Olson Mask for PPE With Optional Filter Pocket
408,055
411
115
Introduction: Olson Mask for PPE With Optional Filter Pocket
About: Fashion Designer, Interior Designer
As a technical fashion designer, I help other fashion designers refine their patterns and construction methods for their designs. I looked at many different mask designs online, created some prototypes, and this one is the winner. I've edited the pattern and instructions for quick construction.
The Olson style is a more stylish yet equally effective mask design. The other popular design you may see is the pleated surgical mask style.
The CDC has recently recommended that EVERYONE wear a fabric mask when out in public in high contact areas, like grocery stores or pharmacy, basically anywhere you may come within 6' of another person.
**DISCLAIMER** PLEASE NOTE that cloth face masks are not a proper substitute for N95 masks in health care environments.
This mask is ideal for personal use, use by non-medical personnel in high-contact jobs such as grocery store clerk, package/food delivery, etc. It is not an N-95 equivalent, but with the N-95 mask shortage, it is much better than nothing.
As always, wash your hands often with soap + water for at least 20 seconds, especially before applying or removing your mask, and practice social distancing. This mask is NOT a substitute for social distancing, all three practices must be maintained for optimal protection to yourself and others.
Outer layer: pre-shrunk tightly woven 100% cotton- quilting fabric works great here and comes in many fun patterns.
A contrast inner fabric - 100% woven cotton or a tightly woven jersey t-shirt. Think soft, this goes against your face. If the mask isn't comfortable, you won't want to wear it.
Optional- fabric for a filter pocket. This can be the same as any of the other layers, or something different.
Jewelry wire, I use 22 gauge, cut into lengths of 5 1/2"
T-shirt yarn for ties. I use 5 3/4" for size small, 6 1/4" for size medium, and 6 3/4" for size large.
Filter (optional)- Non-woven shop towels, folded tissue, dried bath wipes, toilet paper folded- or some other kind of non-woven substrate.
UPDATE: I have replaced the unisex pattern with sizes S, M, and L. Links to the files below.
Folder: https://drive.google.com/drive/folders/1wnl6qXaEZk...
Click the link, make sure you are signed into Google Drive. Click on each file, then press the download button located on the top right part of the page. Do not request access, message me if you have trouble.
Please be sure to print at 100% for proper sizing. There is a scale on the printout to assist with this.
Step 1: Select and Cut Your Fabric
Print out the included pattern. Make sure you print at 100% for proper scale.
The pattern only has two pieces, the main mask, and the pocket pattern (optional). You'll want 2 matched pairs of the main mask, one for the front and one for the inside. For the pocket you will want 1 matched pair of your inside or a contrast fabric. If you are using an old super soft t-shirt, that usually goes on the inside parts. To save time you can stack the fabrics so you only have to cut once.
Step 2: Gather Your Other Pieces
In addition to your fabric, you need ties and a nose wire. I prefer to use t-shirt yarn, created by cutting horizontal strips from the bottom of a t-shirt about 3/4" wide, then pulling on them to make them curl up. Very soft, all the colors, and easy to procure. I use 5.75" for the small, 6.25" for the medium, and 6.75" for the large. For the nose wire I prefer to use 22 gauge jewelry wire, cut to lengths of 5.5" and looped at the ends with jewelry pliers to eliminate the sharp ends.
For the nose wire, you can either insert the wire directly into the mask layers and top stitch a channel, or you can use 1/2" wide strips of fabric folded in half to make a separate channel, which is sewn into the layers. This step takes a couple more steps, but is technically easier.
Step 3: Center Fronts Together
You will have 3 matching pairs at this point. Place them FRONT sides together, pin, and sew the large curved seam at 1/4". That is the center front part of the mask, which goes over your nose and mouth. Then press the seams open. I find a tailoring ham (shown) is quite useful here.
Tip: Chain stitch the pieces to save time and thread (see the second photo).
Step 4: Prep Pocket
For your pocket piece, fold twice at 1/4", press and topstitch the edges as shown. Do both sides equally. This will serve as your pocket opening.
