Introduction: Knex Revolver True Trigger
ok after i saw syprans idea for the taped up cylinder i couldnt let myself sleep without basing an instructable on it oh and by the way the pictures are crap because i couldnt find a real digital camera so i used my xbox live vision camera and i will probably post an instructable on how to set that up because well yes my internet friends it is a B1@h7 to set up if you dont take the easy way out
Step 1: Make the Cylinder
same as syprans only half the size 2 silver spacers rolled together make 8 of these put em on the the what sypran used and
Step 2: Make the Handle
simple and i guess comfortable
Step 3: Barrel Tip and Front Sight
just make this part
Step 4: Trigger
Step 5: Cylinder Platform
ok make sure the red connector faces down and must have those 2 spacers
Step 6: Inner Barrel
Step 7: Gather Last Pieces and Firing Pin
ok fixed this u do not need to modf the pieces gather these parts
Step 8: Assembly
ok attacth the cylinder to the cylinder holder ,that attaches to tip ,tp to top rail ,MAKE SURE U PLACE THE WHITE PIECE THERE, sides go on put trigger in MAKE SURE THAT BAR WITH CLIPS IS ON it keeps the trigger from falling outand the handle u saw the first pic i dont need to take another pic im lazy and hungry
Step 9: Loading FIring and Ammunition
first just find a good spot for a trigger rubber band and a firing pin rubber band 2nd get ammo take a preferably long rod or any rod that u find almost usless cut it into pieces as big as little green connectors i used a green rod flip 3rd pull back ram rod and open front barrel tip 4 either load te cylinder or replace it i have 2 cylinders so i can easily swap out the empty cylinder with a fresh one 5 close the barrel and shoot on pull back the ram rod change the barrel and pull the trigger i
I give alot of credit to sypran for his genius tape revolver cylinder idea
