Introduction: Rainbow Lace Candy Puppy Design
If you love paint by numbers, you will love making this type of sweet artwork. You can really take any photo and create a masterpiece with these easy steps.
  • Lace Candy in your choice of colors
  • Corn Syrup
  • Jolly Rancher
  • Confetti Sprinkles
  • Black Colored Sugar
  • Chocolate
  • Spatula
  • Scissors
  • Image - I purchased this one on Amazon - https://amzn.to/2IbCUa1
  • 2 sheets of Plastic Acetate
Step 1: Gather Your Supplies
The actual supplies you will need will be based on the image you want to recreate. I used mainly Lace Candy because I wanted to create the long fur effect on the puppy. The corn syrup is used to "glue" down the lace candy.
Step 2: Start Building the Design
Cover your image with the plastic acetate sheet. For the eyes, I shaped the Jolly Rancher in the shape needed.
Then in order to "glue" the Lace candy strips together I used corn syrup. Spread a thin layer onto the acetate - do this in sections or the corn syrup will dry out. Do not cover the entire acetate with corn syrup in one step. Once you've spread the corn syrup using the offset spatula, start laying down the lace candy as needed.
Step 3: Continue "drawing"
Using the appropriate laces continue coloring the design. Add some black sugar for the eyes and a couple of white confetti sprinkles for the glimmer in the eyes.
Step 4: Flipping the Image
Once you complete the image, everything is kind of stuck to the acetate. So you'll need to flip the image onto the other acetate sheet. To release the lace candy (which was glued to the acetate), it's best to use a plastic spatula or a plastic scraper. Slowly release the plastic while holding the image down with the plastic spatula. You may have to rinse the spatula occasionally to get the corn syrup off. Also, do not pull the acetate straight up, gently roll against the image. After you remove the entire acetate, take more corn syrup to cover the entire image. This will help glue the laces together and it help with the chocolate (in the next step) from seeping through.
Step 5: Melt Chocolate
Melt the chocolate in the microwave in 30 second increments, stirring occasionally to make sure you don't overheat it.
Step 6: Chocolate Backing
Take the melted chocolate and pour on the back of the design. Spread it out using the offset spatula. Allow to set.
Step 7: Enjoy!
After the chocolate has set, flip the image once more. You can leave it as is, or you can spread one more thin layer of corn syrup on top to seal it.
The possibilities are endless in creating this type of design.
Now that you've completed this sweet artwork, will you want to eat it?
