Introduction: No Sew Fleece Blanket
Step by Step instructions to make a No-Sew Fleece blanket, brought to you by Bunyworks.net. Your blanket can be any size. Fleece comes 60-inches wide, so your blanket can be 60 x ??? Your finished product will be about 10-inches smaller than the fabric you start with.
Step 1: Choose the Fabric
Choose a print and a contrasting or matching solid. I like to use strong, bold contrasts. You will need a solid and a print that are the same size. My sample uses a nice dark hunter green for the back.
Step 2: Line Up the Two Fabric Pieces.
Line up the two fabrics, right sides OUT. Anti-pill solids are FUZZY on the right side. Anti-pill prints will be more distinct on the front side. Regular prints are hard to tell -- use the side that appeals to you.
Step 3: Trim to the Same Size.
Trim the two pieces so that they are the same size.
Step 4: Cut Out the Corners
Cut a 5-inch square from each of the four corners.
Step 5: Cutting the Fringe
Cut fringe on all four sides of the blanket. Cut through both layers of fabric at the same time. Fringe pieces should be a little wider than the width of your finger. Cut in from the edge 5 inches. I like to lay a yard-stick across the fabric, 5 inches from the edge so that I know how far in to make my cut.
Step 6: Begin Tying Knots
Leave your blanket laying flat on the surface, with all fringes lined up. I find it easier to start tying from the left and work right, going around the blanket. If you are left-handed, you may find it easier to start on the right and work left. These knots are called balloon knots... tie them just like you would if tying off a balloon! You can also tie a knot like you would make with a shoe lace. That kind of knot will be easier if your hands are arthritic.
Step 7: Continue Around the Blanket
Tie all the fringes together on all four sides of the blanket. You are Finished! Wasn't that easy? All the knots should be snug up to the blanket, but not too tight. The finished blanket should lay flat.
Tip: If your blanket is square (all four sides the same length) you can turn the top so that the stretch goes in the opposite direction of the stretch on the bottom piece. This gives a more stable blanket.
Use the same directions to make pillows... if you have a 12-inch pillow form, cut two pieces of fabric that are 24-inches square. Tie three sides, insert the pillow form and then finish tying the 4th side.
11 People Made This Project!
- katelynn.daviduck24 made it!
- I like dogs so much made it!
- LaNiaya made it!
- Every_Day_Renee made it!
- MarciaS47 made it!
- CandiceG10 made it!
- AngiJ made it!
- eaglesfly13 made it!
- MammaTot made it!
See 2 More
91 Comments
Question 7 weeks ago on Introduction
approximately how long does it take to complete this blanket, start to finish?
Answer 4 weeks ago
You can make them in 1 day. It really depends on the person. I’ve been making these No Sew blankets for 14+ years now! Very cute and great as a gift!
Answer 5 weeks ago
Approximately a day or two not long at all. Ur fingers will hurt when ur done from tieing knots
Question 8 weeks ago on Introduction
Making my 3rd fleece blanket ever and after pinning and cutting as i started to make knot the fleece tie pulled rite off i tries again and no matter how gentle i was it just kept ripping help i have Another blanket to make and now afraid to cut the fleece
Question 1 year ago
Where can I order the fabric for this? Or do o go out and just buy the fabric myself?
Answer 3 months ago
I order fabric and other things from Joanne's. Or go into one of their many stores.
1 year ago on Introduction
Thanks for the great instructions. My granddaughter makes these blankets. Now I want to try it also and surprise her.
1 year ago
I really like your designs of flour tortilla blanket from https://theburritoblanket.net/. They inspired me a lot. Thanks for sharing this.
6 years ago
Brilliant idea!
Reply 1 year ago
Yes, it is.
1 year ago on Step 1
We can make the blanket any size you want, right?
Question 2 years ago on Introduction
I’m tying the knots on my blanket, but on both selvedge edges it won’t stretch enough to tie a knot. What am I doing wrong?
2 years ago on Step 3
Can you please show how to braid the edges.
Question 2 years ago on Step 7
I want to make a lap blanket for a nursing home. What size fabric do I buy? Do I still cut a 5 inch square from the corners or is it less? Thanks
Thank you I'm so excited to do this activity with my client we are stuck at home for two weeks !!!
Thank you so much
Where exactly did you get THIS pattern of fleece fabric? I have been looking everywhere but can’t find anything like it.
Answer 2 years ago
I saw this deer print at Joanns fabric just this weekend.
Answer 2 years ago
This video was made about 12 years ago. At the time I was buying fleece from the fabric district in Los Angeles and selling it on eBay. You might google “fleece fabric Los Angeles textile district” it is likely someone still carries it! Try Sagetex. ... I bought from them a lot.
Question 4 years ago on Step 6
What is a balloon knot?
Answer 2 years ago
It's on overhand knot. The same kind of knot you tie when you're tying a knot in thread when you're sewing.
