will put the instructable for that on also), I have connected to the power supply and I am planning to use it for polishing/grinding wheel in my workshop.
lots of free stuff!
I hope that my instructable helped one of you.
Sorry for any spelling and grammar mistakes, English is not my first language.
14 Comments
6 years ago on Introduction
Please note that discharging the capacitors is also a bit risky. It will throw a couple of sparks and will weld stuff together. Do not try to short them with your favorite screwdriver. The best way is to find a big resistor that will be able to work with 220V and solder it across the capacitor.
Reply 2 months ago
I'll second the resistor advice... I had a bulging cap ... explode? ... not sure, the top of it blew off and just missed my forehead on its trip across the room ... when I (accidentally) shorted it.
5 years ago
Isn't the capacitor usually a film capacitor? The ones that give a huge spark are the electrolytic ones.
Most of the capacotors I've seen on motors (fans and more...) Are film capacitors that are 1.5 mf or less
Anyway I'm interested in seeing a picture of the capacitor!
Your English was great! Great instructable!
Excellent, thank you for that fresh ideas,
Sometimes the door is made of Pyrex glass, temperature resistant, can be used as a cooking pot,
The iron body is a heavy duty table, for example you can install a grinder at the top.
The stainless-steel drum has a lot of uses, requiring some additional work, from furnaces to auto-vacuum chimney caps. I am preparing an instructable about last one.
6 years ago on Step 13
or just recycle the dryer at the merchant, it can be useful for poor people
6 years ago
some of those components can be sold on eBay. Timers, switches, boards, etc
Let see what happens when .
I love salvaging old parts from large appliances. Great job!
Reply 6 years ago
Thank you sir!
Yes, big appliances are great!
Just a pity they are so scarce here were I live.....
Excellent I have just dismantled a similar piece of white goods. On a point of correction you a re most unlikely to find any Phillips headed screws on this machine, they will ALL be Pozidriv which is cross head in design but has a square section in the centre for positive drive, the tip of the driver is flat and not pointed.. A Phillips screw has a simple cross and the tip of the correct driver is pointed.
Reply 6 years ago
Thank you for the correction!
I did not look closely enough at the screws, simply used a Phillips screwdriver to remove them all, so I assumed they were those kind of screws.
Thanks again for poi ting that out!
Well done, good safety advice throughout, informative images, nice collection of swag at the end- a 10 out of a possible 10 for any Instructable, more so for the first. Looking forward to more of the same caliber.
Reply 6 years ago
Thank you very much for the feedback!
I will be sure to keep all of my instructables up to this standard.
I am glad you enjoyed it!
