How to Make Automatic Soap Dispenser - 3D Printed !!
5,596
30
6
Introduction: How to Make Automatic Soap Dispenser - 3D Printed !!
About: I'm maker from Tunisia i love electronics and robotics . i hope you can support and help me through subscribing to the channel : https://www.youtube.com/watch?v=oc4sKT1CVag
Keeping Hands Clean
Handwashing is one of the best ways to protect yourself and your family from getting sick. Learn when and how you should wash your hands to stay healthy. Wash Your Hands Often to Stay Healthy You can help yourself and your loved ones stay healthy by washing your hands often, especially during these key times when you are likely to get and spread germs.
This devise can help the kids or even you wash your hands regularly .
I HOPE YOU WILL ENJOY IT
PS : not that that i need not use battery because it will not last , dont use 9v batt , use a power bank or a wall adapter to make sure its always powered up and ready to use . you can still improve the system , make it smaller or reduce the power with an arduino power sleep mode.
what we need for this project are :
- 3D printed models
-6 jumper wires : 3short
+3 long or just 6 long ones
-usb cable
-arduino uno
-high torque servo motor
-ultra sonic sensor
Step 1: PRINT the Parts
1- print all the parts
i used PLA 35 % infill
, 1.5 wall thickness
, 0.5 nozzel , 100% cooling fan
, no support needed,
note that the gear hole is a bit small so you can heat the part with a lighter then force the servo motor in , dont drill it , we need that tight grip of this to work .
Step 2: GLUE the Parts
As i made the parts easy to glue , now i advise using first super glue then use hot glue of the sides that will give you the best out of the two , for more crazy gluewiness you ca use epoxy.
Step 3: GET Your Parts
The parts are easy to use and can be found every where , and when you get board with this system at some point you can just reuse them in another project.
Step 4: WIRE the System
It's pretty easy to do , if you have no idea on how to just follow the schismatics and please double and triples check before you wire the arduino , any wrong wires and you may burn it.
Step 5: Send the Code
plug the usb and send the code
Step 6: ENJOY
Now enjoy . easy right? told you.
MADE by The Noob Engineer susbcribe to my youtube channel
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Make It Bridge
      Make It Bridge
    6 Comments
    svinoths2000
    svinoths2000
    2 years ago on Introduction
    Sanitizer hight and dimensions...where to buy from sanitizer bottle in this size..please sir reply fast
    kerwil
    kerwil
    2 years ago
    Hey awesome project..I'm new to Arduino and am about to try and make this...Do I simply plug my Arduino into usb and download code straight in from this site or do I have to load it t into Arduino software and then download it. Thanks for your help.
    TN_inventor
    TN_inventor
    Reply 2 years ago
    download the code , open it then send it
    gineslopez
    gineslopez
    3 years ago
    I think that idea of yours is very helpful while we are dealing with the CODVID-19. This project can help a lot of sites that are visited by a lot of people like supernarkets o clinics.
    TN_inventor
    TN_inventor
    Reply 3 years ago
    That was the goal of this project , thanks for passing by :) Have a healthy life.
