Introduction: (IOT Project) Get Weather Data Using ESP8266 and Openweather API
In this instructable we are going to build a simple IOT project in which fetch the weather data of our city from openweather.com/api and display it using Processing software.
- Arduino
- ESP8266 or any other esp module
- Arduino IDE
- Processing software
- Breadboard
- Jumperwires Male to Male and Male to Female
Step 1: Obtain API Key and URL From Openweather.org
- Create account in https://openweathermap.org (Image 1)
- After you login go to API keys and you will get the API key as shown in image.(Image 2)
- Copy the API key and save it in a notepad file.(Image 3)
- Go to the API option (Image 4)
- Go to API doc option as shown in image (Image 5)
- Copy the url from the and shown and save it in a notepad file (Image 6)
Step 2: Connection Diagram
Step 3: Arduino Code
Before copying this code into Arduino make sure you have downloaded ESP8266 board into arduino ide using Boards manager.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <Arduino_JSON.h>
const char* ssid = "Your SSID";
const char* password = "Your SSID PASSWORD";// Your Domain name with URL path or IP address with path
String openWeatherMapApiKey = "Paste your API key here";
// Replace with your country code and city
String city = "Mumbai";
String countryCode = "IN";
String data[16];
// THE DEFAULT TIMER IS SET TO 10 SECONDS FOR TESTING PURPOSES
// For a final application, check the API call limits per hour/minute to avoid getting blocked/banned
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 10 seconds (10000)
unsigned long timerDelay = 10000;
String jsonBuffer;
void setup() {
Serial.begin(115200);
WiFi.begin(ssid, password);
//Serial.println("Connecting");
while(WiFi.status() != WL_CONNECTED) {
delay(500);
// Serial.print(".");
// Serial.println("");
// Serial.print("Connected to WiFi network with IP Address: ");
// Serial.println(WiFi.localIP());
// Serial.println("Timer set to 10 seconds (timerDelay variable), it will take 10 seconds before publishing the first reading.");
void loop() {
// Send an HTTP GET request
if ((millis() - lastTime) > timerDelay) {
// Check WiFi connection status
if(WiFi.status()== WL_CONNECTED){
String serverPath = "http://api.openweathermap.org/data/2.5/weather?q=" + city + "," + countryCode + "&APPID=" + openWeatherMapApiKey + "&units=metric";
jsonBuffer = httpGETRequest(serverPath.c_str());
//Serial.println(jsonBuffer);
JSONVar myObject = JSON.parse(jsonBuffer);
// JSON.typeof(jsonVar) can be used to get the type of the var
if (JSON.typeof(myObject) == "undefined") {
//Serial.println("Parsing input failed!");
return;
// Serial.print("JSON object = ");
// Serial.println(myObject);
// Serial.print("Temperature: ");
// Serial.println(myObject["main"]["temp"]);
// Serial.print("Pressure: ");
// Serial.println(myObject["main"]["pressure"]);
// Serial.print("Humidity: ");
// Serial.println(myObject["main"]["humidity"]);
// Serial.print("Wind Speed: ");
// Serial.println(myObject["wind"]["speed"]);
int temp = myObject["main"]["temp"];
long pres = myObject["main"]["pressure"];
int humid = myObject["main"]["humidity"];
int wind = myObject["wind"]["speed"];
String country = JSON.stringify(myObject["sys"]["country"]);
String city1 = JSON.stringify(myObject["name"]);
String weather = JSON.stringify(myObject["weather"][0]["description"]);
String icon = JSON.stringify(myObject["weather"][0]["icon"]);
data[0]= String(temp);
data[1]= "/";
data[2]= String(pres);
data[3]= "/";
data[4]= String(humid);
data[5]= "/";
data[6]= String(wind);
data[7]= "/";
data[8]= country;
data[9]= "/";
data[10]= city1;
data[11]= "/";
data[12]= weather;
data[13]= "/";
data[14]= icon;
data[15]= "\n";
for(int i=0;i<=15;i++){
Serial.print(data[i]);
else {
//Serial.println("WiFi Disconnected");
lastTime = millis();
String httpGETRequest(const char* serverName) {
HTTPClient http;
// Your IP address with path or Domain name with URL path
http.begin(serverName);
// Send HTTP POST request
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode>0) {
// Serial.print("HTTP Response code: ");
// Serial.println(httpResponseCode);
payload = http.getString();
else {
Serial.print("Error code: ");
// Free resources
http.end();
return payload;
} Step 4: Processing Code
Before running this code download the given icon images which will be used to show weather. And keep the images and code in the same folder.