Step 5: Layer Pocket on Top of Inner Mask Layer
Lay the back part of the mask face up, seam down. Place the pocket piece on top, also right side up, lining up the notches. Be sure to line up the center seams. I recommend using clips if you have them, pins work also.
Step 6: Pin Ties Onto Front Mask Piece
Grab your front mask piece, and pin your ties along the sides, facing inwards as shown. You want to place them so the outer edge is about 3/8" from the corner of the mask, so when you sew at 1/4" you don't catch the tie along the top or bottom of the mask. Be sure to pin these with the head of the pin on the outside.
Step 7: Sandwich the Front and Back Layers Together
Place the front piece (with ties) face down on top of the back + pocket piece, fronts together. This means the face of your front fabric is up against the face of your pocket. Tuck the ties into the sandwich and pin around, making sure not to catch the tie loops along the top of bottom seam. Line up the center seams of the front with the back.
Step 8: Optional: Add Nose Wire Channel
If you are using a separate fabric channel for your nose wire, layer this on top of the whole sandwich along the top (look for the double notches), and pin or clip, centered.
Step 9: Stitch Around the Perimeter
Stitch around the whole sandwich at 1/4" seam allowance. Back stitch over where the ties attach at the sides, and leave an opening between the ties on one side.
Clip the corners of the mask after sewing.
Step 10: Turn Right Side Out
Using the hole you left on the side, carefully turn the mask right side out. Use a sharp tool to poke out the corners of the mask. Press around the edges of the mask, folding in the seam allowance where the opening is and pressing it flat. Take your time to press evenly so you don't see the back lining of the mask from the front (unless that is what you want).
Tip: If you turn it right side out and it looks like the third photo, flip your pocket to the other side of the mask.
Step 11: Optional: Insert Nose Wire
If you chose not to use a separate fabric channel for your nose wire, take your bare wire and insert it into the side opening, and push it up into the seam allowance at the top of the mask. Center it, and pin it in place. Tip: Place pins at the ends of the wire so you can see it when top stitching.
Step 12: Top Stitch to Finish
Finally, top stitch carefully around the entire perimeter of the mask. At the top where the wire is, stitch carefully and a little farther in from the edge so you don't hit the wire, especially where it starts and stops. If you used a an internal fabric channel for your wire, you may choose not to top stitch where the wire is to be safe.
Step 13: Sanitizing and Caring for Your Mask (important!)
Congratulations on your stylish new mask! To keep it clean, I recommend laundering it often. Remove the filter and throw it away before laundering. In between launderings, you can put your mask in a 160 degree oven for 30 minutes to kill any viruses or bacteria on it. To launder, wash on cold and hang dry.
Store your mask in a well ventilated area, perhaps in a paper bag with your name on it. Launder your mask if it becomes wet.
To apply your mask, first wash your hands. Then apply to face, being care not to touch the inside. Wrap the loops around your ears. Try not to touch your mask when wearing it. To remove, first wash your hands. Then grab the mask by the loops, and remove, being careful not to touch the inside or outside if you can.
I find it helpful to have at least 2 masks so you can rotate them.
Stay safe and healthy out there!!
14 People Made This Project!
  • Puzzles Challenge
    Puzzles Challenge
  • Lamps Challenge
    Lamps Challenge
  • CNC and 3D Printing Contest
115 Comments
lotus0379
lotus0379
2 years ago on Introduction
Hello Ms. James, I try to download the pattern for the Olson mask. In the google drive link, only size small was available. Is size Medium and Large available to download yet? Thank you so much for sharing.
quiltloverforever
quiltloverforever
Reply 2 years ago
I clicked on her llnk Folder: https://drive.google.com/drive/folders/1wnl6qXaEZk... and figured out how to get all three = once I clicked the download = only one opened but there were arrows on the side to get to the other two sizes. I did not know how google drive worked when I tried so I had trouble opening it. I hope this helps. It was very nice of her to share
quiltloverforever
quiltloverforever
2 years ago
Thank you very much for sharing and trying to help us all.
lynnedubay
lynnedubay
Question 2 years ago on Step 7
Hello Ericka,
Did you create an Olson mask pattern for Instructables last spring? I have used it constantly and many people have asked for the pattern. Now I am not able to access the Instructables version to send a link to others. I am referring to the original pattern with the pdf directions along with pictures of a golden color lining fabric and blue facing fabric, with a male modeling the mask. Do you still have a link to that pdf and the L, M, and S sizes? I realize there are now other updates to the Olson masks on Instructables but I prefer the longer nose to ear pattern that has size L on 2 pages.
