Introduction: How to Build the Golden Warrior
This is a basic instruction on how to build the Golden Warrior.
Step 1: The Parts
In order to build this set, you will need the following parts.
Step 2: The Legs
First, you will need to construct the legs, do this two times.
Step 3: Armor of the Legs
Then, snap the pieces of the armor onto the front of the legs.
Step 4: Chestplate
Connect your white core to the golden chestplate
Step 5: Connect the Chestplate
Then, connect the chestplate to the body frame.
Step 6: Connecting the Bottom Limbs
Once you have the legs and body built, connect the legs to body.
Step 7: The Left Arm
Connect the pieces of the arm together. Then, snap the gold pieces onto the left side of the arm.
Step 8: The Right Arm
This has the same process as the other arm but instead connect the gold pieces on the right side.
Step 9: Adding More Limbs
Once you’ve assembled the the arms, connect the arms to the body.
Step 10: The Head
To complete the body of the figure, connect the mask to the green head.
Step 11: The Last Limb
Lastly, connect the head to the body.
Step 12: THE WARRIOR HIMSELF IS ASSEMBLED!
Congratulations! Your Done! Your figure should look like this!
