How to Change Colors Seamlessly in Crochet...Without That Little Bridge!
135,757
141
7
Introduction: How to Change Colors Seamlessly in Crochet...Without That Little Bridge!
About: Creatiknit.com ♥ Knit & Crochet designer ♥ Blogger ♥ Mom ♥ Tea drinker with a flair for all things whimsical & woodland ♥ Hi, I'm Angela, and I am the pattern designer behind CreatiKnit! I remember long ago…
Do you know how to change colors in crochet? If you do, how about seamlessly? This is a really cool trick to add in a new color and make it look perfect!
If you’re familiar with joining in a new color…you know that little bridge you get when normally adding in new color before starting your next stitch?! Well, this gets rid of that and blends in effortlessly with the rest of your stitches!
If you’ve never joined in a new color, then you’ll love this technique to start of learning!
Enjoy the video below, follow the photo tutorial…or both!
Step 1: I Am Going to Work My Next Double Crochet, So Yarn Over With the Yarn You’ve Been Using.
Step 2: Go Through the Stitch As Normal
Step 3: Draw Your Yarn Over Back Through the Stitch, Towards You
Step 4: You Now Have 3 Stitches on Your Hook. Yarn Over Again.
Step 5: Now, Draw Your Yarn Over Back Through Only the First 2 Loops.
Step 6: Here Is Where the Fun Begins!
Normally you would yarn over and draw through these last two loops for a double crochet…
This is the point where you will add in your new yarn color!
Step 7: Loop Your New Yarn Color Over Your Hook!
Step 8: Draw Your New Yarn Color Back Through the Last Two Loops on Your Hook!
Step 9: ​Hold Down Your Old Yarn and New Yarn Taildown in the Back With Your Fingers Until Your Next Double Crochet Is Worked
This will keep your loop from getting loose and loppy! You will weave in these yarn tails into their own color section once finished. You are now prepped to start crocheting in your new yarn color!
Step 10: Continue Crocheting As You Normally Would With Your Awesome New Color!
Step 11: That's It! :D
That’s it! You now know how to join in a new color when crocheting…seamlessly! Yay! May this new learned skill empower you to crochet all you can!
Got questions? Ask away in comments below!
Keep Crocheting!
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
    7 Comments
    Lhairston
    Lhairston
    Question 27 days ago
    This is great instruction for how to add the next color or weave in a new thread, but, I don’t see any response or answer on what to do with the 2 ends and how to work them in. I’d love to know how to incorporate the ends neatly.
    HilaryWelly
    HilaryWelly
    Question 3 years ago on Introduction
    Hi
    Can you explain what you do with the yarn left at the back of the crochet piece. Especially if you are changing yarn every 3 stitches. The back of the piece has short lines going across which looks awful. How do you work each stitch around the 1st colour & then how do you work the stitches around the 2nd colour. So it looks neat both sides. Thanks
    Swtnsassy525
    Swtnsassy525
    3 years ago
    Do you just weave in your ends to finish up?
    BethAnnHall
    BethAnnHall
    4 years ago
    Really cool! I started crocheting in 1971. I should have figured this out already. Lol
    mazzy-m
    mazzy-m
    6 years ago
    That's awesome! Your instructions were wonderfully simple and easy to follow. It's a neat way to keep it from looking horrible when you switch colors. Thumbs up!
    Fluffybunny 13
    Fluffybunny 13
    7 years ago
    thanks for the help my crochet stitches always had a giant bridge.
    Luv2cook74
    Luv2cook74
    7 years ago
    wow, looks easy, thanks for the tutorial
