Introduction: Interactive Laser Sheet Generator With Arduino
Lasers can be used to create incredible visual effects. In this project, I constructed a new type of laser display that is interactive and plays music. The device rotates two lasers to form two vortex-like sheets of light. I included distance sensors in the device so that the laser sheets could be manipulated by moving your hand towards them. As the person interacts with the sensors, the device also plays music through a MIDI output. It incorporates ideas from laser harps, laser vortexes, and POV displays.
The instrument is controlled with an Arduino Mega that takes in the inputs of ultrasonic sensors and outputs the type of laser sheet formed and music generated. Due to the many degrees of freedom of the spinning lasers, there are tons of different laser sheet patterns that can be created.
I did preliminary brainstorming on the project with a new art/tech group in St. Louis called Dodo Flock. Emre Sarbek also ran some initial tests on the sensors used to detect motion near the device.
If you construct a laser sheet device, please remember to be safe operating lasers and spinning discs.
2020 update: I realized the surface created with the lasers is a hyperboloid.
Step 1: Supply List
Materials
Lasers - https://www.amazon.com/gp/product/B01ITK4PEO/ref=o...
Brushless motor - https://www.amazon.com/gp/product/B01MAUFDHW/ref=o...
Electronic speed controller - https://www.amazon.com/gp/product/B00M90WWNC/ref=o...
Servo motors - https://www.amazon.com/gp/product/B015H5AVZG/ref=o...
Transistors
Plywood
Plexiglass
Ultrasonic sensors
Slipring - https://www.amazon.com/gp/product/B01N74WFJA/ref=o...
White LEDs - https://www.amazon.com/gp/product/B005ONQ41W/ref=o...
Buck converters
Wire wrap wire
MIDI connector
Potentiometer and knobs - https://www.amazon.com/gp/product/B00NN6M1V4/ref=o...
Hardware - https://www.amazon.com/gp/product/B01J7IUBG8/ref=o...https://www.amazon.com/gp/product/B06WLMQZ5N/ref=o...https://www.amazon.com/gp/product/B06XQMBDMX/ref=o...
Resistors
JST connector cables - https://www.amazon.com/gp/product/B01AHK50TS/ref=o...
AC power switch
12V Power supply - https://www.amazon.com/gp/product/B019OJSKP4/ref=o...
Wood glue
Super glue
Wood screws
USB extension cable - https://www.amazon.com/gp/product/B002M8VBIS/ref=o...
Tools:
Soldering iron
Wire cutters
Jig saw
Circular saw
Micrometer
Power drill
Step 2: Overview and Schematic
A laser beam creates a well collimated (i.e. narrow) beam of light, so one way to produce a sheet of light is to quickly move the beam in some pattern. For example, to create a cylindrical light sheet, you would rotate a laser around an axis parallel to the direction it is pointing. To quickly move a laser, you can attached a laser to a wooden plank attached to a brushless DC motor. With this alone, you can create cool cylindrical laser vortexes!
Other laser vortex projects accomplish this by mounting a tilted mirror at the axis of rotation with a stationary laser directed to the mirror. This creates a laser sheet cone. However, with this design, all laser sheets will appear to originate from a single origin. If the lasers are positioned off axis like with the design I built, you are able to create converging laser sheets, like the hourglass shape shown in the video.
But what if you wanted the light sheets to be dynamic and interactive? To accomplish this, I attached two lasers onto servos and then attached the servos onto the wooden plank. Now the servos can adjust the angle of the laser with respect to the motor’s axis of rotation. By having two lasers on two different servos, you can created two different light sheets with the device.
In order to control the speed of the DC motor, I connected a potentiometer to an Arduino that takes the potenometer’s input and outputs a signal to the electrical speed controller (ESC). The ESC then controls the speed of the motor (a rather appropriate name, yes), depending on the potentiometer’s resistance.
The laser’s on/off state is controlled by connecting them to the emitter of a transistor operating in saturation (i.e. operating as an electric switch). A control signal is sent to the base of the transistor which controls the current through the laser. Here is a source for controlling a load with a transistor with an arduino: https://teachmetomake.wordpress.com/how-to-use-a-...
The servos position is also controlled with the Arduino. As the plank rotates, the light sheet can be manipulated by changing the servo position. Without any user input, this alone can create dynamic light sheets that are mesmerizing. There are also ultrasonic sensors positioned around the edge of the device, that are used to determine if a person is putting her hand close to the light sheets. This input is then used to either move the lasers to create new light sheets OR generate a MIDI signal. A MIDI jack is connected to transmit the MIDI signal to a MIDI playing device.
