K'nex Semi-Circle Lift
Introduction: K'nex Semi-Circle Lift
About: I'm a 16 year-old guy who loves to build mechanics out of knex. my main interests are ball machines and roller coasters. My real name is Matt and I'm a christian. I live in Australia or more commonly known as …
Hey peeps! Tornado96 here to bring you an instructable of the Semi-Circle lift from my ball machine, Dragon Gem. This is a very simple lift but useful if you want to see something a bit more exciting than a chain lift and don't have an incredible amount of pieces. It is made with a perfectly circular "guide" that forces the chain to rise in a swift half-moon motion. Please enjoy and don't forget to comment and subscribe to see more k'nex models from me!
Now let's get on to the piece count!
Step 1: Piece Count
I hope you like maths because now you have to count the pieces you have to make sure you have enough for this build! If I have any miscalculations please let me know!
Rods:
Green: 78
White: 54
Blue: 58
Yellow: 46
Red: 62
Grey: 35
Connectors:
Light grey 1-slot: 26
Grey 2-slot: 18
Orange 2-slot: 50
Red 3-slot: 26
Green 4-slot: 4
Yellow 5-slot: 68
Purple 3D 4-slot: 71
Blue 3D 7-slot: 19
White 8-slot: 6
Miscellaneous:
Black Y-clips: 8
Flexi-rods: 2
Blue spacers: 9
Grey spacers: 14
Red gears: 6
Motor: 1
Chain links: 91
Total: 752
Now that you have counted the pieces it's time to move on to the building!
Step 2: Entrance Track
This structure supports the track where the ball enters the lift. Don't forget to follow image notes where they are needed!
1. part 1 of main frame
2. part 2 of main frame
3. entrance track
4. connecting part 2 and 3
5. connecting part 1 to part 4
6-7. part 3 of main frame
8. connecting it all together
9-10. the rest of the entrance track
11. connecting it to the main base
12. what you should have so far
13. holding track
14-16. connecting the holding track
17. gears
18. connect it the the rest
19-20. more holding track.
21. connect it ( do not connect teh yellow rods. They will be connected later on)
22. Overview of step 1
Step 3: Lower Backbone Supports
Now you get to start shaping the lift with the Semi-circle backbone. A lot of Backbone-Support connections were necessary to prevent the backbone from moving sideways which would affect the chain on it's way up.
1. lower frame part 1
2. beginning of the backbone
3. more backbone
4. connecting 2 and 3
5. connecting backbone to lower frame
6. another angle
7. lower frame part 2
8. connecting part 7 to 1-6
9. another view
10. middle frame part 1
11. middle frame part 2
12. connecting 9 and 10
13-14. connecting the middle frame to the lower frame
15-17. connecting step 3 to step 2
Step 4: Middle Tower and Backbone
Just as the title of the step suggests you will now build the middle section of the tower and the freestanding section of the backbone.
1. backbone
2. connect it to steps 2-3
3. middle tower
4. connecting the tower
Step 5: Motor Hub and Exit Track
Next you will build the motor hub and the exit track. The gearing tucks in nicely with the exit track!
1. lower motor hub support
2. tension gear
3. connecting them together
4. Motor axle
5. exit track part 1
6. another view
7. exit track part 2
8. another view
9. connecting the exit track together
10. adding the motor axle
11. exit track support
12. adding exit track support to motor hub
13. another view
14. connecting the motor hub to the lower support
15. another view
Step 6: Finishing the Semi-circle
Now you'll build the last part of the backbone that connects to the motor hub and exit track.
1. side support part 1
2. backbone
3. connecting backbone to side support
4. another view
5. side support part 2
6. putting it all together
7. attaching step 6 to step 5
8. another view
9. connecting it all to the tower
10. coming along nicely! :-)
Step 7: Adding the Chain
Without chain, the balls won't get very far. Let's add some, shall we?
1. section 1. build 9 of these
2. section 2. Build 1 of these
3. all the sections you should have. 10 in total
4. Connect it all together!
5. close up of positioning of the chain on the upper gears
6. another view
7. close up of positioning of the chain on the tension gears
8. close up of positioning of the chain on the lower gears
Step 8: You're Done!
Congratulations! You have just achieved a great feat worthy of the most noble k'nex builders! May this contraption aid you in your quest as you build your own ball machines!
heaps corny, I know but it sounds cool! :-D
Now go try it out and let me know how it goes! Always great to receive feedback!
Thanks for building!
Comment, rate and subscribe for more!
See you guys next time! It's been a pleasure teaching you!
3 People Made This Project!
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
  • Game Design: Student Design Challenge
40 Comments
origamiwithnathan
origamiwithnathan
5 years ago
thanks so much for creating these instructions, works great, now all I have to do is build the tracks!
That_Jamie_S_Guy
That_Jamie_S_Guy
7 years ago
I built this beautiful and bigger than I expected lift :) I'll send you a picture tomorrow if I remember :)
Gargamel-Knex
Gargamel-Knex
9 years ago on Step 8
Beautiful lift, I am now working for a ball machine ....
Tornado96
Tornado96
Sorry? I'm not sure what you mean by that haha
Leigo Andre
Leigo Andre
Actualy, seeing this comment 1 year later me neither!:D EPIC
Tornado96
Tornado96
I'm pretty sure it does. If it doesn't it would be easily modifiable
cooljupjup
cooljupjup
yessss it wil work but you gonna modify something on the rail in the bottom
Tornado96
Tornado96
Yes, that was my expectation. Great to see you got it to work! :)
I've built it and it works very good! I'm gonna use this one in my next ball machine!
