Pizza Phone Holder IPhone5
149
Introduction: Pizza Phone Holder IPhone5
Our main idea was to make something handy to hold a phone or iPad up whilst watching something, filming or basically just a tripod. Of of our main objectives was to make It aesthetic, so we decided to make it a pizza slice phone holder
Step 1: Materials
Hot Glue Gun
Something To Cut Wood Precisely
Box Cutter
Wood vMarkers / Colouring Supplies
Brown Paper -Optional
Step 2: Step 1
We did our steps simply, Starting by first cutting pieces of triangular wood.
First of all, you must get a small piece of wood (triangle isosceles) measuring 11.5 cm for the top and the two sides will be 13 cm. The width is about 0.5 cm to 1cm.
Step 3: Step 2
You will need two rectangular pieces of wood, 2 cm wide and 11.5 cm long to match the sides of the triangle
Step 4: Step 3
Once you have the pieces of wood cut out, you can place the two rectangles on the triangle’s sides vertically, place them on any ways that are good for you and fit your phone.
Step 5: Step 4
Step 4 is that a smaller rectangle measuring the same width as the others, just 8.5 cm long, for the top of the isosceles triangle. Place all the rectangles on the triangle vertically and get them in a position to hot glue.
Step 6: Step Six : Prepare to Glue
Now all the sides are on the triangle whilst the hot glue gun is heating up. Maybe measure to make sure the sides are balances and ready to glue.
Step 7: Step Six, the Hot Glueing
Now the wood is ready to get hot glues together, as you see we first did the top side and afterwards to sides. We put a little bit of glue in ever slit and held it together to dry.
Step 8: Step 7 the Finish Result (Almost)
Now the phone can fit and stand up nicely, while you can watch or film, it is basically a tripod.
Step 9: The Finishing Copy
You may add different designs on the wood with markers, pencils and different colouring materials.
We hope this worked out for you, or if you haven't tried it, go ahead and do it, because this little phone tripod is so aesthetic and handy!
Be the First to Share
    • Anything Goes Contest
