Sprouting Chia and Other Small Seeds
204,901
188
28
Introduction: Sprouting Chia and Other Small Seeds
About: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of my instruc…
In this Instructable I will show you how to sprout small mucilaginous seeds. Because these seeds form a mucilaginous coat when soaked in water they can't be sprouted using the usual mason jar method. These seeds are best grown on terracotta, clay or ceramic dishes or trays. If you are familiar with Chia Pets, this shouldn't be a surprise.
Mucilaginous seeds that can be sprouted this way:
  • Chia
  • Arugula
  • Cress
  • Flax
  • Mizuna
  • Radish
Seeds can be obtained from specialized sprouting seed sites (ie; Mumms, or Sprout People).  Chia and flax seeds can be found at health food stores.
What you will need:
  • Growing tray/dish -Unglazed terracotta, ceramic or clay.  Such as an unglazed pie plate, or plant saucers.
  • Clear glass or plastic bowl that fits over growing tray/dish
  • Spray bottle and watering can
Soak dish/tray
Fill dish with water. Let soak for several minutes then drain.  Sprinkle your seeds onto the dish, they should be evenly spread and only a single layer.  There should be space between seeds to allow them to spread while growing. Cover with clear glass or plastic bowl and place in a sunny spot.
Spray
Spray the dish twice a day (I do it in the morning and evening).  It may require more In warmer weather.  Make sure the surface of  the dish is wet at all times but there is no pooling water. Keep covered.
Continue watering
After a few days you can water it by pouring it into the dish from a water can or faucet and then draining it.  The sprouts should stay put.  Again make sure the surface of  the dish is wet at all times but there is now pooling water.
Harvesting
The sprouts are ready to harvest when they are about 1/2 -3/4 inch high which should about 4-7 days depending on the type of seed and time of year (where I live it takes longer in the winter months).  You can cut the sprouts just above the roots and use directly. Or you can also take the whole thing, roots and all, lift off of the tray roots and all and store in a partially closed container in the fridge for up to 10 days ( just cut the sprouts above the roots for eating). Don't water prior to harvesting.
Enjoy
Add your sprouts to a yummy sandwich, wrap, salad or anywhere you would use boring old lettuce!
Gardening Contest
Gardening Contest
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • Game Design: Student Design Challenge
    • For the Home Contest
    28 Comments
    andreabalke4
    andreabalke4
    2 years ago
    I started this and the sprouts are doing amazing, but the roots are sticking to the plate. Is that common?
    ChrysN
    ChrysN
    Reply 2 years ago
    Yes, this is normal, just make sure it is moist.
    OolongJ
    OolongJ
    6 years ago
    Why not eat the roots too?
    Thanks :D
    KevB7
    KevB7
    Reply 6 years ago
    it says you can eat the roots. However, if leaving in fridge for ten days the roots may become too fibrous to enjoy eating
    JoleenH
    JoleenH
    6 years ago
    thanks, I'm going to use the in making bread when I get them sprouted. I usually use alfalfa sprouts. I thought since I have the seeds, this would be just as good and healthly.
    Lynn C Behnke
    Lynn C Behnke
    6 years ago
    Do you you think it would be safe to eat food grade chia sprouted on a chia pet? If I wanted my guests to harvest microgreens from the centerpiece (not just a plate) would I need to buy terra cotta and mold my own? Since the pets are probably not made in the US and are not designed for food production, what might the risks be? Anybody have any thoughts on this?
    ChrysN
    ChrysN
    Reply 6 years ago
    I don't think I would risk it if it is not specifically food grade as they are likely made in China. They also sometimes have a glaze on them and it could be lead based ?. It would be a neat idea for a centrepiece but I think it would safer to make your own.
    Gracedwheels
    Gracedwheels
    6 years ago
    Hola all ~ Chia is one of the mainstays of the Tarahumara tribe of northern Mexico. The Tarahumara are famous for their capacity to run great distances (the farthest clocked was 435 miles) with a happy attitude and a drink made of chia. It is truly loaded with nutrition!
    ArvindN
    ArvindN
    7 years ago on Introduction
    are chia plants safe to eat? where can I find scientific information to support this?
    thanks!
    Arvind
    1st_Balrog
    1st_Balrog
    Very nice instructable! going to try it soon ;)
    I'm usually growing cress in a glas-dish with cotton on the ground and soaking the cotton with water, then placing the seeds on top of it in a single layer.. if this works with chia-seeds too, i'll let you know ^-^
    CityGirl6
    CityGirl6
    9 years ago on Introduction
    Cool, does you cat try to eat them? I can't start anything uncovered because it becomes cat salad.
    ChrysN
    ChrysN
    Yes, he would try to eat it if it wasn't covered, so the bowl is not just to prevent evaporation.
    CityGirl6
    CityGirl6
    LOL, that's what I figured. Sometimes I think I should just grow catnip.
    ChrysN
    ChrysN
    I grow cat grass for my cat but he still tries to eat all my other plants too.
    diane.ostapiuk
    diane.ostapiuk
    You could try crumpled aluminium foil around the plant base or placing double sided tape around areas you don't want the cat. If all else fails there's always this : https://www.youtube.com/watch?v=_cphGWOPi0k&spfreload=1
    ChrysN
    ChrysN
    Good ideas, I love the video.
    When you're talking about spraying and watering the seeds, you say "but there is now pooling water." Should there be pooling water, or do you mean NO pooling water?