Can you assist me in finding access to that link, so I may share it with other mask makers?
Thank you,
Lynne Dubay
919-812-4143
bsemeyn1
bsemeyn1
Question 2 years ago on Introduction
How long do I cut the elastic if I want to add an elastic strap stretchy ear tie rope? I am making all sizes. Thanks.
laurellbarton
laurellbarton
Answer 2 years ago
I do about 9 inches per side so there is ample for personal adjustment.
deavers1213
deavers1213
A couple months ago you had a different pattern - longer and has the choice of elastic or ties. I've overused my current copies and want to print new ones but what is currently on your doc is not that pattern. Can you please post that one too?
vickicurwick
vickicurwick
Answer 2 years ago
Is it possible to print the original pattern you have and maybe share?
laurellbarton
laurellbarton
Reply 2 years ago
I have the same issue! I like the old pattern and want to share the option with a friend who needs to make masks, but this version does not match with what I did based on the old pattern which was also in three sizes and worked great! Please repost?
wilkvolk
wilkvolk
Tip 2 years ago
i think they also sell thin filters for masks you can add to the inside of the mask
marissawhitaker83
marissawhitaker83
This is very hard for me to decipher which piece goes where, because the colors are different on each page. When I have my face piece and I'm ready to add my cheek and mouth pieces, do I face them with the front sights together?
djthornhill1039
djthornhill1039
Would it be better to use a nonwoven fabric to make the masks instead of cotton? I have a ton of totes made from nonwovens that I could use.
marissawhitaker83
marissawhitaker83
Answer 2 years ago
Yup! Since there's so much price gouging for Olyfunun nonwoven polypropylene fabric, I started using non woven PP grocery bags. It's pretty cheap on Amazon you can get quite a few of them for about $12. And I love that they're all different colors. BE CAREFUL IRONING THEM. make sure you iron them between two thick sheets of cotton. and they can be washed in the washing machine and air-dried.
erickajames
erickajames
Answer 2 years ago
Sure why not! As long as the non woven is durable enough to go through the wash, and you can breathe through it. Definitely feel free to experiment with different fabrics, as not all woven cotton has the same breathability- for example quilters cotton tends to be more breathable than high thread count sheets. Good luck!
ScryMsMary
ScryMsMary
Answer 2 years ago
That is what I'm going to try as my pocket section, then stick a filter inside that. So, cloth, nwpp, filter, nwpp, cloth, essentially. I haven't sewed in years though, so I hope I'm not being overly ambitious!
7
nashvilleknippie
nashvilleknippie
Tip 2 years ago on Step 1
When doing multiple masks, cutting out multiple sets of the pattern from tissue (or wax) paper makes pinning a lot easier. I was also able to cut three sets of mask pieces from two stacked half yard cuts of batik fabric; thereby, pinning once and cutting pieces for six masks at one time.
marissawhitaker83
marissawhitaker83
Reply 2 years ago
I would like to do that as well. Can you please be more specific regarding the wax paper? I have never heard of this. Thanks in advance 🙏
jill.s.horn
jill.s.horn
2 years ago
I’m wondering if someone has measurements from nose bridge to chin and ear to nose or to ear for each size: s, m, l - for the finished mask? thanks in advance!
leahwrenn
leahwrenn
2 years ago
I've made several masks without the filter pocket, but using the pattern pieces posted here. I'm looking at teaching a class in my community on mask making and would like to use the patterns. Is it possible to purchase access to the patterns for use in a community class?
Kiefnmadismom
Kiefnmadismom
Where did the pdf file go??? I went to download and print?? and it says its in the owners trash?? Thanks!