Step 3: Controlling Brushless Motor With Arduino
In order to create vortex-like light sheets, you need to rotate the laser beam. To accomplish this, I decided to try to use a brushless DC motor. I learned that these types of motors are really popular with model airplanes and drones, so I figured that it would be pretty easy to use. I ran into a few snags along the way, but overall I am happy with how the motor works for the project.
First, the motor needs to be mounted. I custom designed a part to hold the motor and attach it to a board holding the device. After the motor was secure, I connected the motor to the ESC. From what I read, it sounds really tough to use a brushless motor without one. To make the motor spin, I used an Arduino Mega. Initially, I could not get the motor to spin because I was just connecting the control signal to 5V or ground, without properly setting a baseline value or calibrating the ESC. I then followed an Arduino tutorial with a potentiometer and servo motor, and that got the motor spinning! Here is a link to the tutorial: https://www.arduino.cc/en/Tutorial/Knob
The ESC wires can actually be connected in any way to the brushless motor. You will need some female banana plug connectors. The thicker red and black cables on the ESC are connected to a DC power supply at 12V, and the black and white cables on the control connector of ESC are connected to ground and a control pin on the Arduino, respectively. Check out this video to learn how to calibrate the ESC: https://www.youtube.com/watch?v=F0Fx0NwYUis
Step 4: Constructing the Laser Sheet Chassis
After getting the motor spinning, it is time to build up the light sheet chassis. I cut a piece of plywood using a CNC machine, but you can also use a jig saw. The plywood holds the ultrasonic sensors and has a hole in it to fit a piece of plexiglas. The plexiglas should be attached to the wood using epoxy. Holes are drilled for the slip-ring to fit through.
Another circular sheet of plywood is then cut to hold the brushless motor. In this sheet of wood, holes are drilled so that wires can go through later in the construction. After attaching the motor mount and drilling holes, the two sheets of plywood are attached by 1x3 planks cut about 15cm long and metal brackets. In the photo, you can see how the plexiglas is above the motor and the lasers.
Step 5: Laser and Servo Motor Assembly
The variable light sheets are created by moving lasers with respect to the axis of rotation. I designed and 3d printed a mount that attaches a laser to a servo and a mount that connects the servo to the spinning plank. First attach the servo to the servo mount using two M2 screws. Then, slide a M2 nut into the laser mount, and tighten a set screw to keep the laser in place. Before connecting the laser to the servo, you must make sure that the servo is rotated to its centered operating position. Using the servo tutorial, direct the servo to 90degrees. Then mount the laser as shown in the picture using a screw. I had to also add a dab of glue to ensure that the laser did not shift unintentionally.
I used a laser cutter to create the plank, which has dimensions of around 3cm x 20cm. The maximum size of the light sheet will depend on the size of the wooden plank. A hole was then drilled in the center of the plank so that it fits onto the brushless motor shaft.
Next I glued the laser-servo assembly onto the plank so that the lasers were centered. Make sure that all components on the plank are balanced with respect to the plank’s axis of rotation. Solder JST connecters to the lasers and servo cables so that they can be connected to the slipring in the next step.
Finally attach the plank with attached laser-servo assemblies onto the brushless motor with a washer and nut. At this point, test the brushless motor to make sure that the plank can spin. Be careful not to drive the motor too fast or put your hand in the path of plank’s rotation.
Step 6: Installing the Slipring
How do you prevent the wires from getting tangled as the electronics spin? One way is to use a battery for a power supply and connect it to the spinning assembly, like in this POV instructable. Another way is to use a slipring! If you haven’t heard of a slingring or used one before, check out this great video that demonstrates how it works.
First, attach the other ends of the JST connectors to the slipring. You don’t want the wires to be too long because there is potential for them to get caught on something when the plank rotates. I attached the slipring to the plexiglass above the brushless motor be drilling in holes for screws. Be careful not to crack the plexiglass when drilling. You can also use a laser cutter to get more precise holes. Once the slipring is attached, connect the connectors.
At this point, you can connect the slipring wires to pins of an Arduino to do some preliminary tests with the laser sheet generator.
Step 7: Soldering the Electronics
I cut a prototype board to connect all the electronics. Because I used a 12V power supply, I need to use two dc-dc converters: 5V for the lasers, servos, potentiometer, and MIDI jack, and 9V for the Arduino. Everything was connected as shown the diagram by either soldering or wire wrapping. The board was then connected to a 3d printed part using PCD standoffs.
