Introduction: How to Use the Wiimote As a Computer Mouse Using Candles As a Sensor!!
This guide will show you how to link up your Wii Remote (Wiimote) to your pc and use it as a mouse!
Step 1: What You Will Need
This is fairly simple to complete and you will only need the following:
-Wiimote
-Bluetooth adapter
-Candles (or sensor bar if you want it to be more accurate, there are several guides on Instructables)
-Suitable Bluetooth drivers (to my knowledge Bluesoleil may not work)
-Winremote (found free from http://onakasuita.org/wii/ )
If you do have the Bluesoleil drivers, you may want to look into WIDCOMM drivers (I use these) from here: http://www.devilived.com/2006/05/02/widcomm_bluetooth_stack_v5012500.html
After you have these, progress to step 2
Step 2: Pairing the Wiimote to the Computer
Connect your bluetooth adapter to the computer and load up your drivers.
1.Use the drivers to search for devices and press 1 and 2 on the Wiimote to try pair to the computer. Make sure the Wiimote does not turn itself off until it has been paired (i.e. press 1 and 2 every now and then)
2. Select the service 'Nintendo RVL-CNT-01' or something similar.
Your Wiimote should light up player one and player two and the drivers should recognise the Wiimote. At this stage, you may want to look into mii downloading from the great program located at http://www.miimall.com/ which allows you to download and upload miis.
Step 3: Open Up Winremote
As previously stated, this can be obtained from http://onakasuita.org/wii/
After loaded up, click options and "cursor ON/OFF"
This should allow the remote to work, sometimes even without the candles but the candles will allow a more steady signal if your bluetooth adapter is far away from the remote. Place the candles appart by about the same as a Wii sensor bar and light them up. Hey presto! It works!
70 Discussions
6 years ago
I know this is really random, but do you play Clash of Clans?
9 years ago on Introduction
Does Winnremote support the plus thing and will that make it more accurate?
If you need help, you can contact us via our contact form at http://www.smoothboard.net/contact or email us directly at admin@smoothboard.net.
Regards,
Boon Jin
13 years ago
I've added to the title that you use the candles as a sensor. It works supposedly, because candles emmit infared light as well as the other visible spectrum of light and its easy just to light a couple up and away you go! I'm considering making a USB powered one so you can use the Wiimote with USB but at the moment I don't have a use for the Wiimote on the computer appart from impressing visitors ;)
i want to hook my laptop up to a bigscreen tv and use it with algodoo.. with either this method or using an ir pen and just setting algodoo to touchscreen. It seems like it would be way more intuitive that way.
hey can you set buttons on the remote to use as buttons on the mouse or keyboard? A and B for left and right click and then the digipad and 1 and 2 for the tools? (keys A and K and Z ect)
You can use Smoothboard's Presenter mode to set the Wiimote's buttons and IR sensor to control the mouse and keyboard.
Regards,
Boon Jin
Reply 13 years ago
I like to play emulator games with my wiimote, but I use glovePIE instead of winremote.
Reply 13 years ago
Quite true! You can use glovePIE (http://carl.kenner.googlepages.com/glovepie_download) but I haven't found out how to use it just yet!
Reply 13 years ago
There's some great documentation on it right here.
The biggest difference is that Winremote can take care of your basic button=key stuff and has a mouse driver built right in. It has a better GUI and you can calibrate your wiimote when you use it.
I recommend starting off with Wiinremote and then eventually moving on to Glovepie.
GlovePIE is better if you wanna do more advanced stuff, like use the accelerometers for anything like steering a car, or using the status LEDs. Its GUI is pretty much a "run" button and a text field. You have to write a script to use it, but they can be so simple. They are mostly if, then, else statements and equals signs.
11 years ago on Introduction
I heard of another software called GlovePIE through PCGamer. Will this work?
glovePIE will work, you can make scripts to play games with the wiimote with it.
13 years ago
Just to let everyone know, I'm planning on making a usb-powered sensor bar, may be a while until I get the LEDs however.
Reply 13 years ago on Introduction
I know that Radio Shack sells IR LEDs, if that helps at all. I almost made a USB-powered sensor bar, but I couldn't find an extra USB cable anywhere, so I just went with AAs.
Unfortunately there are no radio shacks around here (in the UK) but also I've had to abandon the project - my cars service cost nearly £1k so I had to sell my wii to pay for it :(
go to maplin
Reply 12 years ago on Introduction
hey, do what i did, 1. get another sensor bar, so you dont void you wii's warrenty (got mine of ebay) 2. get a usb 1.1 plug (maplins) 3. research on usb power 4. solder the wires. only reason my didnt work is because i soldered my wires in the wrong place
Reply 11 years ago on Introduction
you could get one of the wireless wii sensor bars.
You can always get a wireless sensorbar from amazon (i got one for 11 quid) they use batteries
ur from ireland aren't u? thats the only place i've ever seen a maplin electronics store.
