Introduction: Star Wars Thermal Detonator 3d Printed
The mighty Jabba asks why he must pay fifty thousand.
Because he's holding a thermal detonator!
With Star Wars day fast approaching I felt it was only appropriate that my next project was a Star Wars one. I figured that the thermal detonator was the way to go.
There are quite a few examples of replica thermal detonators out there as well as the official Lucasfilm licensed master replicas props, but I've not come across any instructables for one yet, so I've happily obliged.
I used a 3d model created by Oubliette as the basis for my detonator, it's a good quality model that prints well and assembles nicely, the model is available on Thingiverse, also be sure to check out Oubliette's website.
This instructable covers the 3d printing of the prop, the painting (including a handy weathering technique) and the electronics to generate the lights and sounds of the prop.
May the 4th be with you
Step 1: The 3d Printed Parts
The first thing we need are the 3d printed parts, the ones we are using were designed by The Oubliette. The STL file is included here and is also available on Thingiverse.
I printed mine using the following settings on a XYZ DaVinci 1.0:
- Infill: 90%
- Layer height: 0.1
- Supports: Yes medium density
- Speed: Standard
- Shells: Normal
Once you've printed the pieces you'll want to check everything fits, if you find things are a little tight you may want to sand the areas where the different parts meet. Remember that if things are tight now, they'll be even tighter once you've put a few coats of paint on.
Tip: If you don't have access to a 3d printer, you can use 3d printing services such as 3d Hubs and Shapeways.
Step 2: Painting and Weathering
Paint Preparations
To paint the Thermal Detonator and apply the weathering effect, you'll need the following colours:
- Metallic Brass / Gold
- Brilliant Metallic Silver
- Matt Black
To create the weathering effect, you'll need the following additional items:
- Salt
- Water
- Small paint brush for applying water
- Clean and dry toothbrush
Lightly sand the 3d printed parts with a fine sandpaper (P120) to smooth prior to painting, taking care to remove any dust with a tack cloth. I then primed the pieces using an all surface primer and left to dry for a few hours. The top slide switch grip piece is then painted in the matt black.
First Coat of Colour and Paint Weathering
To create the weathering effect we will first paint the main detonator parts using what will be the rust / corrosion colour. Spray the top section, bottom section and main slider piece in the gold / brass. I did a coat of the metallic brass, then after allowing a few hours to dry I followed this up with a coat of metallic gold, immediately followed by another coat of the brass. You will want to want to allow this 24 hours to dry as the paint needs to be 100% dry before the next stage.
The weathering effect will be achieved by using the salt and water. Using a paint brush apply water to the areas that you want to have signs of corrosion, you'll want to focus on areas where moisture and dirt would naturally collect (such as in and around grooves).
Take the salt and sprinkle it over the thermal detonator, you'll find that the salt will stick to the wet spots and begin to crystallise. Once you've covered the wet areas in salt you'll want to leave it for at least an hour to let the salt dry thoroughly.
Once dry you can gently blow off the loose bits of salt, you can then spray paint the rest of the thermal detonator in the final colour. I opted to use a brilliant metallic silver. Allow another 24 hours for the paint to thoroughly dry.
Now comes the fun part, using the toothbrush you can remove the crystallised salt to reveal the corrosion, this should leave you with a fairly good weathering effect. Test fit the assembly again, you'll want to make sure the paint hasn't stopped things from fitting together nicely.
Step 3: Intro to the Electronics
Using lighting and sound on a prop really adds that extra dimension and brings things to life, the thermal detonator is no exception.
To re-create the light effects we will be utilising the following items:
- 1x 08M2 PICAXE Microcontroller
- 3x 3mm Yellow LED's 2.1v forward voltage
- 1x Red LED 2.1v forward voltage
- 1x 10Ω Resistor
- 4x 120Ω Resistors
- 1x 100nf Capacitor
- 1x Roller-switch
To re-create the sound effects we will be utilising the following items:
- Adafruit FX Mini Sound Board
- Adafruit 2.8W Class D Audio Amp
- Visaton K50 8Ω Speaker I'd recommend using a small profile speaker to save space
Alternatively Adafruit also have a combined sound board and amp, though stock is limited as I believe the item may have been discontinued.
The whole thing is powered using a 4.5v battery source, I used 3x AAA batteries for testing purposes and these are replaced with 3x N batteries in the final assembly to save space.
Experimental: I've included some PCB design files for the circuit. One design is intended to use serial communication with the soundboard to trigger sounds, the other uses the GPIO based triggers. It also includes a tilt switch and a DIP switch to give more functionality. More info to follow once I get the chance to build and test...
