Rings and Chain Fidget
Intro: Rings and Chain Fidget
This Instructables you will learn how to make a fidget tool. This tool will help people that have a hard time sitting still.
STEP 1: Rings and Chain Fidget
What you will need
- Bike chain
- Two key Rings
- Chain breaking tool
- 2 to 4 Rainbow loom rubber band. (Personal prefers if and how many to use.)
STEP 2: Breaking the Chain.
Using the chain break. Break bike chain into two, one outer link and one inner link.
STEP 3:
Break the chain so you have 4 outers or inners that are the same. Outers/inners make the Fidget behave differently.
STEP 4:
Take two of your outers/inners and put them on the outside of your link piece. Run the Keyring through the eye hole of all 3 link pieces(the 2 outers/inners and one link pieces)
STEP 5:
Take the chain break and remove the pin. Back the chain break out slowly or the bushing will fall out. Rubber band links together then run keyring through eye hole.
STEP 6:
Link all rings together. Overlap the rings by feeding one ring over the other and your done
35 Comments
SylvainM8 7 years ago
what is that made for ?
koof549 1 year ago
a person that has adhd 3 years ago
bucklipe 7 years ago
For some people they need a "fidget" to occupy the hands so they can concentrate more thoroughly.
redpanda12 2 years ago
beverlyaa 5 years ago
This looks like a great fidget and project. Thank you for sharing! I read that you use a chain for a 1 - 3 speed bike. What size key ring do you use?
sdaluz11 6 years ago
what is the size of the key rings?
stevebarnett 6 years ago
InsomniacOlympian 7 years ago
Anianna 6 years ago
It's the chain for 1 - 3 speed bikes. As I understand it, chains for higher speed bikes have different sized links.
GenerallyOdd 6 years ago
You probably have everything you need to make "the best fidget in the whole wide world"!! Mine is made of copper wire but you can also make it of keyrings!
robypc 7 years ago
Is there any way to take the bike chains apart without special tools?
Jamie JP 6 years ago
robypc 6 years ago
Thanks!
mrsmerwin 7 years ago
I know a few kids who will each want one. Thanks.
piperjon 7 years ago
S0dyP0p 7 years ago
I degrease bike chains with 1:1 Simple Green and water. Drop the chain (or separated links) into a sealed jar with the solution, hand to someone who likes to fidget to agitate the jar for a while, then pull the parts out and rinse. An old chain will probably come cleaner, since the factory lube on a new chain is very resistant to removal.
schaude 7 years ago
Mr_Baier 7 years ago
It is just a bike chain. Nickel plated for rust resistance. you can buy them any where.