import processing.serial.*;
Serial myPort;
PImage img;
PImage img2;
PImage img3;
PImage img4;
PImage img5;
PImage img6;
PImage img7;
PImage img8;
PImage img9;
PImage img10;
PImage img11;
PImage img12;
PImage img13;
PImage img14;
PImage img15;
PImage img16;
PImage img17;
PImage img18;
int temp;
int pres;
int humid;
int wind;
String city = " ";
String country = " ";
String weather =" ";
String icon = " ";
void setup(){
size(500,500);
myPort = new Serial(this,"COM3",115200);
img = loadImage("01d.png");
img2 = loadImage("01n.png");
img3 = loadImage("02d.png");
img4 = loadImage("02n.png");
img5 = loadImage("03d.png");
img6 = loadImage("03n.png");
img7 = loadImage("04d.png");
img8 = loadImage("04n.png");
img9 = loadImage("09d.png");
img10 = loadImage("09n.png");
img11 = loadImage("10d.png");
img12 = loadImage("10n.png");
img13 = loadImage("11d.png");
img14 = loadImage("11n.png");
img15 = loadImage("13d.png");
img16 = loadImage("13n.png");
img17 = loadImage("50d.png");
img18 = loadImage("50n.png");
void draw(){
background(72,209,204);
textSize(22);
fill(54, 69, 79);
text("Temperature: ",25,100);
text(temp +"°C",200,100);
text("Pressure:",25,150);
text(pres + " hpa",200,150);
text("Humidity: ",25,200);
text(humid+" %",200,200);
text("Wind: ",25,250);
text(wind+" m/s",200,250);
text("Country/City: ",25,300);
text(country +"-"+ city,200,300);
text("Weather: ",25,350);
text(weather,200,350);
if(icon.contains("01d")){
image(img, 380, 15);
else if(icon.contains("01n")){
image(img2, 380, 15);
else if(icon.contains("02d")){
image(img3, 380, 15);
else if(icon.contains("02n")){
image(img4, 380, 15);
else if(icon.contains("03d")){
image(img5, 380, 15);
else if(icon.contains("03n")){
image(img6, 380, 15);
else if(icon.contains("04d")){
image(img7, 380, 15);
else if(icon.contains("04n")){
image(img8, 380, 15);
else if(icon.contains("09d")){
image(img9, 380, 15);
else if(icon.contains("09n")){
image(img10, 380, 15);
else if(icon.contains("10d")){
image(img11, 380, 15);
else if(icon.contains("10n")){
image(img12, 380, 15);
else if(icon.contains("11d")){
image(img13, 380, 15);
else if(icon.contains("11n")){
image(img14, 380, 15);
else if(icon == "13d"){
image(img15, 380, 15);
else if(icon.contains("13n")){
image(img16, 380, 15);
else if(icon.contains("50d")){
image(img17, 380, 15);
else if(icon.contains( "50n")){
image(img18, 380, 15);
void serialEvent(Serial myPort){
if (myPort.available() > 0){
String data = myPort.readStringUntil('\n');
if(data != null){
data = trim(data);
String items[] = split(data, '/');
if (items.length > 1) {
temp = int(items[0]);
pres = int(items[1]);
humid = int(items[2]);
wind = int(items[3]);
city = items[4].replace("\"","");
country = items[5].replace("\"","");
weather = items[6].replace("\"","");
icon = items[7].replace("\"","");
}<strong>
<br></strong>
