Introduction: Mom's Blueberry Crumb Pie
When it comes to baking, my mother doesn't mess around. And one of the things she bakes best is blueberry pie. Unfortunately, she only bakes it once or twice a year because she refuses to make it when blueberries are out of season (like I said, she doesn't mess around). For those of you that don't know, blueberries are only in season during the sweltering summer months and hence, she only makes blueberry pie once or twice a summer. As such, when I think of summer, I think of blueberry pie.
Having spent the past few summer's 3,000 miles away in the land of eternal fog, I've really been craving some blueberry pie (thinking about it just makes me homesick). Anyhow, this year I've finally taken it upon myself to do something about this. I got my mother to send me the recipe and made this killer pie myself. Problem solved.
Step 1: Go Get Stuff
Stuff you will need...
For the crust:
2 cups
flour
2 sticks cold butter
1/2 teaspoon salt
1/2 cup ice water
For the filling:
6 cups of blueberries (3 large pints)
1/4 cup flour
1/2 cup sugar (give or take)
A pinch brown sugar
1/2 teaspoon cinnamon
2 teaspoons lemon juice
1/2 teaspoon grated lemon peel
1/8 teaspoon salt
For the topping:
1/3 cup sugar
3/4 cup flour plus a little
1 stick cold butter
a pinch of cinnamon
Tools:
Pie tin
2-3 mixing bowls
Measuring cups
Measuring spoons
Forks, spoons, butter knives
Wooden mixing Spoons
Cutting knives
Pastry blender
Rolling pin
Colander
Grater
Aluminum foil
Plastic wrap
(Note that some of the links on this page are affiliate links. This does not change the cost of the item for you. I reinvest whatever proceeds I receive into making new projects. If you would like any suggestions for alternative suppliers, please let me know.)
Step 2: Bathe the Berries
Wash off the berries in your colander and set them aside to dry.
Step 3: Water on Ice
Stick two cups of cold water in the freezer to chill.
Step 4: Start the Dough
Start the dough for the crust by mixing together the two cups of flour with the half teaspoon of salt
Step 5: Butter It Up
Take your two sticks of cold butter and cut them into small slices. Put these slices into the dough and mix them in with your pastry blender. Don't be shy about it. You need to grind it all together until it starts to form small clumps.
Step 6: On Ice
Mix the ice water into the dough approximately one tablespoon at a time and continue mixing it in until the dough can hold itself together. You probably shouldn't end up putting too much more than a quarter of a cup.
Step 7: Powder Your Hands, Not Your Nose.
Lightly sprinkle flour onto your hands and rub it around such that your hands are coated. You do this so that you can handle the dough in the next step without it being sticky.
(You did wash your hands first, right?)
Step 8: Rolly-polly
With both hands roll the dough around until it forms a single solid ball.
Step 9: Flatten
Lightly flour your counter surface and place dough ball on it. With rolling pin spread out dough until it is roughly 12" square (1 foot). A good method for stretching it out evenly is to roll back and forth around the dough in a clockwise manner such that you stretch it at least once in every direction.
Step 10: More Buttering
Wipe down your pie tin with butter and then lightly flour it. This is to keep the dough from sticking.
Step 11: The Big Switch
With both hands, carefully lift your dough off the counter and transfer it into the pie tin (be careful not to rip it). Lightly push it down so that it fills in the entire pie dish. Also, trim away the extra dough from around the rim. if you want, you can lightly dot all over the bottom of the pie with the fork (but don't go all the way through).
Step 12: Cover and Chill
Cover the pie crust with plastic wrap and let it refrigerate for at least over an hour.
Step 13: Wait
Wait an hour for the dough to cool.
Step 14: Grind It Up
Peel the lemon and then and collect the peel. With your grater, grind inside of peel into fine flakes until you have half a teaspoon worth.
Step 15: Prepare the Blueberries
Place the blueberries in a large bowl and mix in all of the ingredients for the filling listed in Step 1. Mix thoroughly with your hands and then let is sit for a few minutes so that you can make the crumbs.
(Now would be a good time to preheat the oven to 425 degrees)
Step 16: Crumbs
Mix together the ingredients listed in Step 1 for the crumbs. With your pastry blender, mix well until you can no longer see any chunks of butter and small crumbs have formed. It helps if you pound the mixture with the pastry blender.
