Introduction: Indestructable Safe
Ever wanted to have a child proof, bullet proof, and knife proof, safe to hold money or priceless items? Just make one! :)
Step 1: Materials
welder
6 pieces of 3" steel (whatever length you decide)
2 construction grade hinges
1 lock (ex: child proof gun lock)
1 drill
1 drill bit (size of lock diameter and able to drill through the steel)
welding safety gear
4 screws (shorter than thickness of the steel)
2 clamps
1 drill
welding safety gear
2 clamps
Step 2: Clamp!
clamp 4 pieces of steel together to weld. The fifth piece is to be welded after the clamped pieces are all welded together to form a four sided figure.
Step 3: Weld!
weld 5 pieces of steel together to let the 6th piece stay free so you can drill the hinges on.
Step 4: Drill!
screw the 2 hinges on. This will be your entry to the safe. Then drill 2 holes close to eachother (make sure one of the holes are drilled into one of the stationary pieces of steel). Feed the lock into the holes.
Step 5: Finished!
you should have a safe that you made yourself. please vote for the contest i entered and comment if any questions or concerns. :)
