Introduction: Minion Night Ligth Powerbank
Reuse soap container for hands
Before starting we will use welding so I suggest you see the welding course and you should be very careful when handling lithium batteries.
To be able to convert the container of minions into a lamp we will need:
1. Powerbank cheap
2. LED Battery-powered Night Light Stick on Cabinet Closet Touch Lamp Lights0
3.Minion liquid Hand Soap Dispenser
Step 1: Tools Need
Step 1: Tools Needed
Precaution: Can suffer injuries if not taken care of so I do not take responsibility for any injury if any tool does not know how to use it is better to seek help.
Tools:
  • Safety glass
  • Scissors
  • Cutter
  • knife
  • Hot glue
  • Hot glue sticks
  • Soldering
  • IronSolder an flux
  • Wired cutter
  • Hairdryer
  • Dust mask
Technics:
Soldering
Step 2: Disarm the Power Bank and the Light
Firts step.
In the powerbank I got a decal where the usb removed this decal and I found that I had 4 screws after removing them I just had to pull the white part and the battery went out with the electronics.
Second step.
The lamp was simpler since I only had to pull the pieces to disassemble and separate each of the parts leaving only what I would use the electronics without the base.
Step 3: To Assemble
Connect as shown in circuit
Use the same plug to place the tablet with the white usb base
