Introduction: Rechargeable Battery for Lego Mindstorm NXT Any Version
WARNING: polarity must be check 3 times to make sure before connecting battery think of this as one shot deal. These will effect warranty on product so if u got warranty don't try it PLZ. If you really want to do it go a head to next step.
Step 1: Materials
The material u will need are:
1. Any rechargeable battery pack you have or you can get
NI-MH adn NI-CD batery are acceptable
make sure they are 7.2 volts NOT over
i recommend NI-MH battery
give better run time
2. connection
RC 7.2V Battery Pack Connector Repair Kit
you can get it at radioshack or any broken charger or Toy
3. Last thing is the NXT robot
Step 2: Solder Connections or the Way You Want to Do It.
Connections: solder the connections to the battery holder on NXT as shown in the picture
before you solder them make a nod then solder them into place.
Step 3:
Make double or triple check that the connections are in the right polarity before connecting the battery. these will save you $50 on battery from lego and it might even save you shipping.
In total these should be $25 or nothing if you already have the battery and the other stuff.
video
http://www.youtube.com/watch?v=29Rn4AEwP_s
4 Comments
11 years ago on Introduction
apparently, the nxt is designed to run on up to 10 volts. I cannot remember where I read this. I believe the rechargeable batteries that actually are made for the nxt are 10 volts.
Reply 11 years ago on Introduction
Not sure cause i mean it uses 6 battery they are 1.5 v each that would equal 9 volts there possibilities that can go up to 10 v. Not sure there little risk there you're choice I go by my experience on other things that Ive done.
Well, I did some research. It is charged by a 10v dc charger. I am guessing this indicates the maximum voltage the battery can be. Although the nxt works on nine volts, it probably can withstand a little more. Source: http://www.amazon.com/LEGO-NXT-Rechargeable-DC-Battery/dp/B003VT952G
makes sense kinda but sure you could be right.
