Introduction: Minecraft Gardening Tent.
How to make a Minecraft gardening tent. ( I remade it for the remix 2.0 contest. ) Here is the original link: https://www.instructables.com/id/Minecraft-Gardening-Tent/
Step 1: Make the Skeleton.
( This is a bit different than the original one. ) Make the Skeleton of the tent. 5 blocks tall, and 5 blocks wide. Make it connect at top.
Step 2: JAdd the Floor Edge
( this way is different because you make an edge on the floor instead ) is Dig out the edge of the floor & fill it in with whatever block you used to make the skeleton.
Step 3: Add the Water.
( this time, for the water you do it at the edges & only 1 block by 1 block ) Dig 1 block wide 1 block deep at all 4 edges & fill in the holes with water.
Step 4: Hoe the Ground.
( now you have to hoe all the ground that's in the border of the floor edge ) Hoe all the ground as shown in picure.
Step 5: Place Seeds.
( now you have to place seeds on the hoed ground. This is different because the original version used pumpkin seeds which wouldn't work because you need a plain block space for the pumpkins to grow. ) Place seeds on hoed ground.
Step 6: Adding the Roof.
( this is different because the glass is in a different way so it looks much better ) Put glass all around the edges. ( don't put glass on the ends as shown in picture ) On top, fill roof in with glass as shown in picture.
Step 7: Adding Fences & Slabs
( this is much more different than the original version. You put slabs at the top & you put fences all over as it is shown in the pics. ) On top edges, Use slabs twice so they look like blocks. Do slabs in top middle as shown in picture. Add fences as shown in picture.
Step 8: Add Fence Gate
Add the fence gate on the side you want to be the front, bottom middle
Step 9: Add Torches As Shown in Pictures
( this version has torches so it won't have mobs spawning at night & youll be able to see! ) Title pretty much says it all X-)
Step 10: Tada!
Now you're done. Enjoy!
