Introduction: Real Leather Black Wallets With 4 Card Holders and Has a Logo on It
this a wallet that can fit many cards but it is designed to hold 4 cards and cash and can be used anywhere and has my logo on the outside and made by and Jad Hammoudeh and the person who it is designed for
leather
exacto knife
lighter
wet/alcohol wipes
sawing machine
laser cutter
Step 1: Laser Cutter
cut leather, place it in the laser cutter import the design to the laser cutter and add designs that are wanted. for me, I put my logo on the outside that was designed on the computer and the link is put as an attachment for the inside I put made by Jad Hammoudeh that was designed on the website Photopea but any design can be put and in some of the other wallets I also added the name of the person it was designed for which was also designed on Photopea
Step 2: Front
when the print is done take out the leather pieces and align them as they are supposed to be then remove the outer 2 pieces and mark a spot exactly on the edges of the 2 pieces under that would be drawn on the 2nd biggest piece.
bring the sewing-machine and place the 2nd biggest piece and the smallest piece and align them as drawn by a mark indicator and start sawing the bottom line by a very small distance between it and the edge. Then cut the last bits of the string and use the lighter to lock the string in place
then bring the piece that goes over it and saw as it is supposed to and cut the last bits of the sting and use the lighter to lock the string in place
repeat the same thing for the other side
At that point, you should be able to put some cards in the wallet
Step 3: Back Piece
then flip the leather over to the other side and start sewing the edges but what we need is that to keep a small gap on the bottom for it to be able to fold and then don't sew it from the top for us to be able to put cash in it
cut the last bits of the string and light it up to lock in place
Step 4: Poliching
remove the label from the marker by using alcohol wipes or sanitizer wipes and wallet is done
