Introduction: Make a Ornithopter at Home Easy.
Today I will show you how to make a ornithopter at home.I will show you briefly how to make this.
Stick,String,Wood,Iron wire,Rubber band,Polythene,Glue,Scissor.
Step 1: Make a Triangle Using Stick.
Take 3 sticks and bind them as a triangle like the image.Then attach them with glue.
Step 2: Adding Pen
Take the insider tube of a pen and cut them like the first image in three part.Then add the cutted tube like the second image.
Step 3: Working With Stick and Iron Wire.
Take iron wire and bend them by 90° two times.Then attach the bended iron wire with the sticks.
Step 4: Icecream Stick.
Take icecream stick and cut them into two pieces.Then make a hole at both parts of the icecream stick like the first image.Take iron wire and bend them like the second image.Then take the icecream stick put them into the bended iron wire like the third image.
Step 5: Use the Sticks of Step-4
Take sticks from step 4 then attach them at the front part of the triangle made in step-1
like the image.
like the image.
Step 6: Attaching Iron Wire at the Back Part of the Triangle.
Take two iron wires and bend them like the image.Then attach them at the back part of the triangle.
Step 7: Adding Polythene With It.
Take polythene and put it like the image.Then cut it like the image and attach it with the
Ornithopter using glue.
Step 8: Last Step Adding Rubber Band.
Take three or four rubber band and attach it with the ornithopter like the image.
Step 9: Testing the Ornithopter
Now its time to test
If you cannot see the video correctly go to : https://youtu.be/1Pp-r_Amf1g
![Make It Fly Speed Challenge](https://content.instructables.com/FDF/NHNS/KCQ8HLLZ/FDFNHNSKCQ8HLLZ.jpg?auto=webp&crop=1240%2C600&frame=1&width=320)
