Introduction: How to Make a Lebathon!
This is where you'll find all you need to make a lebathon out of K'nex! Its powers:
- Slashers
- Punches
- Tail whips
Enjoy!
Step 1: The Pieces You'll Need...
- Two white rods
- Three yellow rods
- Four grey/white mini rods
- Two red connectors
- Five mini green rods
- Two yellow connectors
- Two grey connectors
- One green connector
Step 2: Starting Off...
Take the two grey connectors and put them together. Then attach the head (a green connector) with a mini green rod. Then attach one of the white/grey mini rods to the body (the two grey connectors that were put together.) and attach a red connector to the white/grey mini rod as shown.
Step 3: Step Two...
Then, on to the red connector, attach a mini green rod onto the red connector and attach another grey/white mini rod onto the red connector as shown.
Step 4: Step Three...
With the green rod in place to connect the pieces together, put a yellow connector onto the mini green rod. Put another green mini rod onto the yellow so that it looks like the picture.
Step 5: Step Four...
Put one of the yellow rods onto the remaining grey bit on the side you're working on for a hind leg, and attach the tail (a yellow rod on the back of the body) to the body.
Step 6: Step Five...
Repeat all of those actions on the other side! There is more steps for that, so don't start working unless you know what you're doing perfectly!
Step 7: Step Six...
Attach a white mini rod on the other front side of the body and put a red connector on the bottom of the white mini rod (front leg).
Step 8: Step Seven...
Put a mini green rod onto the middle bit of the red connector and attach a grey/white mini rod onto the bottom (to finish the front leg.).
Step 9: Step Eight...
Put the yellow connector onto the mini green rod and put a mini green rod on the other side as well.
Step 10: Step Nine...
Add the hind legs (yellow rods) and tail. You're done!
