Introduction: No Steal Chopstick Pens
Every time I lay a pen down on my desk someone takes it, Sick and tired one day I happened across the weekly challenge that had to do with Chopsticks, Then it hit me what’s the only pen that people don't take? It's those ones that have obviously been chewed on, no one like using a pen that's been in someone’s mouth!
Thus was born "The No Steal Chopstick Pens"
Step 1: Materials
Materials:
Chopsticks (of course used or not is your choice)
Barrel style pens (the kind with the removable shafts)
Glue or Epoxy (Gorilla glue epoxy is only 5.47 at Home Depot)
Wire Coat Hanger
Used Engine Oil
Tools:
Drill (and/or Drill Press)
Blowtorch (Plumbing type will do fine)
Vice grips
Ball Hammer
Vice or Anvil
File
Pilot Bit
Step 2: Making the Bit
As with most drill bits they are rarely long enough to drill deep enough for the barrel of the pen. So in order to make these I needed a "Bore" or more simply a bit long enough to do the job.
Making a quick bit that can be used only a few times before being worn out is a simple process of heat treating a coat hanger with oil to make it rigid.
Step 1:
Cut your coat hanger the right length (Remember not to cut it to long as the longer it is the easier it will twist on you)
Step 2:
Clamp it in Vice grips (Important to use a clamp of some kind so you don't burn your hand from the transfer of heat)
Step 3:
Heat it red hot with your blow torch
Step 4:
Hammer one end flat
Step 5:
File the hammered edge to a point and sharpen the edges
Step 6:
Re-heat to red hot again, and then while still red dip it straight into the oil (do not go at an angle it will warp the wire)
Step 7:
Wipe it clean and your ready to use it
Step 3: Drill It!
First start with a pilot bit the same size of your homemade bit; drill a starter hole as deep as you can with the bit. "TIP: go very slow if your using a press set your belts on the lowest speed possible, this will also help keeping the Chopstick straight"
Finally finish boring the hole with your homemade bit till your barrel slides all the way down into the hole and stops with the tip extruding out.
Step 4: Glue It and Use It!
Last drop a few drops of glue or epoxy down in the hole and slide in your pen barrel, once it's dry your ready to take them to work.
A nice touch would be to stop and get an empty rice box from your favorite Chinese eatery drop in your pens and sit it on your desk. Most people that see the pens probably won't take it because you might have had those in your mouth, for the adventurous type they "ARE" still chopsticks and you can still eat with them.
Green Living & Technology Challenge
26 Comments
10 years ago on Introduction
roder225, the pens are great. Very creative. Some people always look for something to be wrong. You're a good American and I love it.
Mostly, I like your "common quote". Sounds like you have a really good attitude.
Thank you for your service to our country.
Thanks for the all the positive words. If someone can find something wrong with something with what I do I look at it as a learning experience, I would love to be perfect everytime but what fun would that be spice of life and all that.
Common quote was something I sat down and without thinking just wrote what I felt about myself. I'm one of those "life's too short to put on an act" kind of guys. Some people like it some people don't, just live by my terms and hope I make a few good friends along the way.
Thanks, there are still many of my brothers and sisters fighting for all of us, come home safe!
Yes, many of them are my family and friends. We pray for all of our troops.
10 years ago on Step 4
Nice 'ible. I suspect that drilling the reciever hole undersized could render the pen portion press fit and replacable.
I hope the upside down pens in the picture were for effect only as leaving them this way will render them useless in not much time.
A cool stealthy touch would be to mix some rice and white glue, set it into the box, then when dry, drill out holes for holding the pens, then spray with a spray polyurathane to seal it and give it a natural look.
Not to say the 'ible is lacking in any way, just thought I'd add to the effect if I could. Nice job.
That would be a cool pen holder, I wonder if they will ever do a challenge for penholder.
I tried 3 times to drill a perfect hole down the center of these tiny little sticks the second set I made for someone after I post this I found it eaiser to start wil the smallest pilot bit you can to get the best center point and then step up it keeps from boring out of the side. as for the right size hole getting the exact bit size is hard to do, and wood moves way to easy to keep the end perfect, I tried it at first and just relized that gluing them was my best option. Yes the upside down pen pic was strictly for effect, Actually these you see I have on my desk took a peice of wood and drilled 2 45 degree holes it it and put the pens face down in them to keep the ball point fresh.
Well. Next time I skulk around the office looking for someone's chopsticks to "borrow", I had better be careful, lest I eat lunch with a writing implement!
Actually if you do see a pair setting around on someones desk please take a quick snapshot, it be cool to see how others try to make them blend in on their desk.
i have some helpful critisism
could you possabbly mak it refillable so when the ink runs out you cou just swich for a new ink cardrage
other than that i think the idea is very ingenuis
"helpful critisism" hmmmmmmm oxy moron. Your comment was positive :0) Like you, I think the author's idea is ingenuis too
LOL, yes that does sound like two words that don't belong together. I am going to look around and see if there is some kind of ink pen that can be refilled, Thanks for the all the great idea's and replies.
I'm sure it could be done, in fact you could probably use some kind of putty or low tack glue to make the pen barrel it easy to remove but keeping it in place when in use. The other reason I wrote it up as disposable is in case someone actually still uses them occasionally for lunch, after a few washes chopstick wood gets cruddy looking. After the contest I'm going to add an addendum about using drafting lead to make a pencil set too, probably something like 2mm lead.
like, lead lead or graphite lead? somehow i think mentioning lead next to directions for making an object that can be used as an eating utensil could spawn a class example of darwins theory.
or maybe you just dont like helpful critics.. *raises eyebrow*
Good point anyhow, no matter what kind of lead it's probably not a good idea to put it them your mouth regardless. And the fact someone might use any lead handy without thinking of the toxic effects. While most drafting leads are non toxic there are some out there that are not, So to anyone reading this instructable (as with any) please consider the materials and the use of them before starting. None of us are perfect all we do is think up ideas and pass them along it's up to everyone to make a good sound judgement, with that let me say as well don't stick the ink end in your mouth either, should go without saying but you never know
oh wait you did write drafting before the lead bit, my bad.
Reply 10 years ago on Step 4
To solve the problem of the wooden chopsticks looking 'cruddy' you could use plastic to solve that problem :)
Yes probably some kind a food grade plastic dip would work, Good tip thanks
Very cool...
When you go out for Chinese food, you can take your last bite of desert and sign the check with it!!
LOL that's great love the looks you might get when you do that priceless
I don't know about no steal. The pens are so cute i want to steal them, or make my own. ^^
Thank you, also if you'd rather buy a bit I was just at Harbor Freight and they have long bore bits this size if you don't have the tools to make a bit.
