Introduction: Super Mega Barrage RBG!!!
Fires unlimited ammo in one shot - BARRAGE! Uses firing mechanism that has never been used before I hope - I just made it up. Easy to build, not many pieces needed, decent firing range.
#2 out now = https://www.instructables.com/id/Super-Mega-Barrage-RBG-2/
Step 1: Firing Mechanism and Trigger Part 1
the bits you need
just build what you see
the last 3 pics are the same thing - slide the white bit next to the brown piece to trap the rubber band
then, repeat this on the other end
Step 2: Firing Mechanism and Trigger Part 2
how all the bits fit together
again build what you see - find the appropriate bits made in the last step and put them together to look like the picture.
*2+3 are the same as each other
**6+7 are the same as each other
Step 3: The Grip
how to make the grip
build what you see again in step 1, then assemble the bits and attach them to the firing mechanism.
follow the pictures
follow the pictures
Step 4: The Barrel
how to make the barrel
build what you see in pic 1, assemble it in pic 2 and then attach it to the firing mechanism in pic 3.
Step 5: The Stock
how to build the stock if you can be bothered
build what you see in pic 1, assemble bits in 2, attach it to body in pic 3.
LAST BUILDING STEP!
LAST BUILDING STEP!
Step 6: Loading and Firing
You're done!
Look at the pictures to load and fire the thing
Please bear in mind that you can add unlimited bands on each peg to fire as many as you want in one go.
Pull the trigger to unleash the power and send rubberbands flying towards the target.
If you're confused, want to ask a question or anything, drop me a comment or e-mail me at
ibborox@hotmail.com
ibborox@hotmail.com
