Introduction: PVC FRUIT PICKER
This fruit picker was designed for oranges, but it works for other fruit also. The body of the picker holds several oranges before needing to be emptied. That speeds up the picking process when there are lots of fruit.
The main feature of interest is the "J" shaped channel at the end of the pipe. One makes a spear-like thrust with the picker to get the fruit inside the pipe. The stem of the fruit follows through the "J" channel. A twist and pull of the picker put the stem at the end of the "J" slot, where a sharp razor blade cuts it. The fruit falls into the head of the picker.
Alternative ways of mounting the pole will be described.
Step 1: SAFETY WHILE HEATING PVC
Give a general description of the StepWe love plastics for what they do for us, but plastic manufacture and decay tend to pollute the environment and negatively affect our health.
Vinyl Chloride, one of the components of PVC, is carcinogenic. When it is locked up in the polymer, however, it is much safer to be around. In my years of experience working with PVC, I have not noticed any adverse effects on my health from being around it.
Always work in areas with good ventilation. If you do get caught in a cloud of smoke, hold your breath and move to clean air.
When heating PVC with a gas stove or propane torch, try not to let it burn. Smoke from burning PVC is bad. With experience one burns it less and less. Don't panic the first time you do burn some. It scorches, but doesn't immediately burst into flame. Move the material away from the flame and try again. Don't breathe the smoke. Smoke avoidance comes naturally for most people.
While heating PVC over a gas flame, keep the plastic an appropriate distance from the flame to avoid scorching the surface before the inside can warm up. It takes time for heat to travel to the center of the material being heated.
Keep the plastic moving, and keep an eye on the state of the plastic. When heated, the PVC material is flexible, like leather. Beyond this stage, you risk scorching it.
A word from James, the plastic engineer -- "Just a word of warning, PVC can handle some high heats but if it catches fire, you wont be able to put it out, it does not need oxygen to burn so don't do this inside".
Another idea from ev372 regarding the heat forming of the bottom in Step 2, "Try dipping the PVC pipe in boiling water in order to soften it. Then fold the bottom fins inward. I used to work for a company that made PVC outdoor furniture and the owner used a water tank with a heating element to soften the PVC pipe and then bend it 90 degrees; worked perfect and no fumes or fire."
I do work inside with the fire technique, but my house is made of cement and has good ventilation. MAKE SURE THAT YOU HAVE GOOD VENTILATION. IF YOU PLAY WITH FIRE, DO SO CAREFULLY.
Step 2: CLOSING THE BOTTOM
PVC is a thermoplastic. It softens with heat and rigidifies again when it cools. This property makes it a useful material for inventions.
Cut the section of pipe you plan to use. In this step, you need to cut "fingers" in the bottom end of the pipe and then fold them over to close the bottom. The pipe, in the finished project, will hold several fruit, but only if the bottom of the pipe is not open.
Cut the pipe as shown, heat it over a gas stove, and press the end against the floor until it cools. All the fingers are bent at the same time, and create a flat bottom.
Step 3: CUT THE "J" CHANNEL
Remember that you will be exerting some force when you pull at the fruit. If the blade is dull, you will be exerting more force. If the blade is missing you can still use the picker to break the stem of the fruit. You don't want to break the picker, so leave as much plastic around the blade as you can, for strength.
To cut the "J" channel, I used a pencil to lay out the design and a saber saw to do the cutting. Files and scrapers are useful for cleaning up the edges.
Step 4: CUT THE BLADE MOUNTING SLITS
Two slits at the sides of the "J" channel hold the razor blade in position. Razor blade replacements slide in from the side and are held by the two slits.
Drill four small holes at the ends of the slits.
Heat the local area to soften it.
Insert the tip of the X-Acto knife into one of the holes and cut across to the other end of the slit. Repeat the procedure for the remaining slit.
Practice first on a piece of scrap material, to get the feel of cutting with the knife. It feels like cutting leather.
Step 5: MOUNT THE RAZOR BLADE
Mounting the razor blade is a little difficult. Be careful to avoid cuts.
You have already gained some experience heating and shaping PVC when you folded the fingers that close the bottom of the pipe. This step calls for more precise heating. You will need a propane torch. Needle nose pliers are also useful, for holding the razor blade during insertion.
I made several of these pickers and modified one of the razor blades to use as a tool for forming all the slits. I ground off the sharp corner of the blade so it would enter the slit more easily, without snagging on the plastic.
After making the slits in the plastic, the plastic will probably have cooled and hardened up again. Bring the local area back up to temperature with the torch. Keep the flame moving to avoid scorching areas.
