The Awesomest Coolest Easiest Water Bowl for DOGS & CATS!
475,011
1,286
107
Introduction: The Awesomest Coolest Easiest Water Bowl for DOGS & CATS!
This is a water bowl for dogs or cats.  It is super EASY!  In a few simple steps you could have a water bowl that you only have to fill up once in a while, and it holds twice as much water for later on.
In this project you don't need to buy a whole new bowl, you just reuse your dog's regular bowl.   If you are worried that you have to drill, nail, or put glue on the bowl, don't be concerned.  This project doesn't do anything to the bowl.
One important thing though, make sure you KEEP THE TOP OF THE 2L BOTTLE!
NOTE: This Watering Bowl was designed, built, and written-up to share on Instructables, by my 11-year old daughter. It's important that I give credit where credit is due, so any and all praise goes to her... the suggestions and critiques as well. It turned out really well, and I'm quite proud of the fact that she wanted to share how she did it here.  Nice work super girl!  What's your next invention going to be? #proudDad
Step 1: Materials
For this project you will need:
-2 by 4 piece of wood about 16 inches long
-1 by 6 piece of wood about 12 inches long
-2L bottle
-Dog dish
-Velcro tape (2 pieces of fuzzy sided, 2 pieces of hooked sided)
-Nails (3)
-Hammer
-Wood glue
-Wood clamp
-Spray paint or stain (optional)
Step 2: Outline the Position of the Board
Take the 2 by 4 and position it in the middle of the end of the 1 by 6.  When you found the spot you like, outline around the outside of the 2 by 4 with a pencil.  You are marking where the boards are going to attach to each other.
Step 3: Glue and Clamp
Once you outline the bottom of the 2 by 4, glue it onto the 1 by 6 in the spot that you picked. The outline should help you line it up.  Once you do that, clamp it!
Step 4: Nail and Velcro
Nail the 2 by 4 to the 1 by 6. After that, stick the 2 soft piece of Velcro on the 2 by 4 piece of wood.  Look at the pictures to see how I placed them.
Suggestion: Use the 2L bottle to measure where to put the soft Velcro (Hint: make sure that one piece of soft Velcro is almost to the top of the 2L bottle so it stay).  The end of it should stick into the bowl at the height you want the water to fill up to.
Once done with that, stick the hard Velcro to the soft Velcro.  Put the 2L bottle on the sticky side of the Velcro and you are DONE!!!
Remember: Wherever the tip of the 2L bottle is that is how high the water will be.  I have had to move the bottle down because so much water was spilling.
Step 5: Spray Paint or Stain (optional)
This step is optional.  You can spray paint or stain your piece.  What I did was first spray paint it green.  Then I took craft paint and painted cool designs.   Have FUN! It's for you pet after all!
Step 6: How to Put Water in the Bowl
Fill up the 2L bottle and the put the cap on on it.  Line up the velcro so that the top of the water bottle is facing down.
Unscrew the cap and WHOOSHHH!  The water comes down!
Now it may come down fast but as soon as the water reaches the tip of the 2L bottle it stops.  As the water reaches underneath the tip of the 2L bottle, more water comes out to fill the bowl back up.
One tip: Don't fill up the bottle all the way it makes it too heavy, and it falls ( I would fill it up at the most half way for the bottle). Make sure you also fill the water bowl.
Hope you find the project useful!
3 People Made This Project!
  • Meatless Challenge
    Meatless Challenge
  • Build a Tool Contest
  • Eggs Challenge
    Eggs Challenge
107 Comments
pavz09
pavz09
3 years ago
Smart kid! With a little tweak, I just might be able to hydrate my dog during flight in cargo. Thank you kiddo!!
LisaH55
LisaH55
6 years ago
there are a lot of easier ones to make. This just seems like a lot of work for something so simple.
VeronicaW32
VeronicaW32
Reply 4 years ago
It was designed by a kid, maybe you could say something nice. Maybe she just loves her dog enough to build it a super cute water contraption. Maybe you're too simple to build one. Super Girl, keep on using science, you're already great at it!
BennoA1
BennoA1
5 years ago
Just cut the bottom of the bottle off, then use a 2nd 2 liter bottle to fill it up with
_NightSky_
_NightSky_
5 years ago
Cute, Nice job!
KirkB19
KirkB19
5 years ago
Interesting use of physics, but a bigger bowl would be easier.
markmhuber
markmhuber
6 years ago
Had no velcro so i cut the back board into two pieces, joined them together at right angles and added a board with a hole for the bottle to fit through, and rest upon. Angled the edges of the hole so the bottle rested on it and leaned on the. Thanks for the insperation.
stubbsonic
stubbsonic
8 years ago on Introduction
Great job! One suggestion. Over time, any water bottle builds up bacteria inside. It's a tough film and doesn't come off even when you wash it with soap. It's good to either replace the bottle every month, or use a little bleach to sterilize it, then rinse it well. I know, gross. Of course, this goes for human water bottles as well.
ScareBear23
ScareBear23
A splash or 2 of Apple Cider Vinegar adds flavor & minerals to the water & also prevents bacteria from growing. But you have to slowly add it so your pet(s) get used to the new taste.
MaryF35
MaryF35
Reply 6 years ago
Yes use Braggs.
stubbsonic
stubbsonic
I have some equipment that requires sterilization and I can tell you that a "splash" of vinegar won't prevent the bacteria from growing. As to whether occasionally vigorously shaking some pure white vinegar in the bottle would work, I don't know. The easy solution would be to use a new bottle every week.
ScareBear23
ScareBear23
The "splash" of Apple Cider Vinegar is mixed in with the drinking water & it causes the water to be too acidic for the bacteria to grow. We use it in all of our animal water (bunnies & both indoor & outdoor water dishes for cats & dogs). We used to have to rinse the outdoor dishes daily because they were gross. But after adding the vinegar we can wait until all the water is gone before rinsing the organic matter out.
I even use white vinegar to clean the rabbit cages. It disinfects every thing with out chemicals that could hurt the rabbits. Gets rid of urine stains & makes the cage look new! (Except the scratch marks on the plastic.)
For *actual* cleaning your obviously need more than a small amount of diluted vinegar. And please note: this is NOT for hospital level "kill everything with fire" sterilization. It is simply a way to keep your animal's things cleaned.
stubbsonic
stubbsonic
Ok. Thanks. It really is impressive how versatile vinegar is for things. It never before occurred to me that pets could just get used to a little vinegar in their water. It's a good idea.
Jack Rodgers
Jack Rodgers
Soda bottles contain so much sugar as to render the procut unfit for human consumption (diabetes, overweight, tooth decay, etc.). Perhaps some of this sugar remains embeded in the organic plastic after the bottle is rinsed. Try comparing the results with a plastic bottle purchased empty. The plastic is made from an organic substance and so might be delicious to bacteria compared to a glass bottle.
MaryF35
MaryF35
Reply 6 years ago
Good job.
MakeBromyard
MakeBromyard
Reply 7 years ago
Air pressure.
The water at the mouth of the bottle cuts off the air getting in as the water leaves, and with no way for the air to get in, that's that.
As the level drops, a little air will get in and the water then drops a bit, until the level stops the air again.