Step 17: Fill'er Up
Take pie shell out of refrigerator and fill it with your berry filling.
(If you still haven't preheated the oven to 425 degrees, do it now)
Step 18: And Sugar on Top
Evenly coat the top of the berries with crumbs.
Step 19: Bake Time
Loosely cover the pie in aluminum foil and bake for 50 minutes at 425 degrees. After the first 50 minutes, remove the aluminum foil and bake until the crumbs start turning golden brown.
Step 20: Be Cool
Let the pie cool down on a cooling rack or on a cool stove-top burner.
Step 21: Serve
Serve it up!
For maximum impact, heat slightly and serve with vanilla bean ice cream.
Did you find this useful, fun, or entertaining?
Follow @madeineuphoria to see my latest projects.
Pie Contest
4 People Made This Project!
- justjimAZ made it!
- pattyann made it!
- krstlchik made it!
- I_am_Canadian made it!
42 Comments
6 years ago
Does anybody know if you can freeze this? I just had a baby and am trying to stockpile frozen meals but we need dessert too :-)
Reply 5 years ago
Are you serious, you can't cook and take care of a baby that sleeps and only wakes up to eat. Wow, your in trouble
Reply 6 years ago
I don't know. I have never tried. I suppose you could
11 years ago on Introduction
I think something went wrong with my pie :-(
After removing the Aluminium foil, the filling and toping were like swimming in fat (from the butter?). I don't know, what i did wrong. Maybe because i used frozen blueberries?
Or is german butter different? :D
Reply 11 years ago on Introduction
Hmmm... I don't know about German butter. Maybe you didn't defrost the blueberries enough? Or maybe you didn't mix the crumbs together well enough? Or possibly you covered the pie too tightly? I'm not really sure why that would happen.
I think it had something to do with the covering or the mixing of the crumbs (i don't have a pastry blender).
But the baking after removing of the aluminium foil saved the pie, it takes good, just looks a bit weird.
12 years ago on Introduction
ha ha sounds yummy i would eat it all
Yum yum yum yum yum!!! I love blueberries and will definitely try this.
I prefer to use frozen when I make blueberry jam as the flavour is much more intense. I keep the frozen berries in the freezer for several months so they can accumulate a nice bit of ice in the bag. Then I take the frozen berries out of the bag, knock any ice off them, and put them back in the freezer on a tray (not in the bag) for a day or two or three. Then I make the jam.
I will try the same method for the berries for this pie.
Your mamma must be proud of you! Very nice instructable too. Fave'd.
yum
14 years ago on Step 1
Oh, and how much is a "stick" of butter?
Reply 12 years ago on Introduction
Being a Canadian professional in the food industry and having lived in both the United States (Florida, California both) and here in Ontario I can explain what and why a "stick of butter" is.
In the US of A they like their extra packaging. Instead of the grease proof paper or recycled thin foil theirs often comes in a cardboard box with 4 equal "sticks" of butter (1/4 lb) Imagine if you will your regular pound of butter unwrapped standing on end so it's taller rather than wider. Now if you were to cut it twice in a cross so that you have four long sticks of butter.
The purpose is so that it fit's nicely on a butter tray. Each lb has 4 sticks. They also measure it that way in recipes. We Canadians have markings on the outside of the package to denote measurements so we can cut just the right amount for a recipe.
Reply 12 years ago on Step 1
Thats super, thanks a pile!
Reply 14 years ago on Introduction
It's one stick of butter. And thanks for the compliments! The clock... belongs to my roommate. It has a different bird call for every hour. It has grown on me over time.
Reply 14 years ago on Step 1
Even better, could you tell me how many grams there are?
My butter does not list grams, but if your butter comes in a 1 pound package, with 4 sticks, then one of those is 1/2 pound. you cand do aconversion to find out grams. there are many places online thay you can find that information.
So a stick is just one of those standard rectangular cube-ish things?
Yes.
One stick of butter is 1/2 a cup (4 oz).
That's what I meant to say... whoops.
12 years ago on Step 16
If you don't have a pastry blender, you can stick it into a food processor and pulse it a few times. If you make it too buttery by accident, don't worry. Just form it into a dough and break it into little pieces when you top the pie with it. Works just as well. When you use the pastry blender or food processor, make sure the butter is COLD. otherwise it is more likely to form a dough.
