Introduction: Kraken Jr. IoT App Tutorial Part 1 - Email Registration and Activation
- Tutorial Part 1 (Email Registration and Activation)
- Tutorial Part 2 (Capturing Cid and Auth Code)
- Tutorial Part 3 (Arduino Registration)
Kraken Jr IoT is the simplest of IoT implementation on the Web.
by Using Arduino Uno + Ethernet Shield you will be able to remote control any electrical devices anywhere in just a few minutes of configurations.
- Android Mobile (OS Version = Minimum 7.0)
- Email Address (Gmail preferably)
Step 1: Search for KJR App @ Google Play Store
- Open your Google Play Store
- Search for phrases such as "KRAKEN JR. IOT" or "MARCIUS PROXIMA LUNARIS"
Step 2: KJR Installation
- Tap Install
- This will download and Install the KJR Application
Step 3: First Time Running the KJR
Once the Installation completed
- Tap Open - To continue with the registration
Step 4: First Time KJR Registration (1)
- Tap the Eye Icon of the Email to show the hidden value
- and Tap the Save Settings so you would not need to re-type again your credential the next time you reboot your app
Step 5: First Time KJR Registration (2)
Change the user@domain.com with your working email address
Step 6: First Time KJR Registration (3)
Click LOGIN
Please Note! When registering you can Ignore the Pass Code field
Step 7: Account Not Found
After tapping the Login button, a warning message will display "Account Not Found"
- To continue with the registration just Tap Register
Step 8: Activation Link Sent
After tapping Register, another message will display "Activation Link Sent"
This means that you will need check your email inbox.
Kraken Jr. App has sent you an email with the link that will verify and activate your new account.
So go ahead and check your email now!
Please Note! The email may arrive immediately or may get delayed and wait few minutes more or sometimes an hour depending on email type. and also check your spam folder.
Step 9: Email Activation Link
The when you received Activation Email. you are now only two steps away to complete the registration.
- Take note of the Pass Code in the email - as you will be needing this when you go back to the app and Login
The whole registration process will be completed when you receive the message "Successfully Activated" after Tapping the Activate Button or the equivalent link in the Email.
Continue to Tutorial Part 2 (Capturing Cid and Auth Code)
1 Person Made This Project!
- krakenjriot made it!
