Introduction: How to Run Smea's RegionFOUR With Sky3ds Flashcard
regionFOUR is a region free loader for New3DS/New3DSXL/3DS/3DSXL/2DS which currently works on on firmware versions 9.2 and 9.7 this also allows you to bypass mandatory gamecard firmware updates. It currently requires that you own a copy of Cubic Ninja from your region in order to run. In some degree, this regionFOUR is a tool for sky3ds flashcart to fix the limitation of game region locked.
And following is a detailed guide on how to run regionFOUR
Step 1:
Note : Pls assure the sky3ds you used was the latest one with blue button like this one : http://www.modchipwarehouse.com/buy-sky3ds-flashcart-to-play-3ds-games-on-n3ds-v90020-or-any-n3ds-console-p-18.html , supports all latest 3ds games,eshop games and online cards without game slot limited
Step 2:
Go to the get regionFOUR from smealum.net/regionfour/ , section of this page and enter your console’s firmware version.
Step 3:
Hit submit; you should get your very own regionFOUR QR code.
Step 4:
Make sure your 3DS's wifi connection is enabled and connected to the internet (this is important!).
Step 5:
Start CUBIC NINJA on your console, choose "Create", then "QR code", and finally "Scan QR code".
Step 6:
Scan the QR Code. This step might take a couple tries; make sure you fill up as much of your 3DS's screen with the QR code. If scanning the QR code returns to menu with an error, try a few more times.
Step 7:
Follow the on screen instructions. You may choose not to install the exploit to your gamecard's savedata.
Step 8:
Once regionFOUR is ready, you will be prompted to insert your out-of-region gamecard. Simply remove the Cubic Ninja gamecard, insert your gamecard and press START.
Step 9:
OPTIONAL - once the regionFOUR is installed to your gamecard, just go back to the "QR code" menu and it'll run automatically!