Step 4: Lighting and Sounds
Circuit Assmebly
The circuit is assembled as per the schematic provided. The on/off switching is achieved using the roller switch. When the top slider is slid back to reveal the red LED, the roller switch opens. This closes the circuit, activating the lights and triggering the sounds.
Batteries
You'll find that the batteries are one of the more troublesome aspects of the build. You'll need something small enough to actually fit inside the Detonator enclsoure, but also large enough to operate the electronics for a suitable length of time.
AA and AAA batteries are too large to fit inside the enclosure, so I opted for the smaller N batteries. I recommend using a battery holder like the one shown in the photos as it will make changing flat batteries easier. But as I was in a hurry, I soldered my wires directly to the batteries.
Flashing Light Sequence and the PICAXE
The yellow flashing lights on the front of the detonator are designed to replicate the pattern and timing of the movie prop. It only appears on-screen in ROTJ for a few seconds so the start of the light pattern is replicated from the movie scenes, the rest of the pattern is taken from the Master Replicas prop. This light sequence is achieved by using a PICAXE microcontroller, the code I used to program the chip is provided below. I happened to have a spare 18 pin PICAXE to hand so I used that in my build, but to save space I'd recommend you use an 8 pin chip instead. The code below is intended for a PICAXE-08M2 wired as indicated by the circuit diagram.
Main: high c.0 low c.1 low c.2 pause 2000 high c.0 high c.1 low c.2 pause 2000 high c.0 low c.1 high c.2 pause 2000 low c.0 high c.1 high c.2 pause 2000 low c.0 high c.1 low c.2 pause 2000 low c.0 low c.1 high c.2 pause 2000 high c.0 high c.1 low c.2 pause 2000 low c.0 high c.1 high c.2 pause 2000 goto main
Soundboard
The Adafruit soundboard is surprisingly easy to program. Triggers are set by simply naming the audio file, using a file name format that corresponds to the relevant trigger switch. For more information follow the tutorial on Adafruit. I've only utilised the main detonator sound effect, but it is also possible to add additional effects (i.e. detonator explosion when the prop is shaken) through the addition of tilt switches etc.
As an alternative to the adafruit sound board you could also use a PlecterLabs board that's pre-loaded with a Thermal Detonator sound font that includes various other effects and features.
Assembly
The most complicated part of final assembly is actually getting everything to fit, be as conservative as possible with cable lengths when soldering everything together, you want to minimise unnecessary usage of space as it gets very tight in there! You'll see fromt he photos that I wasn't particularly neat and my strip/vero board is quite large, but even so everything fits.
I placed the components into my detonator enclosure in the following order:
- Amp at the bottom - it is the narrowest so it can sit nearer the base of the curve
- Soundboard next
- Then the custom built circuit - as it is the largest
- The batteries next - all of these should sit just around the height of the three yellow LEDs
- The speaker goes next - you'll see that my speaker is actually quite chunky, a smaller one would fit even better
This should conclude your build, I hope you enjoyed the Instructable.
Note: that I have not included the thermal detonator sound effect audio file as part of this instructable as I am unsure of the copyright status. I believe it was taken from a Master Replicas thermal detonator prop that was created under license from Lucasfilm so I am not able to re-distribute it openly :( If you turn to Google you should find some sound effects you can use.
Halloween Props Contest 2016
3D Printing Contest 2016
3 People Made This Project!
- ColinA35 made it!
- RichardB432 made it!
64 Comments
5 years ago
Can anyone recommend parts available in the U.S. (like Amazon) that fit for the roller switch, red LED and the speaker? It's hard to tell the size of the parts used from the photos. Thanks!
Reply 5 years ago
Newark in the US have the exact same red LED, Amazon used to have a seller that provided it but not anymore.
This is the roller switch on RS Components in the UK, you're pretty much looking for any microswitch that has a roller lever.
As for the speaker I used this one, it's 8ohm, 2watt and measures 50mm diameter by 17mm high. I'd recommend you look for something a little slimmer though, it will make it a lot easier to assemble! Just make sure it's rated to work with your amp/soundboard.
Reply 5 years ago
Thank you kindly for the info. This looked like such a fun project I couldn't resist!
In one of the parts photos laid out on the table, there are 2 black plastic parts, possibly 3D printed, wondered what those are?
Also wondered if you might have a photo of all the parts installed into the shell halves that you could share?
Reply 5 years ago
No problem, hope it helped!
I forgot those 2 plastic parts were in the photo, they were originally designed to mount a couple of the boards/circuits, but it got too cramped inside so I had to ditch the idea and just put the bits in loose. So they were not actually used.
Apart from the roller switch and the red LED being hot-melt glued in place, everything else is just kinda crammed in to be honest. But once I'm finished with the project I'm currently working on I'll update this I'ble to include some more detailed steps and photos of the internals. I'll also be publishing a PCB design that can be etched instead of having to use vero/strip board, this will make things a lot more compact inside.
