Rusty Junk to Useful Stuff EASY With Chemistry!
Intro: Rusty Junk to Useful Stuff EASY With Chemistry!
Backyard DIY Electrolysis for Rust Removal on Cast Iron and Tools
I'll bet everyone reading this has a secret stash of rusty something-or-other; Granny's Dutch oven, tools left in the rain, a cool garage sale find. If only there was some quick and easy way to return the metal to bright and shiny...
There is. Here's a sweat-free, pain-free method of removing every particle of rust from your rusty junk- using the miracle of electrolysis and some random stuff you probably already have laying around.
STEP 1: Equipment for Your Miracle
Here's what you need:
An automotive battery charger, 10 amps or bigger. A smaller trickle charger will work, but it might take weeks instead of hours to remove all the rust. One with a built-in ammeter is best, so you can tell when you have a good connection.
A plastic tub, bucket or container, big enough to suspend the rusty article completely free of the sides and bottom; you want the solution to circulate freely. You can also line a cardboard box or basket with plastic to hold the solution- anything will work if its sturdy enough and can be lined in plastic
Arm & Hammer WASHING Soda (not baking soda). You'll find this in the laundry detergent aisle.
Steel for the anode- rod, sheet, bar, whatever you have handy or can buy cheap. Old metal junction boxes, pieces of rebar, literally whatever you have. The more surface area the better.
A non-conductive rod to suspend the rusty article from. I used a piece of CPVC pipe, but wood is good too.
Some wire, any kind
STEP 2: Safety First
Do this outside, please.
You will be generating some hydrogen gas and you don't want any explosions in the garage.
Step 1) Fill the plastic container with a measured amount of water- when filled, you will add 1 Tablespoon of washing soda per gallon of water; stir to dissolve. Tip- make the last gallon you put into the tub HOT water, you can dissolve ALL the washing soda in the hot water and you'll get a fast, thorough dissolve.
Step 2) Place the non-conductive rod across the top of the solution container, and wire your rusty article to is so your article hangs completely submerged, but not touching the sides or bottom.
Step 3) Place your anode steel in the solution (the anode can touch the sides and bottom, and it can stick out of the solution too) but make sure it is AT LEAST 2” from your rusty article. Any closer and you will pull too much current on your battery charger and might damage it.
You can use more than one anode, such as multiple pieces of rebar on different sides of the rusty article, as long as all the anodes are electrically connected, i.e. wired together. Using more than one anode speeds up the electrolysis, and you won't have to move and turn your rusty piece during the process, but use whatever is easiest for you. You can also do more than one rusty article at a time, as long as- you guessed it- they are electrically connected to one another and nothing touches.
Step 4) Connect the BLACK clamp of the battery charger to the rusty article, and the RED clamp to the steel anode, and turn on the charger. You can use an extra alligator clip jumper if that makes a better connection to the piece than your regular clamp.
Turn the battery charger on and check the ammeter to see whether or not its “charging”- if not, you may have to scrape a clean spot in the rust so you make a good electrical connection.
Let 'er rip!
STEP 3: Making the Magic
You will see bubbles start to form almost immediately, and an ugly rusty sludge will collect on the surface- all normal.
Every so often, turn off the charger and lift out your rusty piece to inspect how the rust removal is going; take this opportunity to turn or invert the piece if you are using a single anode, to make sure all parts are getting blasted.
The length of time you will have to leave your rusty article will depend on how rusty it was and the amperage of your charger. It will probably take a few hours, maybe overnight to totally remove the rust. It won't hurt anything if the charger continues to run, but it won't help either.
You can dump your rusty, sludgy water on the garden, or save it for your next rust-removal project. * note; if you used a stainless steel anode, you may have generated some semi-toxic byproducts; better to not dump this down the storm drain or into your vegetable garden.*
STEP 4: Yes, You ARE a Genius;
When you remove your work piece the final time from the solution, you will have noticed that instead of rust, your piece is now covered in a sooty black oxidation layer. The easiest way I've discovered to remove this is with 3M Brand GRAY Finishing Pads, available at Lowe's in the sandpaper aisle, but if you need a more polished surface, you may have to work with the softer white scrubbies. It only takes a few minutes to remove the black stuff.