After the blade is mounted, cover the exposed blade ends with electrical tape to prevent accidental cuts.
Step 6: ATTACH THE HANDLE
By now you know the basics of heating and forming PVC. The mounting bracket below is made from the same diameter pipe as the base. Heat the central area with the torch to soften it. Press the soft plastic around a section of handle pipe with blocks of wood until it cools. Pop rivet it in place.
The pole is held in the bracket with a single sheet metal screw.
Step 7: ALTERNATIVE WAYS TO MOUNT THE POLE
These alternative ways to mount the pole are maybe not as elegant as the molded plastic bracket.
They are, however, lighter, faster to make, and suitably strong.
Flatten the end of the metal pole to keep the pole from rocking sideways.
One picture shows the use of a bolt at the end of the pole and a wire wrap further down.
The other picture shows the job done using only wire tying techniques.
Depending on factors of time and materials available, choose the technique you prefer.
Finalist in the
Get in the Garden Contest
1 Person Made This Project!
- borgem made it!
108 Comments
Tip 9 months ago on Step 7
I think instead of closing the bottom you should just drill holes about 1 inch from the bottom all the way around and thread paracord through the holes in a cross/weaving pattern to make a net so the fruit is cushioned and can't fall through...
Reply 9 months ago
Oranges are tough, but I like your idea. It eliminates heat forming for the bottom tabs, which might be intimidating to some first timers. Of course, one still has to attach the pole somehow, as with rivets or tie wire. Either way, it's still good to learn heat forming.
4 years ago on Introduction
I don’t understand why an hour or Teo is spent cutting and heating th PCs just to close the bottom.
Drill Teo holes across the pipe, insert a piece of coat hanger, and in Teo minutes you’re done. Oranges can’t fall through with the wire across.
Reply 4 years ago
Spellchecker got me. An hour or two, not Teo.
5 years ago
Sugiro uma alternativa para seu projeto: o PVC poderia ser mais curto, o que não prejudicaria a fixação de um cabo na lateral. Na parte inferior poderia ser adaptado redes (iguais a de basketball).
9 years ago on Introduction
I dip the portion of pvc to be shaped into boiling water. No fumes, no fear of burning, a little slower, perhaps
13 years ago on Introduction
you should try and make the bottom swing open like a trap door so you don't have to awkwardly pour out (in a figure of speech) the fruit and maybe put wires that it slides down like the contraption in the movie Fracture with Antony Hopkins but a lot steeper.
or you could leave the bottom part open and add a bigger bucket (like a coffee can or small trash can) underneath it with the pole going threw the middle. the fruit would fall through the picker into the catch bucket.
Reply 13 years ago on Introduction
You have a good imagination. Personally, I don't find the pouring out of the fruit to be an awkward maneuver. It takes a little practice, I guess.
I'm thinking you could attach a chute to the bottom of the PVC that would allow the fruit to fall through and gently drop to the ground. You could use a slightly stretchy fabric to make a tube shape. The friction between the fruit and the fabric would slow the fall and keep it from bruising when it hits the ground.
You could use plastic dryer tubing and wrap it around the pole loosely.
I think the cloth tube would just snag on branches and get in the way. You can give it a try, though.
10 years ago on Step 7
This is the smartest and most efficient fruit picker. Thank you!
Reply 10 years ago on Step 7
My thanks to you! Positive feedback is always nice to get.
12 years ago on Introduction
You are genious
I have key limes and would love to make one of these. For the limes, what size (circumference) would you use. You could use the same size as yours, but it could be lighter weight if smaller. But then if it is too small, it would be harder to cut the J, or set the blade in. What do you suggest?
Reply 12 years ago on Introduction
This design can pick fruit without the razor blade. It just rips the stem out sometimes. Sometimes it doesn't. So, I would pick a pipe size that looks appropriate to you for the size of the fruit to be picked. If you can mount a razor blade, great! If not, tough luck, but you can still pick fruit with it.
cool idea, I want to build this but all I have are avocados and I think those would get stuck a lot due to their shape.
I have made pickers that work on avocados. The one I use now is a rebar loop at the end of a pole, with a fishnet bag to catch the avocado. It has an elongated area at end of the rebar loop that presses on the top of the avocado as you pull.
I just bought a house with a HUGE avocado tree in the yard. Does the elongated area of rebar cut the avocado stem? Or are you pulling on the fruit itself? Do you have a photo you can share? Thanks for a great instructable.
