Introduction: Scary Halloween Ooga Pumpkin
Hey, This isn't a very complex hack but it gets the job done for the season. Last year I carved a pumpkin and put an Ooga horn in it then ran the wires inside the house to a 12 volt apc battery. The results are pretty effective as you can see in the video Im thinking about doing it again this year with a police siren in one pumpkin, ooga in another, and a PA speaker in the 3rd. Also Strobe lights can be fun to add too!
Step 1:
What you need:
1 Ooga horn ($9.00 Harbor Freight)
A length of two conductor wire
1 Pumpkin (~$5.00 Walmart)
1 12V power source (Battery or Adapter with high amp rating)
Some Trick or Treater's
Step 2:
This is really easy so I will explain it step by step.
1:
Acquire a fairly large pumpkin.
Make sure that your pumpkin is carved but not in a way your victims can see your horn.
2:
Connect a long wire to the Positive and Negative Terminals of the Ooga horn.
Cut a small hole in an inconspicuous part of the pumpkin.
Push the wire through the pumpkin from the inside.
Place your horn inside your pumpkin.
3:
Pull your wire to a hiding place where you can see the targeted area and your victims cannot see you
4:
Have a 12 Volt power source ready as this will power the ooga horn (I use a 12V APC battery)
5:
Firmly connect the Positive lead from the horn to the Positive terminal on the battery.
6:
When ready to frieghten people simply touch the Negative Lead from the Horn to the Negative Terminal on the battery.
Thats it!
1:
2:
3:
4:
5:
6:
Thats it!