And voila, you have resurrected Granny's Dutch oven with the expenditure of just a little bit of money and the time it took your cauldron to do it's bubbly electrolysis magic.
Take a bow!
100 Comments
dec123 4 years ago
Texas_Mike 4 years ago
I MP 5 years ago
christochandy 5 years ago
cardinalZin 6 years ago
I used this process yesterday on a handful of long-rusted tools. The Washing Soda was tough to find locally but a web search showed that Walmart had some, and they did. Next, my "smart" car charger wouldn't push voltage through what it determined was clearly not a battery. Instead I used a desktop variable DC power supply that I had used to drive an old ham radio--it worked great even at its max of about 16V and 5 amps. I coated all the fresh steel with ACF-50. Great Instructable!
Udon 5 years ago
You can make washing soda out of baking soda.
Sodium bicarbonate (baking soda) decomposes into sodium carbonate (washing soda) at temperatures above 50deg Celsius. So as long as you have pure-ish baking soda (baking powder will go badly...), stick it in any pan, turn on the heat, and wait. You will see the baking soda powder will start bubbling in a weird way, especially as you shake it around the pan. The boiling effect is the powder giving off carbon dioxide. You can't burn it, and just keep going until there doesn't seem to be any more gas coming out, and you're done.
Voila.
Homemade washing soda.
Interestingly, this is the reason why we must be very careful when making cookies or anything that use baking soda as a raising agent. The ingredients need some acidity to react with the alkaline baking soda (and so baking powder has a mix that will neutralize when combined with liquid and exposed to heat). If not, the product will still rise, but a terrible soapy flavor will remain from the now heat-converted washing soda, and hence, we only use baking soda if we are really accurate and follow a tested recipe.
mulapretaz 5 years ago
Braindead63 6 years ago
I'm not an expert, but I think that the anode should be any steel except stainless.
My apologies if I am in error. I make mistakes when it is time for it.
PaulD279 5 years ago
KristinC35 5 years ago
lgroger 6 years ago
marcel-demoulin 5 years ago
Power supply or battery charger is about 12Volt: No danger
DanC66 6 years ago
The charge is so low that it probably won't do you any harm, though you should be wearing rubber gloves if you're putting your hands into water with soda in it anyway. The bigger danger is getting your hands wet and then touching something connected to the mains supply.
Safety first!
osterac 6 years ago
papa-ralph 5 years ago
sreeci 6 years ago
OsterAC,
A battery charger is always 12Volt., with 2Amp and 10Amp output respectively. There are smaller Battery Charges also. But we are speaking about Battery Charger related to the procedure, described by this Auther.
So, coming back to your curiosity, please assume, that the Author i.e.: Cheese Queen was using a 12 Volt battery Charger @ 10Amps.
Please thank the Author as most people have already done.
Thank you, OsterAC
clothier_bruce 6 years ago
A car battery is referred to as '12V', but that figure isn't meant to be taken literally: it depends. When you charge it up the voltage needed is 14 to 15V. Modern chargers are sophisticated electronic devices and who knows what they get up to, but for electrolysis you'd want an old-fashioned el cheapo charger. The maximum current would depend on how expensive and heavy it was: a big one might do around 10A, but I think most bog-standard chargers opted for around 4A. But cheap chargers ( all you need for this ) were just a transformer and rectifier bridge. which gave dirty DC as there was no capacitor. For crude charging this was perfectly OK and also perfectly OK for electrolysis. The disadvantage for a battery was that the voltage output was about 18V open-circuit. This figure also has to be understood: the transformer was 'loose-coupled' so the current became self-limiting - a safety trick. Nevertheless, if the battery was left permanently attached, it boiled dry as these cheap chargers didn't go into trickle-mode. For that you need some electronics. Bottom line: an old cheap battery charger is a lousy battery charger - buy a nice electronic one. But it would be a terrific choice for basic electrolysis.
J DeweyJ 6 years ago
Maybe you should say, or have said, a "car" battery charger. Battery chargers are NOT always 12 volts. I have plenty of batteries, even some SLA ones that are less than 12 volts.
Your method of removing rust certainly is interesting, but I prefer a soft wire wheel on a bench grinder or drill. A lot faster, less trouble and less mess.
