Introduction: Put-together Pot
This is a flowerpot made out of a soda can and some solder.
Do not drink out of the can because a piece of solder might suddenly fall off and possibly choke you,
and it may have sharp edges.
It can be used for a plant pot or to hold a flower. It is put together using random items I found lying around, this gives it it's name.
Step 1: You Will Need:
An empty soda can
A soldering iron
A lot of solder
Jumper wires
Tape
Sandpaper
Wire cutter
Other totally random items (anything you like)
Step 2: Cut the Top Off the Can and Fill It With Patience
I'm serious. You will need a LOT of that stuff.
Step 3: Sand It
Sand the sharp edges so that they lose their sharpness.
Step 4: Cover It in Solder
Then use the soldering iron to melt it so it sticks.
This is to cover the sharp edges.
Step 5: Poke a Hole in the Side (near the Opening)
This is to attach the handle. Do the same to the opposite side.
If this is going to be a plant pot you can make a hole the bottom so that water can drain out.
Step 6: Solder a Jumper Wire (a.k.a Handle) to the Holes
Put a lot of solder to make sure it does not break.
Step 7: Cover the Solder With Tape
This is to hide the messy mess of solder.
Enjoy your randomly put together pot.
HAPPY NEW YEAR!!!!!
