Introduction: Rare Earth Magnets From Old Hard Drives
It happens to all of us eventually.
You've upgraded your laptop from that ancient cinder block to a sleek new light weight model.
You got a new desktop PC to replace the one that was so old the keyboard was in Sanskrit.
You have moved over all you family pictures, every song you've collected since high school, all those movies you download ... completely legitimately .. *cough cough* .. no really ... OK ... moving on
So what do you do with the Hard drives you removed before sending the rest of your old computers to be recycled?
I'll tell you what to do .. You grab your tools and gut them for the glorious rare earth magnets (As well as a few other goodies) that are hidden inside.
Step 1: Tools
Hard drive dock / Hard drive USB adapter - If you haven't already transferred your data off of the Hard drives, now would be a good time.
Screw driver / Torx drivers - depending on the manufacturer some screws will be phillips head. Most will be torx, usually between sizes T6 - T10
Pliers - for those parts that need to be "encouraged" out of their original positions.
Step 2: Those Sneaky Buggers
I have yet to find a manufacturer of Hard Drives that doesn't hide at least one screw under the label or some other sort of sticker.
Some will even hide a screw under a sticker ... that is hidden under the label. WTF!
It's like they don't trust us or something.
Once you have all the screws removed you can lift off the top cover. Some manufacturers will use a sticky gasket under the lid so you may need to apply a little force to get it to pop off.
Step 3: Just Like Playing Operation
Once you take the top magnet off the reader arm, you can now swing the arm far enough out of the way so that you can remove the platter(s) after you take off any screws securing it in place. Typically there will be one to three screws securing the platters, but I have seen as many as ten screws on a hard drive from a raid array.
The reader arm is typically press fitted into place so you can pry it out with a screw driver or encourage it to relocate with your pliers.
Now you can unscrew the bottom magnet from the Hard drive case.
You should now have a top and bottom magnet, as well as one or more platters and possibly some aluminum spacers.
Step 4: Laptop Vs Desktop
The Hard drives from a desktop PC will have similar parts to those found in laptops. Right down to the fact that they love hiding screws under the labels and stickers.
The major differences will be that the magnets will tend to be larger and stronger, and the platters will be slightly larger in diameter.
Step 5: What to Do With Your Salvage
Typically I will leave the magnets on the metal plates that they are glued to for several reasons:
It makes them easier to handle in my opinion.
The magnets are relatively brittle and can break easily once off the metal backing, especially if they smash into each other.
These magnets are ridonculously strong and if they are flat on a metal surface (like the side of the fridge) the odds of you lifting them off are slim at best. Most times you will need to slide them off an edge to get enough leverage. The backing will usually keep the magnets from sitting flat on a surface so your odds of lifting them off is fairly good.
**CAUTION** When handling these magnets there is a very real risk of damage to your favorite body parts (fingers, toes, other protruding bits) if they are caught in between two of these magnets during magnet mating season (whenever two magnets get close enough to attract each other). I have been careless in the past and my life lesson was a wicked pinch that drew blood on one of my fingers. Fortunately it was a set of the smaller magnets. Had it been the big ones from the server hard drive it is very possible I would have had a broken finger, or a chunk missing.
I have found a few uses for the platters
They make a great mirror. The hole in the center makes them easy to hang up in a cubicle with one pushpin.
You can hang them up to twist in the wind in your garden to help keep birds and small animals from wrecking your crops.
They make great precision targets. See how many shots you can land in the hole in the center. If your aim is not true you will see one of two results depending on what the platter is made out of. If you have an aluminum platter you will hear a distinct ring as you make a new hole in the platter. If you have a glass or ceramic platter with an aluminum coating .. it's time to head down range and hang up a new platter.
Use one to make a head reflector for your physician's costume for the next Halloween party.
3 People Made This Project!
- igorpkc made it!
- Sekretmastera made it!
64 Comments
5 years ago
Thankyou with all the Best wishes to you all. 73. This is VU2VIZ
Reply 2 years ago
VU2VIZ,
this is KA8KRV here in Michigan. I have used these magnets to hold my gun in place while driving. It is more comfortable than keeping it in my legal holster. 73 to you and your family.
5 years ago
For many years I collected and stored many electronic parts from these digital electronic devices. They aer so excellent for many many scientific and electronic projects.... Congratulations colleague!!!
: D
5 years ago
Another use for the magnets is to stick one on the side of your drill press to hold the chuck key.
6 years ago
FYI, I have used a heat gun to loosen the glue that holds the magnets to the brackets. I can usually get them of the bracket without breaking them. Then i can glue or attach them to my project. :)
These are great magnets
Reply 6 years ago
the heat gun is a great tip. thanks.
6 years ago
I reuse the cases. They're sturdy and conduct heat well. I also save the PC boards to pull components off them. You should be able to run the motors using the drivers on the board.
I haven't found too many uses for the bearings, which is a shame.
You can get cheap torx screwdrivers from Harbor Freight.
Reply 6 years ago
I want to build a propane forge (just haven't gotten around to buying the parts i need)so I can smelt down the cases and use the aluminum for other projects.
you can get cheap torx from HF .. but I would recommend spending a few extra dollars and get a higher quality set only because when you are dealing with torx as small as 5 or 6 the cheaper drivers will shred to uselessness fairly quickly. Once you get up to size 9 or 10 the cheaper driver has enough bulk to last for quite a while.
Reply 6 years ago
I melt them down. The 3.5" drives yield about 12 ounces (340g) of good quality casting alloy, and it's a very secure way of erasing data from the platters. I disassemble them first, it avoids contaminating the melt with copper, and I get the magnets intact. Sometimes, I need to use a pin punch to drive out the main motor hub. However, there are usually a couple of small, pressed in steel pins or bushings that are hard to get out; they just sink to the bottom of the crucible when the rest melts.
2.5" drives have much less, maybe 50g of aluminum. All the 2.5" drives I've dismantled had glass platters. Some were rivetted, rather than having screws. I just cut them in half on a bandsaw, then shake out the innards.
Dispose of the electronics bits responsibly, not just in the landfill.
6 years ago
I have lots of these,a pair from a old 10 thousand rpm SCSI drive ,hold the door shut on my snow blower shed
Reply 6 years ago
and he hasn't been able to use his snow blower ever since .. lol
Reply 6 years ago
too funny,, it was close a few day had to get the wife to help me get it out ,lol
Reply 6 years ago
And his snowblower always points to the North!
Reply 6 years ago
Those old IBM scsi drive magnets are insanely powerful our household 'cookbook' recipe collection is about 40 sheets of paper hed to the side of the fridge with one. I recently hung a 5 lb bag of limes from our metal wire-rack shelves with one.
6 years ago
These magnets are useful for every thing
6 years ago
А теперь обратно собери.
Reply 6 years ago
And the monkeys have no tails in Zamboanga...
Reply 6 years ago
I don't get that reference
Reply 6 years ago
It's a nonsense song from a Leave It To Beaver episode - sung by Gus the fireman when Beaver was hanging around the fire station...
I just felt it was as constructive as the russian comment I was replying to and couldn't make sense of because I can't read russian.
Reply 6 years ago
ok gotcha. according to google translate, zottosfv said "and now back to gather" .. I guess he is planning on collecting magnets :)
