Introduction: Purple Color-Changing Pajama Squid Figurine
I've been making these baby squids for years and recently wanted to make them temperature-reactive. When I found out their colors could range to a purple-brown, I just had to use some purple pigment in them! If I were to remake these, I would use a colorless-to-purple pigment instead of purple-to-pink. I made a more fantastical version of them with colorless-to-blue pigment to test how it might look. These work great just as figurines, or can be attached to jewelry findings to make pins or pendants.
For this project, you will need:
- Translucent polymer clay
- White polymer clay
- Temperature-reactive pigment. This can be substituted with UV-reactive pigment.
- Liquid clay or Bake-and-Bond
- Black micomarbles (these can be found with glitter or nail art supplies)
- Xacto knife
- Needle tool
- Dotting tool
- Blending tool
TIP: To keep your white clay looking cleaner from dust and lint, mix equal parts of white and translucent together. I find that the brightest white clay is Premo frost white glitter, which is used here.
Step 1: Making Color-Changing Clay
Flatten a disk of translucent clay
Mix a bit of liquid clay and color-changing pigment in the center of the translucent, and fold within the clay
Keep mixing until the pigment is uniformly distributed
Set aside a bit of the purple clay for the eyes
Shape the colored clay and white clay into equally-sized rectangles
Stack the two colors
Step 2: Creating a Stripe Clay 'cane'
Flatten the clay, keeping it in a rectangle shape
Cut the clay in half, and stack the halves, creating 4 layers
Flatten and repeat
Step 3: Creating a Stripe Cane
Keep cutting and stacking the stripes until you have enough layers. Be cautious of creating too many layers or the colors will blend together and loose the stripe pattern.
Remember to keep shaping the clay into a rectangular cube to create a cane.
Step 4: Creating the Body
Slice your cane into sheets and select the best looking slices.
Reserve a lesser-perfect looking slice for the arms.
Step 5: Creating the Body
Take one of the imperfect slices and form it into a dome. This will fill out the body shape
Place a stripe sheet over the body, and shape it around the dome. Round out the top corners.
Use a dotting and blending tool to create small ruffles around the top of the pajama squid.
Step 6: Adding the Arms
Take the sheet of clay reserved for the arms and slice it in half.
Slice this half and split it into 10 parts: 8 arms and 2 tentacles (here I only made eight)
Roll out these parts to a taper on one end
Step 7: Shaping the Appendages
Blend each arm to the body.
Curl up the ends of each arm.
If the there is difficulty sticking the clay together, add a bit of liquid clay to help blend the arms to the body.
Step 8: Adding Eyes
Use the dotting tool to create eye sockets.
Fill the sockets with liquid clay.
Take the bit of purple clay reserved from earlier and roll it into two equal sized balls. Place the balls into the sockets.
Step 9: Eye Details
Use a needle tool to create a place for the micromarbles - this helps with keeping it from sliding in the liquid clay.
Coat the eyes with liquid clay.
Add one micromarble to each eye.
Set your pajama squid aside to bake. I use an index card over a small silicone loaf pan.
Step 10: Baking and Finishing
Bake according to your clay packaging directions. Typically it tends to be around 275°F or 130°C, but be sure to read the directions on your clay specifically. Sometimes I use a clay that bakes at 120°-130°C, slightly lower than the regular temperature.
hint: Be careful to bake your clay thoroughly. Under-baking causes crumbly clay! Also watch your oven and beware of burning!
Once your piece is completely cured, add a few layers of gloss glaze, and you are done!
[once it is edited, I will embed a video of the squid changing colors in ice and warm water]
Runner Up in the
Colors of the Rainbow Contest
9 Comments
1 year ago
Adorable!
Question 2 years ago on Step 9
Where do the purple eye balls come from? Were they supposed to be made and installed in the previous step?
Answer 2 years ago
Whoops, yes, you're supposed to reserve some clay initially and roll out two balls later on. I didn't when making this one and forgot to mention it between having to recolor some clay and actually doing it correctly remembering to leave out some extra clay for the blue one 😅 - thanks for catching that. I'll add an edit on this later today!
Where did you get the thermo reactive pigment? It is so awesome.
Answer 2 years ago
Thank you! It's from Solarcolordust!
2 years ago
I love the detail. I've always admired work that is a clear mix of skill, patience and beauty. Great job!
Reply 2 years ago
Thank you for your kind words!
2 years ago
Really nice job on this little squid! I'm impressed you can get such nice color lines as it seems you really only have one shot once you get the clay layered right :)
Reply 2 years ago
Thank you!! I thought I did one stacking round too many for the photos, but was relieved when there were a few good options in the center of the block!
