Introduction: SPACE!!!do We Really Know?
INTODUCTION
I Abhinandan Pal of class 8 (don't go away seing my class).I have some space theory of mine I have been helped by Rathindra,Saptarshi & Arpan of my class to make it. I have been specially helped by my cousin elder brother Sagnik ghosh and some of my teachers.
Let me clear a thing we say space is infinite but we don't know what is infinite in it (please neglect the spelling mistake or you can take them as fun)infinite means some thing whose end is not known by mankind it does not mean that it has no end .I want to write what I think of SPACE and some of my theories .IF you like it please FOLLOW me.
Hear is the description of infinte according to wikipedia it a little different from my one and is just for comparison “Infinity (symbol: ∞) is an abstract concept describing something without any limit and is relevant in a number of fields, predominantly mathematics and physics. In mathematics, "infinity" is often treated as if it were a number (i.e., it counts or measures things: "an infinite number of terms") but it is not the same sort of number as the real numbers. In number systems incorporating infinitesimals, the reciprocal of an infinitesimal is an infinite number, i.e., a number greater than any real number; see 1/∞. Georg Cantor formalized many ideas related to infinity and infinite sets during the late 19th and early 20th centuries. In the theory he developed, there are infinite sets of different sizes (called cardinalities). For example, the set of integers is countably infinite, while the infinite set of real numbers is uncountable."
Step 1: Worm Hole
The worm hole if seen from a side or from inside it is a 3D tunnel(cylinder).If seen from front it is a 2D hole(circle).If any one puts his hand on one side of his hole his hand will come out from the other side which are lot away from each other thus you can say it to be a 4D space(time,speed),I think you properly didn't understand what is worm hole by this small paragraph .
So here is the definition by Wikipedia"A wormhole is a hypothetical topological feature that would fundamentally be a shortcut through space-time. A wormhole is much like a tunnel with two ends, each in separate points in space-time. Researchers have no observational evidence for wormholes, but the equations of the theory of general relativity have valid solutions that contain wormholes. Because of its robust theoretical strength, a wormhole is one of the great physics metaphors for teaching general relativity. The first type of wormhole solution discovered was the Schwarzschild wormhole, which would be present in the Schwarzschild metric describing an eternal black hole, but it was found that it would collapse too quickly for anything to cross from one end to the other. Wormholes that could be crossed in both directions, known as traversable wormholes, would only be possible if exotic matter with negative energy density could be used to stabilize them."
Step 2: First Proof of Inexistence
worm hole if it would have existed as many people in the world say but I don't believe.As some scientists say that if an object makes through a worm hole it travels between time or different dimensions.So be it then why didn't we still hear of a person from future with extraordinary gadgets and abilities and why didn't we get a bit of proof about it. May be worm holes still has not formed then how can we dream of time travelling and cant find a worm hole for it then it will be a bad wastage of time and money . Is it good to make a time machine ?If it is made and worm hole also exist but still if some one travels to past and kills some body no one know what will happen to our universe it may even get fully destroyed.If some one comes from future and kills an ant may be the ant was supposed to bite Newton so that he does not fall asleep when the apple fell on his head.then Newton may be asleep and no GRAVITY theory.
Step 3: Second Proof of Inexistence(karmakar Pal Theory)
Let there be two parallel universes or universe of different time period.Let them be called 1st universe and 2nd universe . let there be a worm hole connecting both the universes or time period.So if an object moves into the worm hole it changes into energy and goes out of the other side in almost no time and again gets back into mass.Let the object be of weight 100N(mass is a lot similar like energy,e=mc^2).So if the object passes from 1 st universe(from where it goes) through the vast worm hole which is covered in almost no time and moves out to the 2nd universe(to which it goes).Thus there is a decrease in mass(energy)in 1st universe and decrease of mass in 2nd universe.According to the law of conservation of mass,the amount of energy present in an universe is constant and cannot change.If worm hole would exist by now a meteor or some thing like that will be pulled in by it thus cause a change in mass(energy)of the two universe and make them collapse. As our universe and make them collapse. As our universe has still not collapsed,I have PROVED to you that worm hole does not exist. If it is formed in future our universe will collapse.If it does not collapse then the Law of conservation(The law of conservation of mass, or principle of mass conservation, states that for any system closed to all transfers of matter and energy (both of which havemass), the mass of the system must remain constant over time, as system mass cannot change quantity if it is not added or removed. )is WRONG
Step 4: WHAT IS GOD?
ACCORDING TO BIBLE:-One inescapable fact the Bible presents is that, in contrast to pagan deities, God desires that man know Him. He walked with man in the Garden in the cool of the day (Gen. 3:8). He wants intimacy with man. Galatians 2:16 indicates that God so desired fellowship with man that He "helped" man rather than angels when they sinned. Consider Jeremiah 31:34: "And they shall teach no more every man his neighbour, and every man his brother, saying, Know the Lord: for they shall all know me." Hosea 4:6 pinpointed the problem that Judah was having: "My people are destroyed for a lack of knowledge." Knowledge here is not intellectual knowledge, but the knowledge of intimacy.
ACCORDING TO ANCIENT ALIENS:-Most people believe in aliens - from ancient visitors to modern day extraterrestrials who visit Earth with an agenda. Clearly the creation myths of each ancient civilization discuss alien gods who descended from the sky for any number of reasons,In the duality of physical reality, there would be good aliens and bad aliens - who would have great battles, just as we do while visiting here.
ACCORDING TO ME:- this theory will be published after few days
Explore Science Contest
4 Comments
5 years ago on Introduction
hmmmm intresting but meh i have two ways of traveling through time one of them a worm hole generator
6 years ago
you r a great guy bro...
if u r intetested in researches
go for "first step to noble prize contest"
file your papers and get a chance to go USA
Reply 6 years ago
by the way
from which state u are???
Reply 6 years ago on Introduction
Thanks for commenting and I am from west bengal.IF posibble tell others also about it.
