Introduction: Static Grass Applicator
Tutorial on how to make a static grass applicator.
For this project you are going to need:
Electric racket
Black Nylon Waterproof Cable Connector Gland 13-18 mm
Static grass
Scenic War
White glue
Silicone glue
Instant glue
Electrical tape
Electric cable
Scissors - Stitch
Soldering iron
Tin wire
Nib pliers
Diagonal pliers
Alligator claw
Container plastic with cover
Sandpaper
Arc saw
Drilling machine
Philips wrench
Telephone battery
Pin
Pen
Acetate
Step 1:
Sierra racket
Step 2:
Cut the racket electricity wire. Avoid receiving electric shock.
Step 3:
Remove the remainder of the cable using the soldering iron.
Step 4:
Make a hole for the output of the electric cable
Step 5:
it is necessary to make a no on the cable on the inner side, to prevent it from releasing the device during use.
Step 6:
weld the new cable
Step 7:
Cut part of the Waterproof Cable Connector
Step 8:
Sanding the Waterproof Cable Connector
Step 9:
Weld the ends of the cables
Step 10:
Solder the batteries.
Step 11:
Put the batteries in the equipment and weld the electrical part with the racket.
Step 12:
glue the cap with the super glue
Step 13:
Use the Waterproof Cable Connector as a reference to drill the hole in the pot lid.
Step 14:
Prepare a hole in the acetate.
Step 15:
Glue the acetate onto the applicator cap to prevent static grass from returning to the electrical part of the equipment.
Step 16:
Put the mesh of the sieve in the pot.
Step 17:
Step 18:
Step 19:
Step 20:
Step 21:
Step 22:
Step 23:
Attention, caution when using this equipment!
