Instructables - INVENTING SOMETHING TO DO WITH a OLD TRUNK IN THE BACKYARD
Introduction: Instructables - INVENTING SOMETHING TO DO WITH a OLD TRUNK IN THE BACKYARD
About: English is not my first language. I use Google Translator and patience of friends to write Instructables. Feel free to point out style, syntax or grammatical errors. Actually I work in TECHSHOP Menlo Park CA …
I have an old trunk in my backyard
The trunk is 18 ft height and the diameter at the top is 2.8 ft
Step 1:
I think I am obsessed with the geometry of truncated Icosahedron
(These and all others Platonics and Archimedians geometric solids)
but for this project, I will built a regular geodesic sphere
On the top  of a tree trunk in my backyard
before I do the real one, i decided it is better to make a prototype.  (I know all implications that occur when you scale a model or make with different materials :)
Dimensions for the real sphere:
To build a sphere with a radius of 4.25 feet requires:
70 Struts 2.63 feet each bend angle 18o
60 Struts 2.32 feet each bend angle 16o
52 Bolts, 52 Nuts, & 104 Washers
Originally I was at Safeway and bought 2 boxes of 100 straws for $3.99
Then I calculated the size of the straws based on the maximum possible length of the straw (5.5 inches)
Dimension for the model
The maximum possible size of the straw was 5.5 inches:
70 Struts 5.5 inches each
60 Struts 4.8 inches each
52 Bolts, 52 Nuts
model trunk diameter 5.99 inches
model trunk height 37 inches
Step 2:
The first step was to cut 70 straws (Struts) with 5.5 inches each and cut 60 straws (Struts) with 4.8 inches each. I made a small device to guarantee all cuts were the same without needing to measure one by one. I used a heavy trunk and a side of a table as a reference to cut.  I measured one time only, the heavy trunk did not move, so, all subsequent cuts are the same. (this technique guarantees the quality of the production process)
Step 3:
I bent and made holes in both sides of all 130 straws
Step 4:
I assembled the first pentagon with the short straws (4.8”) inside and the long straws (5.5”) outside.
Step 5:
I then assembled 11 other pentagons (total 12 pentagons) all the same.
Step 6:
The first assembly step was, in each vertices of the pentagon, I attached another vertices of another pentagon
Step 7:
I then attached the sides of the all pentagons
Step 8:
By repeating this operation again and you will have two half spheres ready to be connected.
Step 9:
Connect the 2 vertices of each pentagon with the 2 other vertices of  the other 2 pentagons
I made it at Techshop
Step 10:
after that I got a piece of a tree trunk (diameter 5.99 inches and 37 inches in length)
Step 11:
I tied the geodesic sphere to the trunk
To mock the final product of this Intructable
Step 12:
Once the prototype showed satisfactory structure and stability, I decided to go for the real project
Step 13: End of SubInstructables - BUILDING a SPHERICAL MODEL FOR STUDY
Step 14:
To make a quick test on the real size, I was at home depot and bought 5 pieces of 10 foot ¾ EMT Conduit
Step 15:
After that I made 3 cuts in each. Two cuts with 2.63 feet (2” 7’ ½) and one with 2.32. (2” 3’ ¾) the result was 4 struts, 2 with 2.63 feet and 2 with 2.32 feet
Step 16:
Filed the ends
Step 17:
then bent all ends
Step 18:
then, I punctured to make a hole in each end
Step 19:
I made a 25/64 diameter hole in each end
Step 20:
After that I bent all ends with a angle of 18 degrees for the long ones and 16 degrees for the short ones
Step 21:
with all struts, bolts, washers and nuts ready, I started the assembly of one pentagon to check the overall process
Step 22:
Looks good
The next step was to buy 28 pieces of  10 foot ¾ EMT Conduit and make 11 more pentagons a total of 12 pentagons
About 320 feet of conduit ¾ 10’ (1408 Lbs ~ 700 kg)
As you can see, I made it at Techshop
Step 23:
The only step I feel deserves a comment in this part of the process was when I took all the remaining pieces,
with the support of the Dream Consultant of Techshop to help me find a better way  to quickly band the pieces to the correct angle
Step 24:
Then I assembled the 2 half spheres
(see the video Instructable - Geodesic Sphere)
Step 25:
and put the two halves together to make my geodesic sphere
Step 26:
Then I drove home with my sphere safely tied to the bed of my truck
Step 27:
After 1 day I revised all plans including the detailed process to assemble the Geodesic Sphere in the top of the tree trunk, after all that, I discovered that the tree trunk did not reside on my property  :((
it was a bitter discovery,
well, anyway, never give up
any suggestions as to what I can do with my sphere?
be nice :)
Be the First to Share
    • Cheese Challenge
      Cheese Challenge
    • Fandom Contest
      Fandom Contest
    • Teach With Tinkercad Contest
    17 Comments
    GregoriNiculitcheff
    GregoriNiculitcheff
    Very good idea, I will decide in 2 or 3 weeks and do it :)
    thanks for the suggestion :)
    Efitall
    Efitall
    10 years ago on Step 27
    It's plenty large enough to turn into a small chicken coup, though access might be a bit of an issue. could also add thin plexi or clear heavy-duty plastic and make a sort of temporary greenhouse.
    Personally, I'd suspend a light-weight medium (like bark from the stump) in the center and grow air plants inside (epiphyte). The sphere is open and airy and almost fantastical, so "floating" plants hanging out in there seems quite fitting to me.
    rangerweavere
    rangerweavere
    Dig up the root structure of the trunk and move it onto your property.......
    GregoriNiculitcheff
    GregoriNiculitcheff
    .....ahahah....
    I have 2 other trunk in my property suitable to do it but...
    the enchantment was broken
    that sphere was born for that trunk
    no other trunk will feet
    she need find a new path in her life
    may be a room or a chicken house
    the sphere now need a new destiny
    fungus amungus
    Is the trunk's property owner friendly? Worth a shot to talk to 'em.
    GregoriNiculitcheff
    GregoriNiculitcheff
    Is property of CalTrans, probably I am out of the game ...ahahah...
    but I am waiting suggestion (nice ones) about what to do with this sphere :)
    fungus amungus
    fungus amungus
    They'll never know! Looks like the land is not commonly accessed at all.
    GregoriNiculitcheff
    GregoriNiculitcheff
    If I don't receive any interesting idea, I will finish doing the original idea :)
    omnibot
    omnibot
    Well, that's no problem then. Just mount it and stamp part of it with an arbitrary letter/number-combination and if anyone ever asks just tell'em you have no idea what it's for. A bunch of army guys showed up one day and set it up. Now it's a government truncated Icosahedron.
    Nerdz
    Nerdz
    This is just Full of awesome.
    Hmm, Hang battery powered LEDs from it and make it glow at night? Would look quiet spooky in the middle of the forest just glowing. Would look good glowing green-Fake UFO? Or RGB LED's
    Or small tealight Candles
    Im sure Im not the only one who thought this looked like Wardenclyffe Tower (the top)
    it looks like your backyard is full of lavender or something.
    BrefelanDesigns
    BrefelanDesigns
    I think you might just be on to something about Wardenclyffe..... too bad the tower was demolished before it was ever operational... It would have been Tesla's legacy... hmm I know a few years ago the land and the few buildings still left were up for sale... maybe if it hasn't sold someone could re-create the tower and light it up.... and make it a museum....
