Introduction: Marble Cannon
Mr. B 5th Period A day Marble Cannon Project by Landon Sumor and Sam Bosworth
Step 1: Gather Your Mats
- 2 2x4's cut 18in in length
- 1 1x1 cut 18in in length
- 1 3/4 inch pvc pipe cut 14in in length
- 1 1/2 inch dal rod cut 12in
- 1 3/4 inch door hinge
- 2 half-inch diameter springs
- 10 2 inch screws
- duct tape
- drill, saw, measuring tape,
Step 2: Assembling the Base
Attach Door hinge to inside of the 2 2x4's on the short side.
Then, screw 1x1 into the top of the top 2x4 on both ends to make sure it is sturdy.
Begin to bore a hole through the dal rod on one end, leaving about an inch remaining.
Next, attach one spring to a screw and drill it through said hole until the screw is showing on both sides about the equal amount.
Finally, drill a screw about 3.5 inches down on the 1x1 from the right.
Step 3: Assembling the Cannon
- Duct tape the pvc pipe to the 1x1 leaving about 2.5 inches on the same side you already screwed the screw into.
- Next, insert dal rod into pvc pipe and attach the second spring to the exposed side of the screw in the dal rod.
- Use duct tape accordingly to contain the springs to the screws so they don't fall out.
- Attach the other sides of the springs to the screw in the 1x1.
Step 4: Checking for Errors
- Test the cannon several times from a variety of ranges to test its consistency
- Make minor improvements, if needed, to adjust your cannon to be sure of success
- Finally, your cannon is done. Now, you begin your tests and your mathematical research
Step 5: Mathematics
- First, figure out an angle that your cannon works with. This is done by simple trial and error and there will be a range of possible angles.
- Once an angle has been found, you can apply it in kinematic formulas.
- By taking the distance/time you get the velocity in which you fired your cannon.
- Velocity is just another term for speed, measured in meters/second.
- With the velocity, you can determine how hard to shoot your cannon to go a specific distance, and the acceleration of your marble.
