Iron Man Earpiece ( How to Make ) One Easy Option.
Introduction: Iron Man Earpiece ( How to Make ) One Easy Option.
When I started building the Iron Man helmet , I had great difficulty on making the earpiece.After a few mistakes and hours of sanding, I had an idea that works quite ok for me.
Step 1: The Material Needed:
01craft stick
40ml of polyester resin
01 spray can cap
01 plastic cup
Step 2: Let's Start!
First in a plastic cup we are going to add about 40ml of polyester resin.
Normally I put 10 drops of catalyst to accelerate the hardening process.
Step 3: Pouring the Resin Into the Spray Cap
After mixing the resin, you must pour directly into the spray cap.
It's not necessary to use any mold release!
Step 4: Removing the Resin From the Spray Cap.
wait about 1 hour to remove the resin from the spray cap.
After removing the cured resin from the spray cap, the piece should look like the one from the picture above.
Step 5:
Now with a marker, outline the craft stick and cut along the line drawn..
You can cut along the line drawn with a dremmel or a small cutter.
Remember! If you are underage ,you must ask your parents for permission!
http://www.wikihow.com/Use-a-Dremel-Tool
Step 6: Sanding.
After sanding , the earpiece should look something like the pictures from above..
Step 7: Final Step.
You can use a bit of modeling clay to fill the middle part.
I added about 4 mm height of clay and made a mold.
That's all folks!
Good Luck!!!
Be the First to Share
    • Cheese Challenge
      Cheese Challenge
    • Fandom Contest
      Fandom Contest
    • Microcontroller Contest
