Introduction: Making Black and White Images on Photoshop
Hello, today I am going to show a very easy way to make an Image in Photoshop black and white. It's really one of the easiest things you can do in Photoshop, but if you are a beginner, no worries, I got you covered!
You will only need one thing:
- Photoshop (I am using the most current version of Creative Cloud, but it shouldn't be much different for earlier versions)
Step 1: Find an Image That You Want Turned Into Black and White
I just found an image of a cat on Google Images, but you can use any photo that you want!
Step 2: Put the Image Into Photoshop
Click on File->New and choose your desired image size. If you have an image already copied from Google Images like I do, the image size should be already correct.
If you are using a image on your computer find the image on your computer, right click it, and click
Open With-> Photoshop
Step 3: Desaturate the Image
Go to Image -> Adjustments -> Desaturate
You should get a result similar to the image on the right.
You could end there, but I like to take it a couple steps further...
Step 4: The Burn Tool
After the Image is desaturated, I like to go in with the burn tool and highlight the shadows and stuff to give the image a little more depth to the image.
The detail are a little finite, but I just go around the edges and the shadows, and on some of the focal points (ei, the mouth, eyes, and ears of the cat.
Step 5: The Burn Tool
You can't see a huge difference, but if you look at the side by side image, you can tell the mouth and some of the shadows are a bit darker, giving the image more depth.
Step 6: Save the Image
Once you are done you go to File->Save As and choose where you want to save the image and what file format, I'd recommend saving it as a JPEG or PNG, but that's up to the user.
Step 7: You're Finished!
There you have it, a beautiful Black and White Image.
3 years ago
Good steps, thank you for sharing : )
