Introduction: Improving Efficiency: Relation Orientation & Speed in 3D Printing. I Made It at TechShop.
Background:
There are many way to speed up 3D Printing. One is to make percent fill less. Normally, users don't use 100% fill. Normally, they range from 10% to 50%. However, in some applications changing of percent fill might not be an option. Or we keep everything the same, what else is possible to speed up the 3D printing.
Goal:
To verify an hypothesis on improving 3D printing speed. To measure the speed up based on a simple shape.
Discussion:
The hypothesis is not meant to include all possible shapes. If a part is largely rectangular, having one motor move from left to right of the bed might be slower to go from one end to another. If we place a part at 45-deg, how much speed up could we gain?
A cylindrical or flower base shape would likely not have any significant effect.
During our discussion, my friend at TechShop brought out a good point. What if the extruder speed is the critical factor? This could be very true.
So to quickly check out this hypothesis, I decided to conduct a test.
If anyone know other related study, please share. Thank you very much.
My test samples would 5" long x 1" width x 0.25" thickness. Due to limited material, I could only use 10% fill.and run maximum 6 tests. 10% is most common used so I think it is best to use this. I would rotate the part 45-deg along the vertical. I would also rotate it about the X + 45-deg about the vertical.
Due to limited time on 3D Printer at the Shop, I would gradually update the result. I am updating the 6 alignment configuration.. In Autodesk, we only need to make 1 file. The rotation could be done on MakerBot.
Configurations are the following:
(1) 5" along X
(2) 5" along X sideway
(3) 5" along Y
(4) 5" along Y sideway
(5) 45-deg
(6) 45-deg sideway
Conclusion:
Since the test is very simplified. No conclusion could be derived from the above exercise. Only conclusion could be if the orientation affect the printing speed.
DIsclaimer:
This test is based on simple shape and 10% filled. This test is based only on one simple case. No generation should be derived from it without conducting a well planned DOE.
I did not try to search if this test has been done in the past and analyze all factors in depth. I simply conduct this simple and likely unscientific tests.
Goal:
Discussion:
(1) 5" along X
(3) 5" along Y
(5) 45-deg
(6) 45-deg sideway
Conclusion:
DIsclaimer:
