Introduction: How to Make a Piranha Plant With a Tube
For this Plant you will need
Perler beads:
-Black
-Red
-White
-Dark green
-Bright Green
*Ironing Paper
*Iron
*2 Large Pegboards
*A book or something heavy and flat
*Tweezers *OPTIONAL*
*A green Tube (You can buy this at wal mart for $2.00 CAD or at Micheals Craft shop)
You will need a Ruler or a straight edge!
A piece of paper
Scissors
Hot glue gun
Fake Moss/Or soil which ever you prefer
some Styrofoam plant stuff. (It's green not sure what its called)
Perler beads:
-Black
-Red
-White
-Dark green
-Bright Green
*Ironing Paper
*Iron
*2 Large Pegboards
A piece of paper
Scissors
Hot glue gun
Step 1: How to Make a Piranha Plant With a Tube Part 1
Use the two grids to do out the plant, make sure to put the Arrow under it. This will make it easy to push it down into the foam.
Step 2:
Iron the plant
Step 3: How to Make a Piranha Plant With a Tube Part 3
PLACE THE PLANT UNDER SOMETHING FLAT AND HEAVY SO IT WONT BEND.
Draw a line on the paper, about a half inch thick. Cut it out and glue it around the top of the tube.
Once you have tat glued on, cut around the paper. This is a guide line.
turn the piece of tube you cut off inside out and glue it around the top of the tube.
Step 4:
Fill the tube up with your foam and inset the plant! You can finish it off by applying fake moss around the rough edges where you unevenly cut the tube.
Step 5:
Hot glue fake moss at the bottom to cover up the uneven edges & enjoy your cute room decor.
