Simple Autumn Pumpkin Loaf
Introduction: Simple Autumn Pumpkin Loaf
When the temperature begins to drop and the leaves start to change, pumpkin becomes my favorite ingredient to bake with. That is how the inspiration to bake a pumpkin loaf came about. This recipe is simple enough for a beginner baker and a college student to prepare (as I am both of those things). The goal of this recipe was to make a gourmet-tasting loaf with the baking tools of your average college student. A mixing bowl and a whisk will be the most high-tech equipment you will need.
Step 1: Ingredients
  • 1-2/3 Cups All Purpose Flour
  • 1-1/2 Cups Pure Cane Sugar
  • 1 Teaspoon Baking Soda
  • 1/2 Teaspoon Baking Powder
  • 3/4 Teaspoon Salt
  • 1 Teaspoon Pumpkin Pie Spice
  • 2 Eggs
  • 1 Cup Canned Pumpkin
  • 1/2 Cup Canola Oil
  • 1/2 Cup Water
  • 1/2 Cup Powdered Sugar
  • 1/4 Cup Milk
Step 2: List of Materials
  • 9 x 5 Loaf Pan
  • Mixing bowls
  • Measuring utensils
  • Whisk
Tip: If you don't own a 9 x 5 loaf pan, most grocery stores sell single-use versions of this size.
Step 3:
Preheat the oven to 350 degrees.
Step 4:
Spray the entire pan with cooking spray (i.e. PAM) and coat with a dusting of flour.
Tip: Make sure to coat flour all the way up the sides of the loaf pan to ensure that it does not stick.
Step 5:
Combine dry ingredients in a medium sized mixing bowl.
  • 1-2/3 Cups Flour
  • 1-1/2 Cups Sugar
  • 1 Teaspoon Baking soda
  • 1/2 Teaspoon Baking powder
  • 3/4 Teaspoon Salt
Step 6:
In a separate, large, mixing bowl combine the wet ingredients.
  • 2 Eggs
  • 1/2 Cup Water
Mix until all ingredients are incorporated.
Step 7:
Add half of the dry ingredients to the combined wet ingredients. Whisk until combined. Then add the rest of the dry ingredients and combine.
Tip: By incorporating the dry ingredients slowly the consistency of the mixture will be smoother.
Step 8:
Pour mixture into coated baking pan.
Step 9:
Place in a 350-degree oven and bake for 40-50 minutes.
Tip: Baking time will vary with different ovens, so to ensure enough cooking time, poke a toothpick in the middle of the loaf. If it comes out clean then the loaf is finished baking.
Step 10:
Combine powdered sugar and milk in a small bowl.
  • 1/4 Cup Milk
Whisk until completely smooth.
Step 11:
Turn loaf pan upside down on a flat surface, and tap the bottom until it detaches from the bottom of the pan.
Tip: Use a knife to scrape around the edges of the loaf. This makes it easier for the loaf to detach from the pan.
Warning: The bottom of the pan will still be hot, be sure to use proper baking equipment like baking gloves.
Step 12:
Drizzle icing mixture on the top of the cooled loaf.
Step 13: Conclusion
This pumpkin loaf is the perfect fall treat. It is not overly sweet which means it can be enjoyed at all times of day. In total, this recipe takes 20 minutes of preparation time and 50 minutes of baking.
Be the First to Share
    • For the Home Contest
    • Game Design: Student Design Challenge
    • Big and Small Contest
    2 Comments
    Gadisha
    Gadisha
    3 years ago
    I never had pumpkin bread, but it seems delicious, I'd like to try it!
