Introduction: My BoomBox
Hello everyone
Have you ever encountered a situation where you went with friends to the beach at night or maybe some friend's apartment and he had no stereo system?
It happened to me, and it sucks!
So , i decided to build one !
although it weights 6.5 Kilo , You Grab it with both your hands , put the music at Max and have the best time !
Enjoy!
Step 1: Shopping List
Materials :
1X1 meter of Plexiglas , preferable Transparent
screws & nuts - a lot!
12V 7 amp Batteries , preferred 2 for longer operation
Lepai Amp from eBay
12V Charger for the Battery -eBay
Speakers - i got the Pioneer 4.5" as Woofer / Mid-range and a pair of Teac t20 Tweeters
Volt-meter - ( not shown yet , but will be attached later )
Wiring for speakers
Iphone Dock
Aluminum Angles - comes in 3 Meter length - - for connecting the Plexiglas sides to each other
Tools :
Driller and electric screwdriver
Jigsaw - most important instrument - make sure you cut the Plexiglas with a refined saw (designated for steel)
Marker
Leveler
Calipers
A pair of clamps
Drill bits - different sizes
Caliber
Tin snips + a pair of working gloves so you wont cut yourself
Soldering iron - for the wiring
tin
Hot Glue
Time ,Patience , and lots and lots of Coffee !!
Step 2: Cut the Plxiglas
Start by planning the general size of your future to be Boombox.
Measure the inner diameter of your speakers , and accordingly mark it with the Caliber or some other ruler on the Plexiglas
Prepare the driller and and the jigsaw ,and off we go our way
Step 3: Cutting the Aluminum Angles
cut the aluminum with Tin snips .
* please be cautious
Step 4: Drill Holes in the Aluminum and Plexiglas
Make sure you grab the Aluminum angles to some tight ground , only then Drill !
Use a special drill bit for metal, that way the hole will be accurate and round , and probably will take less time to drill.
Step 5:
after i finished the drilling , i took the Aluminum angles and attached them to the Plexiglas with bolts and nuts
Step 6: Moved Forward
Continue sawing slowly , be careful not to brake the Plexiglas ,it`s a very delicate material and it might crack easily .
Step 7: Strengthen the Boombox by Adding an Additional Middle Rib
Step 8: Prepare the Bottom .
since i plan to put two 12V batteries at the bottom , and they are heavy .we need to create a strong durable Plexiglas bottom.
I took two Plexiglas pieces , attached them to each other , drilled holes for the stand , and attached them to the sides with the Aluminum profiles
Step 9: Create an Upper Case Door , With Hinges
On top of the upper case i plan to put the Lepai amp and some Docking station for the iPhone
Step 10: Upper Look
I just put inside the Batteries in order to see if they sit properly
Step 11: Last Steps of Drilling
before you take the Nylon off , it would be wise ( not like i did ) to finish with the Drilling . god forbids i`ll scratch it ;)
Step 12: Pealing Off the Protective Nylon of the Plexiglas
I pealed off the protecting nylon layer of the Plexiglas .
I had to unscrew all the bolts and nuts in order to get rid of the excess layers of nylon.
Step 13: Still Pealing Off
Step 14: Assembling All the Pieces Back Together
Without the Nylon
Step 15: Mounting the Speakers
Step 16: Almost Ready ...
all i need is to wire the speakers and tweeters do some good soldering
Step 17: Hot Glue on the Tweeters
This thing sticks like charm!
At some point i decided to replace to old tweeters with a set of Teac T20 .
It was quite tricky the issue of releasing the grip of the Hot Glue from the Tweeters and the Plexiglas.
after Gooooogling for a while i found a quick Cool way to remove the Glue
Alcohol !
You just put tiny tiny tiny little drop on the Glue and in seconds it releases it`s grip , like taking candy from a baby :)
Step 18: Soldering Ends to Wires and Connecting the Batteries in Parallel
Make sure that you did some good Soldering in here, we don`t want it to disconnect and perhaps make us some Short circuit .
I connected the batteries in Parallel in order to give me higher Amps . Total of 14 Amps
Still i will have 12 Volt direct and stable current
Step 19: Inside Look
Step 20: Charging Moment
After charging it for a few hours ,the batteries gave me a reading of 13.2 Watts and 14 Amps
After 8 hours of playing the Boombox i checked the Voltage with the Volt-Meter and the reading was 12.89 !!
Amazing!
83 Comments
8 years ago on Step 21
Looks awesome!
8 years ago on Introduction
This is pure sexy. I love how it's acrylic and you can see all the components
Thanks!
loved your work - Inventor-Deadmau5 Head
hi thanks foe sharing your ideas with us
That looks like my pc-case (sharkoon acryl-showcase). Looks rearly cool, i like it.
Thanks!
it is actually the size of a Desktop computer ...
I`m thinking about mounting him a pair of wheels so i can roll it over from place to place instead of lifting it ;)
God ideal :-)
If this isn't sweet...I don't know what is! I love to see electronics made with Plexiglass. Wish I had the tools, time and patience.
Thanks!
appreciate it ;)
Go for it , don`t waste time , invest in your self and start expressing your thoughts
Very cool!
Very nice looking enclosure too!
Takes me back to my post high-school days when a friend and I used to make and sell sub-woofers, mostly for cars!
3 years ago
Here is one more
6 years ago on Introduction
Nice build!!!
I love that you can see the internals
but to make it a bit more portable you should have used a like 2 of those in parallel i think you need 12v? than that would be an better option? Those car acid batteries are really heavy! but you choice =P Still a nice build!
7 years ago on Introduction
What is the bass like with this? By watching the video the bass almost sounds non-existent. But i assume that's just due to sound quality.
your right!
the bass is actually very surprising . it is very rich and soft and not cold and hard.
it is all due to the Reflex port location and the middle partition , it gives the woofers a better sound
did you ever play music before you cut the reflex port?
Yep
and the sound was rubbish/
well at least the BASS was awful .
you must let the Membranes " Breath " they are moving in and out , and the whole concept of Acoustics is give the sound waves the ability to move freely in the box
either way , the sound is much better with a Reflex port \
I've made an ammo box speaker (my profile picture) but i haven't put a reflex port on it. My problem is knowing where to put it, any ideas? i was thinking on the side of the box where the lid catch is but i don't know. There is a whole science of reflex ports, so any help would be appreciated!
Well you are right about the science issue of those reflex ports
to get the best sound we need to have a professional lab , with a few guys who know a thing or two about acoustics
first i have seen already your boombox and it`s awesome!
second , i would have make a small 3x3 reflex port between the speakers ( top side )
or a better way - on the internal side ( where the air freshener is )
cut a small 3x3 hole( even a 4x4 ) , put a round tube and get it to come all the way over the middle ( above the battery )
i read an article about tubing inside a woofer box and it`s very complex , but it`s better then just making a hole.
attached is picture
I'm just a bit hesitant of cutting a hole as once it is cut then i can't go back. I have just ordered 2 more ammo boxes so maybe i'll transfer the guts into that one and put a port on it. I'll let you know how things turn out!
the pictures