Step 8: Constructing the Electronics Box
All the electronics are housed in a wooden box. I cut 1x3 lumber for the sides of the box, and cut a large opening in one side so that the wires on a control panel could go through. The sides were connected using small blocks of wood, wood glue, and screws. After the glue dried, I sanded down the sides of the box to even out all imperfections in the box. Then I cut thin wood for the front, back, and bottom of the box. The bottom was nailed to the sides, and the front and back were glued onto the box. Finally, I measured and cut holes the dimensions of the components on the front panel of the box: the power cable jack, usb jack, MIDI jack, and potentiometer.
Step 9: Installing Electronics in the Box
I attached the power supply to the box using screws, the Arduino using a custom designed mount, and the circuit board created in Step 7. The potentiometer and MIDI jack were first connected to the circuit board using wire wrapping wire, and then glued to the front panel. The AC jack was connected to the power supply, and the DC output of the power supply was connected to the inputs of the Buck converters and cables that connect to the brushless motor. The motor, servo, and laser wires are then run through a hole in the plywood down to the electronics box. Before dealing with the ultrasonic sensors, I tested components individually to make sure that everything was wired correctly.
I initially purchased an AC power jack, but read some pretty bad reviews of it melting so I had incorrectly sized holes on the front panel. Therefore, I designed and 3d printed some jack adapters to match the size of the holes I cut.
Step 10: Mounting and Wiring the Ultrasonic Sensors
At this point, the lasers, servos, brushless motor, and MIDI jack are all connected to and can be controlled by the Arduino. The last hardware step is connecting the ultrasonic sensors. I designed and 3d printed an ultrasonic sensor. I then wired and evenly attached the ultrasonic sensor assemblies to the top plywood sheet of the light sheet generator. The wire wrap wire were run down to the electronics box by drilling holes in the plywood sheet. I connected the wire wrap to the appropriate pins on the Arduino.
I was a little disappointed with the ultrasonic sensor performance. They worked pretty well for distances between 1cm - 30cm, but the distance measurement is very noisy outside that range. To improve the signal to noise ratio, I tried taking the median or average of several measurements. However, the signal was still not dependable enough, so I ended up setting the cut-off for playing a note or changing the laser sheet at 25cm.
Step 11: Programming the Dynamic Laser Vortex
After all the wiring and assembly is completed, it is time to program the light sheet device! There are many possibilities, but the overall idea is to take in the inputs of the ultrasonic sensors and send out signals for MIDI and controlling the lasers and servos. In all programs, the plank’s rotation is controlled by turning the potentiometer knob.
You will need two libraries: NewPing and MIDI
Attached is the full Arduino code.
Second Prize in the
Invention Challenge 2017
16 Comments
3 years ago
really cool project would love to try this sometime.
5 years ago
thank you so much I always wanted to make something like a slipring but never got success
5 years ago
Another great project, Jon! I'm fascinated by the slipring. Where did you get yours? Could you share a link?
Reply 5 years ago
Thanks, Donald! The slipring is really neat part. I just purchased one from Amazon: https://www.amazon.com/gp/product/B01N74WFJA/ref=o...
Reply 5 years ago
hahaha big brother !!! clicking this link not only shows the slip ring but nearly the full BoM in section "Customers who viewed this item also viewed"
cool 'ible ... stunning project
for people who can't read code, could you explain in 1-2 sentences what the LSG can do with MIDI and how it reacts on the sensors?
Reply 5 years ago
Wow, that is bizarre, thanks for pointing that out!
The LSG (nice acronym) can be programmed to produce any MIDI signal, thanks to the awesome MIDI library I mention in the instructable. I programmed it to read in all the sensor info to see if an object is within 15cm of the sensor. For each sensor blocked, it plays an arpeggio with different root note.
Reply 5 years ago
Perfect. Thanks Jon.
Reply 5 years ago
Reply 5 years ago
The slip rings are also available at www.mcmelectronics.com
5 years ago
hello, thank you for your project, this is inspiring.
Why do you use the combination brushless motor/ESC ? Could I replace it by a DC brushed motor?
Reply 5 years ago
Thanks! I used a brushless motor because I had heard about them and wanted to try one out. You can definitely replace it with a DC brushed motor that has enough torque. Instead of the ESC, you will use a MOSFET to control the speed of the motor with the Arduino. Attached is a picture from the Arduino starter kit of what the circuit would roughly look like. Replace the switch with a potentiometer.
5 years ago
It's spectacular!
5 years ago
Excellent!!! My question is, what made you decide to build it? Also, what shop do you have available?
Reply 5 years ago
Thank you for your note! I decided to build it because I wanted to create a new take on the laser harp. I also wanted to learn how to use a brushless motor and how to deal with spinning electronics. I don't have a shop, but your question makes me want to start one.
5 years ago
Amazing work! Thanks for your continued work, the beautiful presentation, and the detail you put into your instructables!
Reply 5 years ago
Thanks a lot, enaselim!