Reply 5 years ago
Thanks TED, those sound like super additions to an already-great l'ble. I look forward to seeing what you'll come up with.
Reply 5 years ago
I've got around to taking photos of my assembled internals, I've also added some extra info about the assembly process and the batteries to the Instructable.
Hopefully this info will help, I'll be starting the PCB design this weekend so will have more updates coming soon.
Reply 5 years ago
Thanks for adding more info, will definitely help. I'm still gathering parts and still have more sanding of the model to do, so I'll be able to take advantage of anything you add.
Reply 5 years ago
Hi, just checking in to see if you are still considering working on a PCB for this project.
Reply 5 years ago
Yes that is the intention. I have started to design the PCB (I've added the untested experimental designs to the Instructable). It's just a matter of finding the time for me to build and test the new design before updating the Instructable to include the new steps.
5 years ago
Hello
I have troubles with the flashing light sequence, I can't make it works and I don't know what I'm doing wrong
I'm totally new to the electronic world but I tried to replicate what you did (I don't get what's the point of the 100nf capacitor)
I had troubles programming the Picaxe but it should be okay by now, I used the official AXE027 cable and pasted your code
Reply 5 years ago
First thing you can check is that the code works when you simulate it in the PICAXE Editor. The code I've provided should work on all versions of the 8-pin PICAXE chip.
The next thing is to check your circuit. If you're new to PICAXE check out their Getting Started guides, they're really helpful.
The 100nf cap is a decoupling capacitor and all ICs should have one. It suppresses high-frequency noise in power supply signals, it basically protects the PICAXE chip. This capacitor should connect between the power source (V+) and ground (V-) as close to the PICAXE power pins as possible. The attached image shows its ideal location on your breadboard.
Reply 5 years ago
Does anything else looks suspicious to you in my circuit ?
I don't know what is supposed to happen when I 'simulta' in the editor, nothing particular shows up
Reply 5 years ago
Everything else looks ok as far as I can tell. I can't quite see the colour bands on the resistors to check their values though, so make sure you are using the correct ones. If in doubt you can use this resistor colour code calculator.
With regards to the simulation in the PICAXE software, copy and paste the code into the Editor, then do the following (I've included a screenshot to illustrate):-
1. Click the 'Simulate' tab.
2. Click the 'Run' button (if it produces an error, check you copied the code correctly).
3. As the code simulation runs, it will highlight the active code line in yellow.
4. The pins of the PICAXE chip will change colour to indicate their status, the green indicates output. This represents the LED switching on.
Reply 5 years ago
I tried just now and it works in the Picaxe Programm
Reply 5 years ago
That means the code is ok, it's probably worth re-programming the chip just to make sure everything is hunky dory and there are no errors, you should get a clear indication that the program downloaded to the PICAXE successfully.
Now it's just about the circuit, make sure the 100nf cap is in the right place and double check your resistors are the correct values.
5 years ago
Hi there,
I've got the 8 pin chip instead of the 18 pin chip you used. How do I know what goes where on a circuit board though when I wire it up as it won't be connected to the same legs (not sure the right term) of the chip? I'm buying a cable to program the chip as it's not cost effective to make it. I can get a cable for £5!
Reply 5 years ago
If you check the schematic for the 8 pin chip you need to wire the LED's to any 3 output pins (amend the code relative to the pin number changes), from memory the V+, GND and reset pin (the one with the 4k7 resistor) are the same.
Reply 5 years ago
That honestly means nothing to me! I'm trying so hard to get my head around this. I can see the 4k7 pin is 4, VDD & GND look like they are linked to all the yellow LED pins and pin 14? How does that relate to your code as these pin numbers aren't referenced in your code? On the schematic why do some lines not have a dot? I'd assume that means they don't connect but why join them? Does it mean it's a jumper wire?
Reply 5 years ago
The schematic was a little confusing as it was missing a couple of the dots to indicate where a connection is made at a cross-section, hopefully it will make a little more sense now I've tweaked it a bit.
Where a line crosses over another line at 90 degrees to each other they are not connected. Cross sections are only connected if there is a dot to indicate as much.
So the yellow LED pins connect only to the PICAXE chip on one side, and to ground via a resistor on the other (they are not tied to the VDD and ground).
I'll make a new shematic on the weekend that's clearer, I'll also post some information that's specific to the pin-outs of the 8-pin chip.
Reply 5 years ago
That would be amazing! I've nearly got the sound file going. I've used a music program and over-layed some jabba etc to my detonator loop. Having problems with a long loop though as it makes the file size too big as a wav file. That updated schematic really helps
