Introduction: Pallet Chair
In this instructable, I'm going to teach you step by step how to make a recycle wooden chair, with the Pallets.
You can use it like decoration for the inside or outside of your house, if you want to use it outside, you'll need to cover the chair with some protection like varnish.
Step 1: Get the Pallets
First of all you have to count with the material and the tools that we need.
To make a chair you will need two Pallets, you can get it from supermarkets or something like Home Depot.
To make the work more simple, its better get Pallets in good conditions it will be easier give it the ending we want.
Step 2: Tools
To make the chair we need this tools.
- Wood Cutter
- Hammer
- Drill
- Screwdriver.
- Nails
- Screws
- Sanding Sheets
Step 3: Cut the Pallets
Now, we have de Wood, we have to cut the Pallet by the Half, But we need to consider the base of the pallets, so the chais can support a person.
Now we have two pices, one of this pieces will be the sitting area and the back.
Since this cut, the part of the back, you need to cut the junction diagonally, this to create a degree of inclination and the chair will be more comfortable.
The latest cuts are in the second pallet, these will be for the elbow, I'm afraid I do not have pictures of this step... however, is very simple, it is only necessary cut it in half again but this time trying to make a small Pallet , that is, like a square and should has a good support.
Step 4: Detailing Wood
Once the wood is cut to the necessary measures, sanded so there are no splinters and chair look much better.
Step 5: Put It All Together
In this part just all the pieces fit together to create a better bond between these parts, extra wood is placed on the back of this form will support more weight without the risk of breaking.
For the case of the elbow is the same procedure, bind to the seat and back with the help of nails and screws at different points to support the chair while the weight of the person.
Step 6: Finished
The finish that gives this chair is a rough finish, a brown tone to the wood look better, they can give you the finish you want but in this case chose the rustic finish.
Combining Wood Varnish 1/4L and 3/4L from Tiner, with the help of a tow,
Surgical masks and gloves (for security)
Bast in the mixture is wetted and applied to all wood.
Immediately the wood takes on the color of the mixture, however, you need to let it dry that will not ruin the clothes of those who sit.
