Introduction: Ribbon Hair Clip in Sky Blue
Tutorial on how to make ribbon clips again. While this time the ribbon hair clip is of organza ribbon. And the color of sky blue makes you pure and sweet if you wear it to decorate your hair.
To make the ribbon hair clip you need to make a bow out of organza ribbon first. Then add a clip to the bow, a fantastic hair clip is done from how to make ribbon hair clips.
Step 1: Step 1: Stick the Ribbon
Make the materials well-prepared. Cut a ribbon of 20cm; stick a double-sided tape in the middle. Fold the ribbon to make the end sticked.
Step 2: Step 2: Make Layers of Ribbon
Cut the other two folded ribbons: one is 18cm; the other is 16cm. Place the three pieces together with the longest at the bottom. Bind the three ribbons with iron wire in the center.
Step 3: Step 3: Add a Clip
Take out a clip. Glue the clip to one side of the ribbons. Cut a ribbon of 10cm; thread it through the clip.
Step 4: Step 4: Make a Knot
Knot the ribbon to the reverse side of the clip. Tie up the knot; unfold one end of the ribbon. Fix the knot with melted plastic stick.
Step 5: Step 5: the Ending Work
Unfold the other end of the ribbon and glue. Then a hair clip is done.
